RTEMS 6.3
PWD - USB PHY Power-Down Register | |
| #define | USBPHY_PWD_RSVD0_MASK (0x3FFU) |
| #define | USBPHY_PWD_RSVD0_SHIFT (0U) |
| #define | USBPHY_PWD_RSVD0(x) |
| #define | USBPHY_PWD_RSVD1_MASK (0x1E000U) |
| #define | USBPHY_PWD_RSVD1_SHIFT (13U) |
| #define | USBPHY_PWD_RSVD1(x) |
| #define | USBPHY_PWD_RSVD2_MASK (0xFFE00000U) |
| #define | USBPHY_PWD_RSVD2_SHIFT (21U) |
| #define | USBPHY_PWD_RSVD2(x) |
| #define | USBPHY_PWD_TXPWDFS_MASK (0x400U) |
| #define | USBPHY_PWD_TXPWDFS_SHIFT (10U) |
| #define | USBPHY_PWD_TXPWDFS(x) |
| #define | USBPHY_PWD_TXPWDIBIAS_MASK (0x800U) |
| #define | USBPHY_PWD_TXPWDIBIAS_SHIFT (11U) |
| #define | USBPHY_PWD_TXPWDIBIAS(x) |
| #define | USBPHY_PWD_TXPWDV2I_MASK (0x1000U) |
| #define | USBPHY_PWD_TXPWDV2I_SHIFT (12U) |
| #define | USBPHY_PWD_TXPWDV2I(x) |
| #define | USBPHY_PWD_RXPWDENV_MASK (0x20000U) |
| #define | USBPHY_PWD_RXPWDENV_SHIFT (17U) |
| #define | USBPHY_PWD_RXPWDENV(x) |
| #define | USBPHY_PWD_RXPWD1PT1_MASK (0x40000U) |
| #define | USBPHY_PWD_RXPWD1PT1_SHIFT (18U) |
| #define | USBPHY_PWD_RXPWD1PT1(x) |
| #define | USBPHY_PWD_RXPWDDIFF_MASK (0x80000U) |
| #define | USBPHY_PWD_RXPWDDIFF_SHIFT (19U) |
| #define | USBPHY_PWD_RXPWDDIFF(x) |
| #define | USBPHY_PWD_RXPWDRX_MASK (0x100000U) |
| #define | USBPHY_PWD_RXPWDRX_SHIFT (20U) |
| #define | USBPHY_PWD_RXPWDRX(x) |
PWD_SET - USB PHY Power-Down Register | |
| #define | USBPHY_PWD_SET_RSVD0_MASK (0x3FFU) |
| #define | USBPHY_PWD_SET_RSVD0_SHIFT (0U) |
| #define | USBPHY_PWD_SET_RSVD0(x) |
| #define | USBPHY_PWD_SET_RSVD1_MASK (0x1E000U) |
| #define | USBPHY_PWD_SET_RSVD1_SHIFT (13U) |
| #define | USBPHY_PWD_SET_RSVD1(x) |
| #define | USBPHY_PWD_SET_RSVD2_MASK (0xFFE00000U) |
| #define | USBPHY_PWD_SET_RSVD2_SHIFT (21U) |
| #define | USBPHY_PWD_SET_RSVD2(x) |
| #define | USBPHY_PWD_SET_TXPWDFS_MASK (0x400U) |
| #define | USBPHY_PWD_SET_TXPWDFS_SHIFT (10U) |
| #define | USBPHY_PWD_SET_TXPWDFS(x) |
| #define | USBPHY_PWD_SET_TXPWDIBIAS_MASK (0x800U) |
| #define | USBPHY_PWD_SET_TXPWDIBIAS_SHIFT (11U) |
| #define | USBPHY_PWD_SET_TXPWDIBIAS(x) |
| #define | USBPHY_PWD_SET_TXPWDV2I_MASK (0x1000U) |
| #define | USBPHY_PWD_SET_TXPWDV2I_SHIFT (12U) |
| #define | USBPHY_PWD_SET_TXPWDV2I(x) |
| #define | USBPHY_PWD_SET_RXPWDENV_MASK (0x20000U) |
| #define | USBPHY_PWD_SET_RXPWDENV_SHIFT (17U) |
| #define | USBPHY_PWD_SET_RXPWDENV(x) |
| #define | USBPHY_PWD_SET_RXPWD1PT1_MASK (0x40000U) |
| #define | USBPHY_PWD_SET_RXPWD1PT1_SHIFT (18U) |
| #define | USBPHY_PWD_SET_RXPWD1PT1(x) |
| #define | USBPHY_PWD_SET_RXPWDDIFF_MASK (0x80000U) |
| #define | USBPHY_PWD_SET_RXPWDDIFF_SHIFT (19U) |
| #define | USBPHY_PWD_SET_RXPWDDIFF(x) |
| #define | USBPHY_PWD_SET_RXPWDRX_MASK (0x100000U) |
| #define | USBPHY_PWD_SET_RXPWDRX_SHIFT (20U) |
| #define | USBPHY_PWD_SET_RXPWDRX(x) |
PWD_CLR - USB PHY Power-Down Register | |
| #define | USBPHY_PWD_CLR_RSVD0_MASK (0x3FFU) |
| #define | USBPHY_PWD_CLR_RSVD0_SHIFT (0U) |
| #define | USBPHY_PWD_CLR_RSVD0(x) |
| #define | USBPHY_PWD_CLR_RSVD1_MASK (0x1E000U) |
| #define | USBPHY_PWD_CLR_RSVD1_SHIFT (13U) |
| #define | USBPHY_PWD_CLR_RSVD1(x) |
| #define | USBPHY_PWD_CLR_RSVD2_MASK (0xFFE00000U) |
| #define | USBPHY_PWD_CLR_RSVD2_SHIFT (21U) |
| #define | USBPHY_PWD_CLR_RSVD2(x) |
| #define | USBPHY_PWD_CLR_TXPWDFS_MASK (0x400U) |
| #define | USBPHY_PWD_CLR_TXPWDFS_SHIFT (10U) |
| #define | USBPHY_PWD_CLR_TXPWDFS(x) |
| #define | USBPHY_PWD_CLR_TXPWDIBIAS_MASK (0x800U) |
| #define | USBPHY_PWD_CLR_TXPWDIBIAS_SHIFT (11U) |
| #define | USBPHY_PWD_CLR_TXPWDIBIAS(x) |
| #define | USBPHY_PWD_CLR_TXPWDV2I_MASK (0x1000U) |
| #define | USBPHY_PWD_CLR_TXPWDV2I_SHIFT (12U) |
| #define | USBPHY_PWD_CLR_TXPWDV2I(x) |
| #define | USBPHY_PWD_CLR_RXPWDENV_MASK (0x20000U) |
| #define | USBPHY_PWD_CLR_RXPWDENV_SHIFT (17U) |
| #define | USBPHY_PWD_CLR_RXPWDENV(x) |
| #define | USBPHY_PWD_CLR_RXPWD1PT1_MASK (0x40000U) |
| #define | USBPHY_PWD_CLR_RXPWD1PT1_SHIFT (18U) |
| #define | USBPHY_PWD_CLR_RXPWD1PT1(x) |
| #define | USBPHY_PWD_CLR_RXPWDDIFF_MASK (0x80000U) |
| #define | USBPHY_PWD_CLR_RXPWDDIFF_SHIFT (19U) |
| #define | USBPHY_PWD_CLR_RXPWDDIFF(x) |
| #define | USBPHY_PWD_CLR_RXPWDRX_MASK (0x100000U) |
| #define | USBPHY_PWD_CLR_RXPWDRX_SHIFT (20U) |
| #define | USBPHY_PWD_CLR_RXPWDRX(x) |
PWD_TOG - USB PHY Power-Down Register | |
| #define | USBPHY_PWD_TOG_RSVD0_MASK (0x3FFU) |
| #define | USBPHY_PWD_TOG_RSVD0_SHIFT (0U) |
| #define | USBPHY_PWD_TOG_RSVD0(x) |
| #define | USBPHY_PWD_TOG_RSVD1_MASK (0x1E000U) |
| #define | USBPHY_PWD_TOG_RSVD1_SHIFT (13U) |
| #define | USBPHY_PWD_TOG_RSVD1(x) |
| #define | USBPHY_PWD_TOG_RSVD2_MASK (0xFFE00000U) |
| #define | USBPHY_PWD_TOG_RSVD2_SHIFT (21U) |
| #define | USBPHY_PWD_TOG_RSVD2(x) |
| #define | USBPHY_PWD_TOG_TXPWDFS_MASK (0x400U) |
| #define | USBPHY_PWD_TOG_TXPWDFS_SHIFT (10U) |
| #define | USBPHY_PWD_TOG_TXPWDFS(x) |
| #define | USBPHY_PWD_TOG_TXPWDIBIAS_MASK (0x800U) |
| #define | USBPHY_PWD_TOG_TXPWDIBIAS_SHIFT (11U) |
| #define | USBPHY_PWD_TOG_TXPWDIBIAS(x) |
| #define | USBPHY_PWD_TOG_TXPWDV2I_MASK (0x1000U) |
| #define | USBPHY_PWD_TOG_TXPWDV2I_SHIFT (12U) |
| #define | USBPHY_PWD_TOG_TXPWDV2I(x) |
| #define | USBPHY_PWD_TOG_RXPWDENV_MASK (0x20000U) |
| #define | USBPHY_PWD_TOG_RXPWDENV_SHIFT (17U) |
| #define | USBPHY_PWD_TOG_RXPWDENV(x) |
| #define | USBPHY_PWD_TOG_RXPWD1PT1_MASK (0x40000U) |
| #define | USBPHY_PWD_TOG_RXPWD1PT1_SHIFT (18U) |
| #define | USBPHY_PWD_TOG_RXPWD1PT1(x) |
| #define | USBPHY_PWD_TOG_RXPWDDIFF_MASK (0x80000U) |
| #define | USBPHY_PWD_TOG_RXPWDDIFF_SHIFT (19U) |
| #define | USBPHY_PWD_TOG_RXPWDDIFF(x) |
| #define | USBPHY_PWD_TOG_RXPWDRX_MASK (0x100000U) |
| #define | USBPHY_PWD_TOG_RXPWDRX_SHIFT (20U) |
| #define | USBPHY_PWD_TOG_RXPWDRX(x) |
TX - USB PHY Transmitter Control Register | |
| #define | USBPHY_TX_D_CAL_MASK (0xFU) |
| #define | USBPHY_TX_D_CAL_SHIFT (0U) |
| #define | USBPHY_TX_D_CAL(x) |
| #define | USBPHY_TX_TXCAL45DN_MASK (0xF00U) |
| #define | USBPHY_TX_TXCAL45DN_SHIFT (8U) |
| #define | USBPHY_TX_TXCAL45DN(x) |
| #define | USBPHY_TX_TXCAL45DP_MASK (0xF0000U) |
| #define | USBPHY_TX_TXCAL45DP_SHIFT (16U) |
| #define | USBPHY_TX_TXCAL45DP(x) |
| #define | USBPHY_TX_RSVD0_MASK (0xF0U) |
| #define | USBPHY_TX_RSVD0_SHIFT (4U) |
| #define | USBPHY_TX_RSVD0(x) |
| #define | USBPHY_TX_RSVD1_MASK (0xF000U) |
| #define | USBPHY_TX_RSVD1_SHIFT (12U) |
| #define | USBPHY_TX_RSVD1(x) |
| #define | USBPHY_TX_RSVD2_MASK (0x3F00000U) |
| #define | USBPHY_TX_RSVD2_SHIFT (20U) |
| #define | USBPHY_TX_RSVD2(x) |
| #define | USBPHY_TX_USBPHY_TX_EDGECTRL_MASK (0x1C000000U) |
| #define | USBPHY_TX_USBPHY_TX_EDGECTRL_SHIFT (26U) |
| #define | USBPHY_TX_USBPHY_TX_EDGECTRL(x) |
| #define | USBPHY_TX_RSVD5_MASK (0xE0000000U) |
| #define | USBPHY_TX_RSVD5_SHIFT (29U) |
| #define | USBPHY_TX_RSVD5(x) |
TX_SET - USB PHY Transmitter Control Register | |
| #define | USBPHY_TX_SET_D_CAL_MASK (0xFU) |
| #define | USBPHY_TX_SET_D_CAL_SHIFT (0U) |
| #define | USBPHY_TX_SET_D_CAL(x) |
| #define | USBPHY_TX_SET_TXCAL45DN_MASK (0xF00U) |
| #define | USBPHY_TX_SET_TXCAL45DN_SHIFT (8U) |
| #define | USBPHY_TX_SET_TXCAL45DN(x) |
| #define | USBPHY_TX_SET_TXCAL45DP_MASK (0xF0000U) |
| #define | USBPHY_TX_SET_TXCAL45DP_SHIFT (16U) |
| #define | USBPHY_TX_SET_TXCAL45DP(x) |
| #define | USBPHY_TX_SET_RSVD0_MASK (0xF0U) |
| #define | USBPHY_TX_SET_RSVD0_SHIFT (4U) |
| #define | USBPHY_TX_SET_RSVD0(x) |
| #define | USBPHY_TX_SET_RSVD1_MASK (0xF000U) |
| #define | USBPHY_TX_SET_RSVD1_SHIFT (12U) |
| #define | USBPHY_TX_SET_RSVD1(x) |
| #define | USBPHY_TX_SET_RSVD2_MASK (0x3F00000U) |
| #define | USBPHY_TX_SET_RSVD2_SHIFT (20U) |
| #define | USBPHY_TX_SET_RSVD2(x) |
| #define | USBPHY_TX_SET_USBPHY_TX_EDGECTRL_MASK (0x1C000000U) |
| #define | USBPHY_TX_SET_USBPHY_TX_EDGECTRL_SHIFT (26U) |
| #define | USBPHY_TX_SET_USBPHY_TX_EDGECTRL(x) |
| #define | USBPHY_TX_SET_RSVD5_MASK (0xE0000000U) |
| #define | USBPHY_TX_SET_RSVD5_SHIFT (29U) |
| #define | USBPHY_TX_SET_RSVD5(x) |
TX_CLR - USB PHY Transmitter Control Register | |
| #define | USBPHY_TX_CLR_D_CAL_MASK (0xFU) |
| #define | USBPHY_TX_CLR_D_CAL_SHIFT (0U) |
| #define | USBPHY_TX_CLR_D_CAL(x) |
| #define | USBPHY_TX_CLR_TXCAL45DN_MASK (0xF00U) |
| #define | USBPHY_TX_CLR_TXCAL45DN_SHIFT (8U) |
| #define | USBPHY_TX_CLR_TXCAL45DN(x) |
| #define | USBPHY_TX_CLR_TXCAL45DP_MASK (0xF0000U) |
| #define | USBPHY_TX_CLR_TXCAL45DP_SHIFT (16U) |
| #define | USBPHY_TX_CLR_TXCAL45DP(x) |
| #define | USBPHY_TX_CLR_RSVD0_MASK (0xF0U) |
| #define | USBPHY_TX_CLR_RSVD0_SHIFT (4U) |
| #define | USBPHY_TX_CLR_RSVD0(x) |
| #define | USBPHY_TX_CLR_RSVD1_MASK (0xF000U) |
| #define | USBPHY_TX_CLR_RSVD1_SHIFT (12U) |
| #define | USBPHY_TX_CLR_RSVD1(x) |
| #define | USBPHY_TX_CLR_RSVD2_MASK (0x3F00000U) |
| #define | USBPHY_TX_CLR_RSVD2_SHIFT (20U) |
| #define | USBPHY_TX_CLR_RSVD2(x) |
| #define | USBPHY_TX_CLR_USBPHY_TX_EDGECTRL_MASK (0x1C000000U) |
| #define | USBPHY_TX_CLR_USBPHY_TX_EDGECTRL_SHIFT (26U) |
| #define | USBPHY_TX_CLR_USBPHY_TX_EDGECTRL(x) |
| #define | USBPHY_TX_CLR_RSVD5_MASK (0xE0000000U) |
| #define | USBPHY_TX_CLR_RSVD5_SHIFT (29U) |
| #define | USBPHY_TX_CLR_RSVD5(x) |
TX_TOG - USB PHY Transmitter Control Register | |
| #define | USBPHY_TX_TOG_D_CAL_MASK (0xFU) |
| #define | USBPHY_TX_TOG_D_CAL_SHIFT (0U) |
| #define | USBPHY_TX_TOG_D_CAL(x) |
| #define | USBPHY_TX_TOG_TXCAL45DN_MASK (0xF00U) |
| #define | USBPHY_TX_TOG_TXCAL45DN_SHIFT (8U) |
| #define | USBPHY_TX_TOG_TXCAL45DN(x) |
| #define | USBPHY_TX_TOG_TXCAL45DP_MASK (0xF0000U) |
| #define | USBPHY_TX_TOG_TXCAL45DP_SHIFT (16U) |
| #define | USBPHY_TX_TOG_TXCAL45DP(x) |
| #define | USBPHY_TX_TOG_RSVD0_MASK (0xF0U) |
| #define | USBPHY_TX_TOG_RSVD0_SHIFT (4U) |
| #define | USBPHY_TX_TOG_RSVD0(x) |
| #define | USBPHY_TX_TOG_RSVD1_MASK (0xF000U) |
| #define | USBPHY_TX_TOG_RSVD1_SHIFT (12U) |
| #define | USBPHY_TX_TOG_RSVD1(x) |
| #define | USBPHY_TX_TOG_RSVD2_MASK (0x3F00000U) |
| #define | USBPHY_TX_TOG_RSVD2_SHIFT (20U) |
| #define | USBPHY_TX_TOG_RSVD2(x) |
| #define | USBPHY_TX_TOG_USBPHY_TX_EDGECTRL_MASK (0x1C000000U) |
| #define | USBPHY_TX_TOG_USBPHY_TX_EDGECTRL_SHIFT (26U) |
| #define | USBPHY_TX_TOG_USBPHY_TX_EDGECTRL(x) |
| #define | USBPHY_TX_TOG_RSVD5_MASK (0xE0000000U) |
| #define | USBPHY_TX_TOG_RSVD5_SHIFT (29U) |
| #define | USBPHY_TX_TOG_RSVD5(x) |
RX - USB PHY Receiver Control Register | |
| #define | USBPHY_RX_ENVADJ_MASK (0x7U) |
| #define | USBPHY_RX_ENVADJ_SHIFT (0U) |
| #define | USBPHY_RX_ENVADJ(x) |
| #define | USBPHY_RX_DISCONADJ_MASK (0x70U) |
| #define | USBPHY_RX_DISCONADJ_SHIFT (4U) |
| #define | USBPHY_RX_DISCONADJ(x) |
| #define | USBPHY_RX_RXDBYPASS_MASK (0x400000U) |
| #define | USBPHY_RX_RXDBYPASS_SHIFT (22U) |
| #define | USBPHY_RX_RXDBYPASS(x) |
| #define | USBPHY_RX_RSVD0_MASK (0x8U) |
| #define | USBPHY_RX_RSVD0_SHIFT (3U) |
| #define | USBPHY_RX_RSVD0(x) |
| #define | USBPHY_RX_RSVD1_MASK (0x3FFF80U) |
| #define | USBPHY_RX_RSVD1_SHIFT (7U) |
| #define | USBPHY_RX_RSVD1(x) |
| #define | USBPHY_RX_RSVD2_MASK (0xFF800000U) |
| #define | USBPHY_RX_RSVD2_SHIFT (23U) |
| #define | USBPHY_RX_RSVD2(x) |
RX_SET - USB PHY Receiver Control Register | |
| #define | USBPHY_RX_SET_ENVADJ_MASK (0x7U) |
| #define | USBPHY_RX_SET_ENVADJ_SHIFT (0U) |
| #define | USBPHY_RX_SET_ENVADJ(x) |
| #define | USBPHY_RX_SET_DISCONADJ_MASK (0x70U) |
| #define | USBPHY_RX_SET_DISCONADJ_SHIFT (4U) |
| #define | USBPHY_RX_SET_DISCONADJ(x) |
| #define | USBPHY_RX_SET_RXDBYPASS_MASK (0x400000U) |
| #define | USBPHY_RX_SET_RXDBYPASS_SHIFT (22U) |
| #define | USBPHY_RX_SET_RXDBYPASS(x) |
| #define | USBPHY_RX_SET_RSVD0_MASK (0x8U) |
| #define | USBPHY_RX_SET_RSVD0_SHIFT (3U) |
| #define | USBPHY_RX_SET_RSVD0(x) |
| #define | USBPHY_RX_SET_RSVD1_MASK (0x3FFF80U) |
| #define | USBPHY_RX_SET_RSVD1_SHIFT (7U) |
| #define | USBPHY_RX_SET_RSVD1(x) |
| #define | USBPHY_RX_SET_RSVD2_MASK (0xFF800000U) |
| #define | USBPHY_RX_SET_RSVD2_SHIFT (23U) |
| #define | USBPHY_RX_SET_RSVD2(x) |
RX_CLR - USB PHY Receiver Control Register | |
| #define | USBPHY_RX_CLR_ENVADJ_MASK (0x7U) |
| #define | USBPHY_RX_CLR_ENVADJ_SHIFT (0U) |
| #define | USBPHY_RX_CLR_ENVADJ(x) |
| #define | USBPHY_RX_CLR_DISCONADJ_MASK (0x70U) |
| #define | USBPHY_RX_CLR_DISCONADJ_SHIFT (4U) |
| #define | USBPHY_RX_CLR_DISCONADJ(x) |
| #define | USBPHY_RX_CLR_RXDBYPASS_MASK (0x400000U) |
| #define | USBPHY_RX_CLR_RXDBYPASS_SHIFT (22U) |
| #define | USBPHY_RX_CLR_RXDBYPASS(x) |
| #define | USBPHY_RX_CLR_RSVD0_MASK (0x8U) |
| #define | USBPHY_RX_CLR_RSVD0_SHIFT (3U) |
| #define | USBPHY_RX_CLR_RSVD0(x) |
| #define | USBPHY_RX_CLR_RSVD1_MASK (0x3FFF80U) |
| #define | USBPHY_RX_CLR_RSVD1_SHIFT (7U) |
| #define | USBPHY_RX_CLR_RSVD1(x) |
| #define | USBPHY_RX_CLR_RSVD2_MASK (0xFF800000U) |
| #define | USBPHY_RX_CLR_RSVD2_SHIFT (23U) |
| #define | USBPHY_RX_CLR_RSVD2(x) |
RX_TOG - USB PHY Receiver Control Register | |
| #define | USBPHY_RX_TOG_ENVADJ_MASK (0x7U) |
| #define | USBPHY_RX_TOG_ENVADJ_SHIFT (0U) |
| #define | USBPHY_RX_TOG_ENVADJ(x) |
| #define | USBPHY_RX_TOG_DISCONADJ_MASK (0x70U) |
| #define | USBPHY_RX_TOG_DISCONADJ_SHIFT (4U) |
| #define | USBPHY_RX_TOG_DISCONADJ(x) |
| #define | USBPHY_RX_TOG_RXDBYPASS_MASK (0x400000U) |
| #define | USBPHY_RX_TOG_RXDBYPASS_SHIFT (22U) |
| #define | USBPHY_RX_TOG_RXDBYPASS(x) |
| #define | USBPHY_RX_TOG_RSVD0_MASK (0x8U) |
| #define | USBPHY_RX_TOG_RSVD0_SHIFT (3U) |
| #define | USBPHY_RX_TOG_RSVD0(x) |
| #define | USBPHY_RX_TOG_RSVD1_MASK (0x3FFF80U) |
| #define | USBPHY_RX_TOG_RSVD1_SHIFT (7U) |
| #define | USBPHY_RX_TOG_RSVD1(x) |
| #define | USBPHY_RX_TOG_RSVD2_MASK (0xFF800000U) |
| #define | USBPHY_RX_TOG_RSVD2_SHIFT (23U) |
| #define | USBPHY_RX_TOG_RSVD2(x) |
CTRL - USB PHY General Control Register | |
| #define | USBPHY_CTRL_ENOTG_ID_CHG_IRQ_MASK (0x1U) |
| #define | USBPHY_CTRL_ENOTG_ID_CHG_IRQ_SHIFT (0U) |
| #define | USBPHY_CTRL_ENOTG_ID_CHG_IRQ(x) |
| #define | USBPHY_CTRL_ENHOSTDISCONDETECT_MASK (0x2U) |
| #define | USBPHY_CTRL_ENHOSTDISCONDETECT_SHIFT (1U) |
| #define | USBPHY_CTRL_ENHOSTDISCONDETECT(x) |
| #define | USBPHY_CTRL_ENIRQHOSTDISCON_MASK (0x4U) |
| #define | USBPHY_CTRL_ENIRQHOSTDISCON_SHIFT (2U) |
| #define | USBPHY_CTRL_ENIRQHOSTDISCON(x) |
| #define | USBPHY_CTRL_HOSTDISCONDETECT_IRQ_MASK (0x8U) |
| #define | USBPHY_CTRL_HOSTDISCONDETECT_IRQ_SHIFT (3U) |
| #define | USBPHY_CTRL_HOSTDISCONDETECT_IRQ(x) |
| #define | USBPHY_CTRL_ENDEVPLUGINDETECT_MASK (0x10U) |
| #define | USBPHY_CTRL_ENDEVPLUGINDETECT_SHIFT (4U) |
| #define | USBPHY_CTRL_ENDEVPLUGINDETECT(x) |
| #define | USBPHY_CTRL_DEVPLUGIN_POLARITY_MASK (0x20U) |
| #define | USBPHY_CTRL_DEVPLUGIN_POLARITY_SHIFT (5U) |
| #define | USBPHY_CTRL_DEVPLUGIN_POLARITY(x) |
| #define | USBPHY_CTRL_OTG_ID_CHG_IRQ_MASK (0x40U) |
| #define | USBPHY_CTRL_OTG_ID_CHG_IRQ_SHIFT (6U) |
| #define | USBPHY_CTRL_OTG_ID_CHG_IRQ(x) |
| #define | USBPHY_CTRL_ENOTGIDDETECT_MASK (0x80U) |
| #define | USBPHY_CTRL_ENOTGIDDETECT_SHIFT (7U) |
| #define | USBPHY_CTRL_ENOTGIDDETECT(x) |
| #define | USBPHY_CTRL_RESUMEIRQSTICKY_MASK (0x100U) |
| #define | USBPHY_CTRL_RESUMEIRQSTICKY_SHIFT (8U) |
| #define | USBPHY_CTRL_RESUMEIRQSTICKY(x) |
| #define | USBPHY_CTRL_ENIRQRESUMEDETECT_MASK (0x200U) |
| #define | USBPHY_CTRL_ENIRQRESUMEDETECT_SHIFT (9U) |
| #define | USBPHY_CTRL_ENIRQRESUMEDETECT(x) |
| #define | USBPHY_CTRL_RESUME_IRQ_MASK (0x400U) |
| #define | USBPHY_CTRL_RESUME_IRQ_SHIFT (10U) |
| #define | USBPHY_CTRL_RESUME_IRQ(x) |
| #define | USBPHY_CTRL_ENIRQDEVPLUGIN_MASK (0x800U) |
| #define | USBPHY_CTRL_ENIRQDEVPLUGIN_SHIFT (11U) |
| #define | USBPHY_CTRL_ENIRQDEVPLUGIN(x) |
| #define | USBPHY_CTRL_DEVPLUGIN_IRQ_MASK (0x1000U) |
| #define | USBPHY_CTRL_DEVPLUGIN_IRQ_SHIFT (12U) |
| #define | USBPHY_CTRL_DEVPLUGIN_IRQ(x) |
| #define | USBPHY_CTRL_ENUTMILEVEL2_MASK (0x4000U) |
| #define | USBPHY_CTRL_ENUTMILEVEL2_SHIFT (14U) |
| #define | USBPHY_CTRL_ENUTMILEVEL2(x) |
| #define | USBPHY_CTRL_ENUTMILEVEL3_MASK (0x8000U) |
| #define | USBPHY_CTRL_ENUTMILEVEL3_SHIFT (15U) |
| #define | USBPHY_CTRL_ENUTMILEVEL3(x) |
| #define | USBPHY_CTRL_ENIRQWAKEUP_MASK (0x10000U) |
| #define | USBPHY_CTRL_ENIRQWAKEUP_SHIFT (16U) |
| #define | USBPHY_CTRL_ENIRQWAKEUP(x) |
| #define | USBPHY_CTRL_WAKEUP_IRQ_MASK (0x20000U) |
| #define | USBPHY_CTRL_WAKEUP_IRQ_SHIFT (17U) |
| #define | USBPHY_CTRL_WAKEUP_IRQ(x) |
| #define | USBPHY_CTRL_ENAUTOCLR_CLKGATE_MASK (0x80000U) |
| #define | USBPHY_CTRL_ENAUTOCLR_CLKGATE_SHIFT (19U) |
| #define | USBPHY_CTRL_ENAUTOCLR_CLKGATE(x) |
| #define | USBPHY_CTRL_ENAUTOCLR_PHY_PWD_MASK (0x100000U) |
| #define | USBPHY_CTRL_ENAUTOCLR_PHY_PWD_SHIFT (20U) |
| #define | USBPHY_CTRL_ENAUTOCLR_PHY_PWD(x) |
| #define | USBPHY_CTRL_ENDPDMCHG_WKUP_MASK (0x200000U) |
| #define | USBPHY_CTRL_ENDPDMCHG_WKUP_SHIFT (21U) |
| #define | USBPHY_CTRL_ENDPDMCHG_WKUP(x) |
| #define | USBPHY_CTRL_ENIDCHG_WKUP_MASK (0x400000U) |
| #define | USBPHY_CTRL_ENIDCHG_WKUP_SHIFT (22U) |
| #define | USBPHY_CTRL_ENIDCHG_WKUP(x) |
| #define | USBPHY_CTRL_ENVBUSCHG_WKUP_MASK (0x800000U) |
| #define | USBPHY_CTRL_ENVBUSCHG_WKUP_SHIFT (23U) |
| #define | USBPHY_CTRL_ENVBUSCHG_WKUP(x) |
| #define | USBPHY_CTRL_FSDLL_RST_EN_MASK (0x1000000U) |
| #define | USBPHY_CTRL_FSDLL_RST_EN_SHIFT (24U) |
| #define | USBPHY_CTRL_FSDLL_RST_EN(x) |
| #define | USBPHY_CTRL_OTG_ID_VALUE_MASK (0x8000000U) |
| #define | USBPHY_CTRL_OTG_ID_VALUE_SHIFT (27U) |
| #define | USBPHY_CTRL_OTG_ID_VALUE(x) |
| #define | USBPHY_CTRL_HOST_FORCE_LS_SE0_MASK (0x10000000U) |
| #define | USBPHY_CTRL_HOST_FORCE_LS_SE0_SHIFT (28U) |
| #define | USBPHY_CTRL_HOST_FORCE_LS_SE0(x) |
| #define | USBPHY_CTRL_UTMI_SUSPENDM_MASK (0x20000000U) |
| #define | USBPHY_CTRL_UTMI_SUSPENDM_SHIFT (29U) |
| #define | USBPHY_CTRL_UTMI_SUSPENDM(x) |
| #define | USBPHY_CTRL_CLKGATE_MASK (0x40000000U) |
| #define | USBPHY_CTRL_CLKGATE_SHIFT (30U) |
| #define | USBPHY_CTRL_CLKGATE(x) |
| #define | USBPHY_CTRL_SFTRST_MASK (0x80000000U) |
| #define | USBPHY_CTRL_SFTRST_SHIFT (31U) |
| #define | USBPHY_CTRL_SFTRST(x) |
| #define | USBPHY_CTRL_AUTORESUME_EN_MASK (0x40000U) |
| #define | USBPHY_CTRL_AUTORESUME_EN_SHIFT (18U) |
| #define | USBPHY_CTRL_AUTORESUME_EN(x) |
| #define | USBPHY_CTRL_DATA_ON_LRADC_MASK (0x2000U) |
| #define | USBPHY_CTRL_DATA_ON_LRADC_SHIFT (13U) |
| #define | USBPHY_CTRL_DATA_ON_LRADC(x) |
| #define | USBPHY_CTRL_ENAUTO_PWRON_PLL_MASK (0x40000U) |
| #define | USBPHY_CTRL_ENAUTO_PWRON_PLL_SHIFT (18U) |
| #define | USBPHY_CTRL_ENAUTO_PWRON_PLL(x) |
| #define | USBPHY_CTRL_RSVD1_MASK (0x6000000U) |
| #define | USBPHY_CTRL_RSVD1_SHIFT (25U) |
| #define | USBPHY_CTRL_RSVD1(x) |
CTRL_SET - USB PHY General Control Register | |
| #define | USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_MASK (0x1U) |
| #define | USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_SHIFT (0U) |
| #define | USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ(x) |
| #define | USBPHY_CTRL_SET_ENHOSTDISCONDETECT_MASK (0x2U) |
| #define | USBPHY_CTRL_SET_ENHOSTDISCONDETECT_SHIFT (1U) |
| #define | USBPHY_CTRL_SET_ENHOSTDISCONDETECT(x) |
| #define | USBPHY_CTRL_SET_ENIRQHOSTDISCON_MASK (0x4U) |
| #define | USBPHY_CTRL_SET_ENIRQHOSTDISCON_SHIFT (2U) |
| #define | USBPHY_CTRL_SET_ENIRQHOSTDISCON(x) |
| #define | USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_MASK (0x8U) |
| #define | USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_SHIFT (3U) |
| #define | USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ(x) |
| #define | USBPHY_CTRL_SET_ENDEVPLUGINDETECT_MASK (0x10U) |
| #define | USBPHY_CTRL_SET_ENDEVPLUGINDETECT_SHIFT (4U) |
| #define | USBPHY_CTRL_SET_ENDEVPLUGINDETECT(x) |
| #define | USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_MASK (0x20U) |
| #define | USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_SHIFT (5U) |
| #define | USBPHY_CTRL_SET_DEVPLUGIN_POLARITY(x) |
| #define | USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_MASK (0x40U) |
| #define | USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_SHIFT (6U) |
| #define | USBPHY_CTRL_SET_OTG_ID_CHG_IRQ(x) |
| #define | USBPHY_CTRL_SET_ENOTGIDDETECT_MASK (0x80U) |
| #define | USBPHY_CTRL_SET_ENOTGIDDETECT_SHIFT (7U) |
| #define | USBPHY_CTRL_SET_ENOTGIDDETECT(x) |
| #define | USBPHY_CTRL_SET_RESUMEIRQSTICKY_MASK (0x100U) |
| #define | USBPHY_CTRL_SET_RESUMEIRQSTICKY_SHIFT (8U) |
| #define | USBPHY_CTRL_SET_RESUMEIRQSTICKY(x) |
| #define | USBPHY_CTRL_SET_ENIRQRESUMEDETECT_MASK (0x200U) |
| #define | USBPHY_CTRL_SET_ENIRQRESUMEDETECT_SHIFT (9U) |
| #define | USBPHY_CTRL_SET_ENIRQRESUMEDETECT(x) |
| #define | USBPHY_CTRL_SET_RESUME_IRQ_MASK (0x400U) |
| #define | USBPHY_CTRL_SET_RESUME_IRQ_SHIFT (10U) |
| #define | USBPHY_CTRL_SET_RESUME_IRQ(x) |
| #define | USBPHY_CTRL_SET_ENIRQDEVPLUGIN_MASK (0x800U) |
| #define | USBPHY_CTRL_SET_ENIRQDEVPLUGIN_SHIFT (11U) |
| #define | USBPHY_CTRL_SET_ENIRQDEVPLUGIN(x) |
| #define | USBPHY_CTRL_SET_DEVPLUGIN_IRQ_MASK (0x1000U) |
| #define | USBPHY_CTRL_SET_DEVPLUGIN_IRQ_SHIFT (12U) |
| #define | USBPHY_CTRL_SET_DEVPLUGIN_IRQ(x) |
| #define | USBPHY_CTRL_SET_ENUTMILEVEL2_MASK (0x4000U) |
| #define | USBPHY_CTRL_SET_ENUTMILEVEL2_SHIFT (14U) |
| #define | USBPHY_CTRL_SET_ENUTMILEVEL2(x) |
| #define | USBPHY_CTRL_SET_ENUTMILEVEL3_MASK (0x8000U) |
| #define | USBPHY_CTRL_SET_ENUTMILEVEL3_SHIFT (15U) |
| #define | USBPHY_CTRL_SET_ENUTMILEVEL3(x) |
| #define | USBPHY_CTRL_SET_ENIRQWAKEUP_MASK (0x10000U) |
| #define | USBPHY_CTRL_SET_ENIRQWAKEUP_SHIFT (16U) |
| #define | USBPHY_CTRL_SET_ENIRQWAKEUP(x) |
| #define | USBPHY_CTRL_SET_WAKEUP_IRQ_MASK (0x20000U) |
| #define | USBPHY_CTRL_SET_WAKEUP_IRQ_SHIFT (17U) |
| #define | USBPHY_CTRL_SET_WAKEUP_IRQ(x) |
| #define | USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_MASK (0x80000U) |
| #define | USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_SHIFT (19U) |
| #define | USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE(x) |
| #define | USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_MASK (0x100000U) |
| #define | USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_SHIFT (20U) |
| #define | USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD(x) |
| #define | USBPHY_CTRL_SET_ENDPDMCHG_WKUP_MASK (0x200000U) |
| #define | USBPHY_CTRL_SET_ENDPDMCHG_WKUP_SHIFT (21U) |
| #define | USBPHY_CTRL_SET_ENDPDMCHG_WKUP(x) |
| #define | USBPHY_CTRL_SET_ENIDCHG_WKUP_MASK (0x400000U) |
| #define | USBPHY_CTRL_SET_ENIDCHG_WKUP_SHIFT (22U) |
| #define | USBPHY_CTRL_SET_ENIDCHG_WKUP(x) |
| #define | USBPHY_CTRL_SET_ENVBUSCHG_WKUP_MASK (0x800000U) |
| #define | USBPHY_CTRL_SET_ENVBUSCHG_WKUP_SHIFT (23U) |
| #define | USBPHY_CTRL_SET_ENVBUSCHG_WKUP(x) |
| #define | USBPHY_CTRL_SET_FSDLL_RST_EN_MASK (0x1000000U) |
| #define | USBPHY_CTRL_SET_FSDLL_RST_EN_SHIFT (24U) |
| #define | USBPHY_CTRL_SET_FSDLL_RST_EN(x) |
| #define | USBPHY_CTRL_SET_OTG_ID_VALUE_MASK (0x8000000U) |
| #define | USBPHY_CTRL_SET_OTG_ID_VALUE_SHIFT (27U) |
| #define | USBPHY_CTRL_SET_OTG_ID_VALUE(x) |
| #define | USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_MASK (0x10000000U) |
| #define | USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_SHIFT (28U) |
| #define | USBPHY_CTRL_SET_HOST_FORCE_LS_SE0(x) |
| #define | USBPHY_CTRL_SET_UTMI_SUSPENDM_MASK (0x20000000U) |
| #define | USBPHY_CTRL_SET_UTMI_SUSPENDM_SHIFT (29U) |
| #define | USBPHY_CTRL_SET_UTMI_SUSPENDM(x) |
| #define | USBPHY_CTRL_SET_CLKGATE_MASK (0x40000000U) |
| #define | USBPHY_CTRL_SET_CLKGATE_SHIFT (30U) |
| #define | USBPHY_CTRL_SET_CLKGATE(x) |
| #define | USBPHY_CTRL_SET_SFTRST_MASK (0x80000000U) |
| #define | USBPHY_CTRL_SET_SFTRST_SHIFT (31U) |
| #define | USBPHY_CTRL_SET_SFTRST(x) |
| #define | USBPHY_CTRL_SET_AUTORESUME_EN_MASK (0x40000U) |
| #define | USBPHY_CTRL_SET_AUTORESUME_EN_SHIFT (18U) |
| #define | USBPHY_CTRL_SET_AUTORESUME_EN(x) |
| #define | USBPHY_CTRL_SET_DATA_ON_LRADC_MASK (0x2000U) |
| #define | USBPHY_CTRL_SET_DATA_ON_LRADC_SHIFT (13U) |
| #define | USBPHY_CTRL_SET_DATA_ON_LRADC(x) |
| #define | USBPHY_CTRL_SET_ENAUTO_PWRON_PLL_MASK (0x40000U) |
| #define | USBPHY_CTRL_SET_ENAUTO_PWRON_PLL_SHIFT (18U) |
| #define | USBPHY_CTRL_SET_ENAUTO_PWRON_PLL(x) |
| #define | USBPHY_CTRL_SET_RSVD1_MASK (0x6000000U) |
| #define | USBPHY_CTRL_SET_RSVD1_SHIFT (25U) |
| #define | USBPHY_CTRL_SET_RSVD1(x) |
CTRL_CLR - USB PHY General Control Register | |
| #define | USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_MASK (0x1U) |
| #define | USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_SHIFT (0U) |
| #define | USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ(x) |
| #define | USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_MASK (0x2U) |
| #define | USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_SHIFT (1U) |
| #define | USBPHY_CTRL_CLR_ENHOSTDISCONDETECT(x) |
| #define | USBPHY_CTRL_CLR_ENIRQHOSTDISCON_MASK (0x4U) |
| #define | USBPHY_CTRL_CLR_ENIRQHOSTDISCON_SHIFT (2U) |
| #define | USBPHY_CTRL_CLR_ENIRQHOSTDISCON(x) |
| #define | USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_MASK (0x8U) |
| #define | USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_SHIFT (3U) |
| #define | USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ(x) |
| #define | USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_MASK (0x10U) |
| #define | USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_SHIFT (4U) |
| #define | USBPHY_CTRL_CLR_ENDEVPLUGINDETECT(x) |
| #define | USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_MASK (0x20U) |
| #define | USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_SHIFT (5U) |
| #define | USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY(x) |
| #define | USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_MASK (0x40U) |
| #define | USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_SHIFT (6U) |
| #define | USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ(x) |
| #define | USBPHY_CTRL_CLR_ENOTGIDDETECT_MASK (0x80U) |
| #define | USBPHY_CTRL_CLR_ENOTGIDDETECT_SHIFT (7U) |
| #define | USBPHY_CTRL_CLR_ENOTGIDDETECT(x) |
| #define | USBPHY_CTRL_CLR_RESUMEIRQSTICKY_MASK (0x100U) |
| #define | USBPHY_CTRL_CLR_RESUMEIRQSTICKY_SHIFT (8U) |
| #define | USBPHY_CTRL_CLR_RESUMEIRQSTICKY(x) |
| #define | USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_MASK (0x200U) |
| #define | USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_SHIFT (9U) |
| #define | USBPHY_CTRL_CLR_ENIRQRESUMEDETECT(x) |
| #define | USBPHY_CTRL_CLR_RESUME_IRQ_MASK (0x400U) |
| #define | USBPHY_CTRL_CLR_RESUME_IRQ_SHIFT (10U) |
| #define | USBPHY_CTRL_CLR_RESUME_IRQ(x) |
| #define | USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_MASK (0x800U) |
| #define | USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_SHIFT (11U) |
| #define | USBPHY_CTRL_CLR_ENIRQDEVPLUGIN(x) |
| #define | USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_MASK (0x1000U) |
| #define | USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_SHIFT (12U) |
| #define | USBPHY_CTRL_CLR_DEVPLUGIN_IRQ(x) |
| #define | USBPHY_CTRL_CLR_ENUTMILEVEL2_MASK (0x4000U) |
| #define | USBPHY_CTRL_CLR_ENUTMILEVEL2_SHIFT (14U) |
| #define | USBPHY_CTRL_CLR_ENUTMILEVEL2(x) |
| #define | USBPHY_CTRL_CLR_ENUTMILEVEL3_MASK (0x8000U) |
| #define | USBPHY_CTRL_CLR_ENUTMILEVEL3_SHIFT (15U) |
| #define | USBPHY_CTRL_CLR_ENUTMILEVEL3(x) |
| #define | USBPHY_CTRL_CLR_ENIRQWAKEUP_MASK (0x10000U) |
| #define | USBPHY_CTRL_CLR_ENIRQWAKEUP_SHIFT (16U) |
| #define | USBPHY_CTRL_CLR_ENIRQWAKEUP(x) |
| #define | USBPHY_CTRL_CLR_WAKEUP_IRQ_MASK (0x20000U) |
| #define | USBPHY_CTRL_CLR_WAKEUP_IRQ_SHIFT (17U) |
| #define | USBPHY_CTRL_CLR_WAKEUP_IRQ(x) |
| #define | USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_MASK (0x80000U) |
| #define | USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_SHIFT (19U) |
| #define | USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE(x) |
| #define | USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_MASK (0x100000U) |
| #define | USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_SHIFT (20U) |
| #define | USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD(x) |
| #define | USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_MASK (0x200000U) |
| #define | USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_SHIFT (21U) |
| #define | USBPHY_CTRL_CLR_ENDPDMCHG_WKUP(x) |
| #define | USBPHY_CTRL_CLR_ENIDCHG_WKUP_MASK (0x400000U) |
| #define | USBPHY_CTRL_CLR_ENIDCHG_WKUP_SHIFT (22U) |
| #define | USBPHY_CTRL_CLR_ENIDCHG_WKUP(x) |
| #define | USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_MASK (0x800000U) |
| #define | USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_SHIFT (23U) |
| #define | USBPHY_CTRL_CLR_ENVBUSCHG_WKUP(x) |
| #define | USBPHY_CTRL_CLR_FSDLL_RST_EN_MASK (0x1000000U) |
| #define | USBPHY_CTRL_CLR_FSDLL_RST_EN_SHIFT (24U) |
| #define | USBPHY_CTRL_CLR_FSDLL_RST_EN(x) |
| #define | USBPHY_CTRL_CLR_OTG_ID_VALUE_MASK (0x8000000U) |
| #define | USBPHY_CTRL_CLR_OTG_ID_VALUE_SHIFT (27U) |
| #define | USBPHY_CTRL_CLR_OTG_ID_VALUE(x) |
| #define | USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_MASK (0x10000000U) |
| #define | USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_SHIFT (28U) |
| #define | USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0(x) |
| #define | USBPHY_CTRL_CLR_UTMI_SUSPENDM_MASK (0x20000000U) |
| #define | USBPHY_CTRL_CLR_UTMI_SUSPENDM_SHIFT (29U) |
| #define | USBPHY_CTRL_CLR_UTMI_SUSPENDM(x) |
| #define | USBPHY_CTRL_CLR_CLKGATE_MASK (0x40000000U) |
| #define | USBPHY_CTRL_CLR_CLKGATE_SHIFT (30U) |
| #define | USBPHY_CTRL_CLR_CLKGATE(x) |
| #define | USBPHY_CTRL_CLR_SFTRST_MASK (0x80000000U) |
| #define | USBPHY_CTRL_CLR_SFTRST_SHIFT (31U) |
| #define | USBPHY_CTRL_CLR_SFTRST(x) |
| #define | USBPHY_CTRL_CLR_AUTORESUME_EN_MASK (0x40000U) |
| #define | USBPHY_CTRL_CLR_AUTORESUME_EN_SHIFT (18U) |
| #define | USBPHY_CTRL_CLR_AUTORESUME_EN(x) |
| #define | USBPHY_CTRL_CLR_DATA_ON_LRADC_MASK (0x2000U) |
| #define | USBPHY_CTRL_CLR_DATA_ON_LRADC_SHIFT (13U) |
| #define | USBPHY_CTRL_CLR_DATA_ON_LRADC(x) |
| #define | USBPHY_CTRL_CLR_ENAUTO_PWRON_PLL_MASK (0x40000U) |
| #define | USBPHY_CTRL_CLR_ENAUTO_PWRON_PLL_SHIFT (18U) |
| #define | USBPHY_CTRL_CLR_ENAUTO_PWRON_PLL(x) |
| #define | USBPHY_CTRL_CLR_RSVD1_MASK (0x6000000U) |
| #define | USBPHY_CTRL_CLR_RSVD1_SHIFT (25U) |
| #define | USBPHY_CTRL_CLR_RSVD1(x) |
CTRL_TOG - USB PHY General Control Register | |
| #define | USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_MASK (0x1U) |
| #define | USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_SHIFT (0U) |
| #define | USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ(x) |
| #define | USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_MASK (0x2U) |
| #define | USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_SHIFT (1U) |
| #define | USBPHY_CTRL_TOG_ENHOSTDISCONDETECT(x) |
| #define | USBPHY_CTRL_TOG_ENIRQHOSTDISCON_MASK (0x4U) |
| #define | USBPHY_CTRL_TOG_ENIRQHOSTDISCON_SHIFT (2U) |
| #define | USBPHY_CTRL_TOG_ENIRQHOSTDISCON(x) |
| #define | USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_MASK (0x8U) |
| #define | USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_SHIFT (3U) |
| #define | USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ(x) |
| #define | USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_MASK (0x10U) |
| #define | USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_SHIFT (4U) |
| #define | USBPHY_CTRL_TOG_ENDEVPLUGINDETECT(x) |
| #define | USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_MASK (0x20U) |
| #define | USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_SHIFT (5U) |
| #define | USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY(x) |
| #define | USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_MASK (0x40U) |
| #define | USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_SHIFT (6U) |
| #define | USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ(x) |
| #define | USBPHY_CTRL_TOG_ENOTGIDDETECT_MASK (0x80U) |
| #define | USBPHY_CTRL_TOG_ENOTGIDDETECT_SHIFT (7U) |
| #define | USBPHY_CTRL_TOG_ENOTGIDDETECT(x) |
| #define | USBPHY_CTRL_TOG_RESUMEIRQSTICKY_MASK (0x100U) |
| #define | USBPHY_CTRL_TOG_RESUMEIRQSTICKY_SHIFT (8U) |
| #define | USBPHY_CTRL_TOG_RESUMEIRQSTICKY(x) |
| #define | USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_MASK (0x200U) |
| #define | USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_SHIFT (9U) |
| #define | USBPHY_CTRL_TOG_ENIRQRESUMEDETECT(x) |
| #define | USBPHY_CTRL_TOG_RESUME_IRQ_MASK (0x400U) |
| #define | USBPHY_CTRL_TOG_RESUME_IRQ_SHIFT (10U) |
| #define | USBPHY_CTRL_TOG_RESUME_IRQ(x) |
| #define | USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_MASK (0x800U) |
| #define | USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_SHIFT (11U) |
| #define | USBPHY_CTRL_TOG_ENIRQDEVPLUGIN(x) |
| #define | USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_MASK (0x1000U) |
| #define | USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_SHIFT (12U) |
| #define | USBPHY_CTRL_TOG_DEVPLUGIN_IRQ(x) |
| #define | USBPHY_CTRL_TOG_ENUTMILEVEL2_MASK (0x4000U) |
| #define | USBPHY_CTRL_TOG_ENUTMILEVEL2_SHIFT (14U) |
| #define | USBPHY_CTRL_TOG_ENUTMILEVEL2(x) |
| #define | USBPHY_CTRL_TOG_ENUTMILEVEL3_MASK (0x8000U) |
| #define | USBPHY_CTRL_TOG_ENUTMILEVEL3_SHIFT (15U) |
| #define | USBPHY_CTRL_TOG_ENUTMILEVEL3(x) |
| #define | USBPHY_CTRL_TOG_ENIRQWAKEUP_MASK (0x10000U) |
| #define | USBPHY_CTRL_TOG_ENIRQWAKEUP_SHIFT (16U) |
| #define | USBPHY_CTRL_TOG_ENIRQWAKEUP(x) |
| #define | USBPHY_CTRL_TOG_WAKEUP_IRQ_MASK (0x20000U) |
| #define | USBPHY_CTRL_TOG_WAKEUP_IRQ_SHIFT (17U) |
| #define | USBPHY_CTRL_TOG_WAKEUP_IRQ(x) |
| #define | USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_MASK (0x80000U) |
| #define | USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_SHIFT (19U) |
| #define | USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE(x) |
| #define | USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_MASK (0x100000U) |
| #define | USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_SHIFT (20U) |
| #define | USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD(x) |
| #define | USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_MASK (0x200000U) |
| #define | USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_SHIFT (21U) |
| #define | USBPHY_CTRL_TOG_ENDPDMCHG_WKUP(x) |
| #define | USBPHY_CTRL_TOG_ENIDCHG_WKUP_MASK (0x400000U) |
| #define | USBPHY_CTRL_TOG_ENIDCHG_WKUP_SHIFT (22U) |
| #define | USBPHY_CTRL_TOG_ENIDCHG_WKUP(x) |
| #define | USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_MASK (0x800000U) |
| #define | USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_SHIFT (23U) |
| #define | USBPHY_CTRL_TOG_ENVBUSCHG_WKUP(x) |
| #define | USBPHY_CTRL_TOG_FSDLL_RST_EN_MASK (0x1000000U) |
| #define | USBPHY_CTRL_TOG_FSDLL_RST_EN_SHIFT (24U) |
| #define | USBPHY_CTRL_TOG_FSDLL_RST_EN(x) |
| #define | USBPHY_CTRL_TOG_OTG_ID_VALUE_MASK (0x8000000U) |
| #define | USBPHY_CTRL_TOG_OTG_ID_VALUE_SHIFT (27U) |
| #define | USBPHY_CTRL_TOG_OTG_ID_VALUE(x) |
| #define | USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_MASK (0x10000000U) |
| #define | USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_SHIFT (28U) |
| #define | USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0(x) |
| #define | USBPHY_CTRL_TOG_UTMI_SUSPENDM_MASK (0x20000000U) |
| #define | USBPHY_CTRL_TOG_UTMI_SUSPENDM_SHIFT (29U) |
| #define | USBPHY_CTRL_TOG_UTMI_SUSPENDM(x) |
| #define | USBPHY_CTRL_TOG_CLKGATE_MASK (0x40000000U) |
| #define | USBPHY_CTRL_TOG_CLKGATE_SHIFT (30U) |
| #define | USBPHY_CTRL_TOG_CLKGATE(x) |
| #define | USBPHY_CTRL_TOG_SFTRST_MASK (0x80000000U) |
| #define | USBPHY_CTRL_TOG_SFTRST_SHIFT (31U) |
| #define | USBPHY_CTRL_TOG_SFTRST(x) |
| #define | USBPHY_CTRL_TOG_AUTORESUME_EN_MASK (0x40000U) |
| #define | USBPHY_CTRL_TOG_AUTORESUME_EN_SHIFT (18U) |
| #define | USBPHY_CTRL_TOG_AUTORESUME_EN(x) |
| #define | USBPHY_CTRL_TOG_DATA_ON_LRADC_MASK (0x2000U) |
| #define | USBPHY_CTRL_TOG_DATA_ON_LRADC_SHIFT (13U) |
| #define | USBPHY_CTRL_TOG_DATA_ON_LRADC(x) |
| #define | USBPHY_CTRL_TOG_ENAUTO_PWRON_PLL_MASK (0x40000U) |
| #define | USBPHY_CTRL_TOG_ENAUTO_PWRON_PLL_SHIFT (18U) |
| #define | USBPHY_CTRL_TOG_ENAUTO_PWRON_PLL(x) |
| #define | USBPHY_CTRL_TOG_RSVD1_MASK (0x6000000U) |
| #define | USBPHY_CTRL_TOG_RSVD1_SHIFT (25U) |
| #define | USBPHY_CTRL_TOG_RSVD1(x) |
STATUS - USB PHY Status Register | |
| #define | USBPHY_STATUS_RSVD0_MASK (0x7U) |
| #define | USBPHY_STATUS_RSVD0_SHIFT (0U) |
| #define | USBPHY_STATUS_RSVD0(x) |
| #define | USBPHY_STATUS_RSVD1_MASK (0x30U) |
| #define | USBPHY_STATUS_RSVD1_SHIFT (4U) |
| #define | USBPHY_STATUS_RSVD1(x) |
| #define | USBPHY_STATUS_RSVD2_MASK (0x80U) |
| #define | USBPHY_STATUS_RSVD2_SHIFT (7U) |
| #define | USBPHY_STATUS_RSVD2(x) |
| #define | USBPHY_STATUS_RSVD3_MASK (0x200U) |
| #define | USBPHY_STATUS_RSVD3_SHIFT (9U) |
| #define | USBPHY_STATUS_RSVD3(x) |
| #define | USBPHY_STATUS_RSVD4_MASK (0xFFFFF800U) |
| #define | USBPHY_STATUS_RSVD4_SHIFT (11U) |
| #define | USBPHY_STATUS_RSVD4(x) |
| #define | USBPHY_STATUS_HOSTDISCONDETECT_STATUS_MASK (0x8U) |
| #define | USBPHY_STATUS_HOSTDISCONDETECT_STATUS_SHIFT (3U) |
| #define | USBPHY_STATUS_HOSTDISCONDETECT_STATUS(x) |
| #define | USBPHY_STATUS_DEVPLUGIN_STATUS_MASK (0x40U) |
| #define | USBPHY_STATUS_DEVPLUGIN_STATUS_SHIFT (6U) |
| #define | USBPHY_STATUS_DEVPLUGIN_STATUS(x) |
| #define | USBPHY_STATUS_OTGID_STATUS_MASK (0x100U) |
| #define | USBPHY_STATUS_OTGID_STATUS_SHIFT (8U) |
| #define | USBPHY_STATUS_OTGID_STATUS(x) |
| #define | USBPHY_STATUS_RESUME_STATUS_MASK (0x400U) |
| #define | USBPHY_STATUS_RESUME_STATUS_SHIFT (10U) |
| #define | USBPHY_STATUS_RESUME_STATUS(x) |
DEBUG - USB PHY Debug Register | |
| #define | USBPHY_DEBUG_OTGIDPIOLOCK_MASK (0x1U) |
| #define | USBPHY_DEBUG_OTGIDPIOLOCK_SHIFT (0U) |
| #define | USBPHY_DEBUG_OTGIDPIOLOCK(x) |
| #define | USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_MASK (0x2U) |
| #define | USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_SHIFT (1U) |
| #define | USBPHY_DEBUG_DEBUG_INTERFACE_HOLD(x) |
| #define | USBPHY_DEBUG_HSTPULLDOWN_MASK (0xCU) |
| #define | USBPHY_DEBUG_HSTPULLDOWN_SHIFT (2U) |
| #define | USBPHY_DEBUG_HSTPULLDOWN(x) |
| #define | USBPHY_DEBUG_ENHSTPULLDOWN_MASK (0x30U) |
| #define | USBPHY_DEBUG_ENHSTPULLDOWN_SHIFT (4U) |
| #define | USBPHY_DEBUG_ENHSTPULLDOWN(x) |
| #define | USBPHY_DEBUG_TX2RXCOUNT_MASK (0xF00U) |
| #define | USBPHY_DEBUG_TX2RXCOUNT_SHIFT (8U) |
| #define | USBPHY_DEBUG_TX2RXCOUNT(x) |
| #define | USBPHY_DEBUG_ENTX2RXCOUNT_MASK (0x1000U) |
| #define | USBPHY_DEBUG_ENTX2RXCOUNT_SHIFT (12U) |
| #define | USBPHY_DEBUG_ENTX2RXCOUNT(x) |
| #define | USBPHY_DEBUG_SQUELCHRESETCOUNT_MASK (0x1F0000U) |
| #define | USBPHY_DEBUG_SQUELCHRESETCOUNT_SHIFT (16U) |
| #define | USBPHY_DEBUG_SQUELCHRESETCOUNT(x) |
| #define | USBPHY_DEBUG_ENSQUELCHRESET_MASK (0x1000000U) |
| #define | USBPHY_DEBUG_ENSQUELCHRESET_SHIFT (24U) |
| #define | USBPHY_DEBUG_ENSQUELCHRESET(x) |
| #define | USBPHY_DEBUG_SQUELCHRESETLENGTH_MASK (0x1E000000U) |
| #define | USBPHY_DEBUG_SQUELCHRESETLENGTH_SHIFT (25U) |
| #define | USBPHY_DEBUG_SQUELCHRESETLENGTH(x) |
| #define | USBPHY_DEBUG_HOST_RESUME_DEBUG_MASK (0x20000000U) |
| #define | USBPHY_DEBUG_HOST_RESUME_DEBUG_SHIFT (29U) |
| #define | USBPHY_DEBUG_HOST_RESUME_DEBUG(x) |
| #define | USBPHY_DEBUG_CLKGATE_MASK (0x40000000U) |
| #define | USBPHY_DEBUG_CLKGATE_SHIFT (30U) |
| #define | USBPHY_DEBUG_CLKGATE(x) |
| #define | USBPHY_DEBUG_RSVD0_MASK (0xC0U) |
| #define | USBPHY_DEBUG_RSVD0_SHIFT (6U) |
| #define | USBPHY_DEBUG_RSVD0(x) |
| #define | USBPHY_DEBUG_RSVD1_MASK (0xE000U) |
| #define | USBPHY_DEBUG_RSVD1_SHIFT (13U) |
| #define | USBPHY_DEBUG_RSVD1(x) |
| #define | USBPHY_DEBUG_RSVD2_MASK (0xE00000U) |
| #define | USBPHY_DEBUG_RSVD2_SHIFT (21U) |
| #define | USBPHY_DEBUG_RSVD2(x) |
| #define | USBPHY_DEBUG_RSVD3_MASK (0x80000000U) |
| #define | USBPHY_DEBUG_RSVD3_SHIFT (31U) |
| #define | USBPHY_DEBUG_RSVD3(x) |
DEBUG_SET - USB PHY Debug Register | |
| #define | USBPHY_DEBUG_SET_OTGIDPIOLOCK_MASK (0x1U) |
| #define | USBPHY_DEBUG_SET_OTGIDPIOLOCK_SHIFT (0U) |
| #define | USBPHY_DEBUG_SET_OTGIDPIOLOCK(x) |
| #define | USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_MASK (0x2U) |
| #define | USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_SHIFT (1U) |
| #define | USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD(x) |
| #define | USBPHY_DEBUG_SET_HSTPULLDOWN_MASK (0xCU) |
| #define | USBPHY_DEBUG_SET_HSTPULLDOWN_SHIFT (2U) |
| #define | USBPHY_DEBUG_SET_HSTPULLDOWN(x) |
| #define | USBPHY_DEBUG_SET_ENHSTPULLDOWN_MASK (0x30U) |
| #define | USBPHY_DEBUG_SET_ENHSTPULLDOWN_SHIFT (4U) |
| #define | USBPHY_DEBUG_SET_ENHSTPULLDOWN(x) |
| #define | USBPHY_DEBUG_SET_TX2RXCOUNT_MASK (0xF00U) |
| #define | USBPHY_DEBUG_SET_TX2RXCOUNT_SHIFT (8U) |
| #define | USBPHY_DEBUG_SET_TX2RXCOUNT(x) |
| #define | USBPHY_DEBUG_SET_ENTX2RXCOUNT_MASK (0x1000U) |
| #define | USBPHY_DEBUG_SET_ENTX2RXCOUNT_SHIFT (12U) |
| #define | USBPHY_DEBUG_SET_ENTX2RXCOUNT(x) |
| #define | USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_MASK (0x1F0000U) |
| #define | USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_SHIFT (16U) |
| #define | USBPHY_DEBUG_SET_SQUELCHRESETCOUNT(x) |
| #define | USBPHY_DEBUG_SET_ENSQUELCHRESET_MASK (0x1000000U) |
| #define | USBPHY_DEBUG_SET_ENSQUELCHRESET_SHIFT (24U) |
| #define | USBPHY_DEBUG_SET_ENSQUELCHRESET(x) |
| #define | USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_MASK (0x1E000000U) |
| #define | USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_SHIFT (25U) |
| #define | USBPHY_DEBUG_SET_SQUELCHRESETLENGTH(x) |
| #define | USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_MASK (0x20000000U) |
| #define | USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_SHIFT (29U) |
| #define | USBPHY_DEBUG_SET_HOST_RESUME_DEBUG(x) |
| #define | USBPHY_DEBUG_SET_CLKGATE_MASK (0x40000000U) |
| #define | USBPHY_DEBUG_SET_CLKGATE_SHIFT (30U) |
| #define | USBPHY_DEBUG_SET_CLKGATE(x) |
| #define | USBPHY_DEBUG_SET_RSVD0_MASK (0xC0U) |
| #define | USBPHY_DEBUG_SET_RSVD0_SHIFT (6U) |
| #define | USBPHY_DEBUG_SET_RSVD0(x) |
| #define | USBPHY_DEBUG_SET_RSVD1_MASK (0xE000U) |
| #define | USBPHY_DEBUG_SET_RSVD1_SHIFT (13U) |
| #define | USBPHY_DEBUG_SET_RSVD1(x) |
| #define | USBPHY_DEBUG_SET_RSVD2_MASK (0xE00000U) |
| #define | USBPHY_DEBUG_SET_RSVD2_SHIFT (21U) |
| #define | USBPHY_DEBUG_SET_RSVD2(x) |
| #define | USBPHY_DEBUG_SET_RSVD3_MASK (0x80000000U) |
| #define | USBPHY_DEBUG_SET_RSVD3_SHIFT (31U) |
| #define | USBPHY_DEBUG_SET_RSVD3(x) |
DEBUG_CLR - USB PHY Debug Register | |
| #define | USBPHY_DEBUG_CLR_OTGIDPIOLOCK_MASK (0x1U) |
| #define | USBPHY_DEBUG_CLR_OTGIDPIOLOCK_SHIFT (0U) |
| #define | USBPHY_DEBUG_CLR_OTGIDPIOLOCK(x) |
| #define | USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_MASK (0x2U) |
| #define | USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_SHIFT (1U) |
| #define | USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD(x) |
| #define | USBPHY_DEBUG_CLR_HSTPULLDOWN_MASK (0xCU) |
| #define | USBPHY_DEBUG_CLR_HSTPULLDOWN_SHIFT (2U) |
| #define | USBPHY_DEBUG_CLR_HSTPULLDOWN(x) |
| #define | USBPHY_DEBUG_CLR_ENHSTPULLDOWN_MASK (0x30U) |
| #define | USBPHY_DEBUG_CLR_ENHSTPULLDOWN_SHIFT (4U) |
| #define | USBPHY_DEBUG_CLR_ENHSTPULLDOWN(x) |
| #define | USBPHY_DEBUG_CLR_TX2RXCOUNT_MASK (0xF00U) |
| #define | USBPHY_DEBUG_CLR_TX2RXCOUNT_SHIFT (8U) |
| #define | USBPHY_DEBUG_CLR_TX2RXCOUNT(x) |
| #define | USBPHY_DEBUG_CLR_ENTX2RXCOUNT_MASK (0x1000U) |
| #define | USBPHY_DEBUG_CLR_ENTX2RXCOUNT_SHIFT (12U) |
| #define | USBPHY_DEBUG_CLR_ENTX2RXCOUNT(x) |
| #define | USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_MASK (0x1F0000U) |
| #define | USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_SHIFT (16U) |
| #define | USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT(x) |
| #define | USBPHY_DEBUG_CLR_ENSQUELCHRESET_MASK (0x1000000U) |
| #define | USBPHY_DEBUG_CLR_ENSQUELCHRESET_SHIFT (24U) |
| #define | USBPHY_DEBUG_CLR_ENSQUELCHRESET(x) |
| #define | USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_MASK (0x1E000000U) |
| #define | USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_SHIFT (25U) |
| #define | USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH(x) |
| #define | USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_MASK (0x20000000U) |
| #define | USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_SHIFT (29U) |
| #define | USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG(x) |
| #define | USBPHY_DEBUG_CLR_CLKGATE_MASK (0x40000000U) |
| #define | USBPHY_DEBUG_CLR_CLKGATE_SHIFT (30U) |
| #define | USBPHY_DEBUG_CLR_CLKGATE(x) |
| #define | USBPHY_DEBUG_CLR_RSVD0_MASK (0xC0U) |
| #define | USBPHY_DEBUG_CLR_RSVD0_SHIFT (6U) |
| #define | USBPHY_DEBUG_CLR_RSVD0(x) |
| #define | USBPHY_DEBUG_CLR_RSVD1_MASK (0xE000U) |
| #define | USBPHY_DEBUG_CLR_RSVD1_SHIFT (13U) |
| #define | USBPHY_DEBUG_CLR_RSVD1(x) |
| #define | USBPHY_DEBUG_CLR_RSVD2_MASK (0xE00000U) |
| #define | USBPHY_DEBUG_CLR_RSVD2_SHIFT (21U) |
| #define | USBPHY_DEBUG_CLR_RSVD2(x) |
| #define | USBPHY_DEBUG_CLR_RSVD3_MASK (0x80000000U) |
| #define | USBPHY_DEBUG_CLR_RSVD3_SHIFT (31U) |
| #define | USBPHY_DEBUG_CLR_RSVD3(x) |
DEBUG_TOG - USB PHY Debug Register | |
| #define | USBPHY_DEBUG_TOG_OTGIDPIOLOCK_MASK (0x1U) |
| #define | USBPHY_DEBUG_TOG_OTGIDPIOLOCK_SHIFT (0U) |
| #define | USBPHY_DEBUG_TOG_OTGIDPIOLOCK(x) |
| #define | USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_MASK (0x2U) |
| #define | USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_SHIFT (1U) |
| #define | USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD(x) |
| #define | USBPHY_DEBUG_TOG_HSTPULLDOWN_MASK (0xCU) |
| #define | USBPHY_DEBUG_TOG_HSTPULLDOWN_SHIFT (2U) |
| #define | USBPHY_DEBUG_TOG_HSTPULLDOWN(x) |
| #define | USBPHY_DEBUG_TOG_ENHSTPULLDOWN_MASK (0x30U) |
| #define | USBPHY_DEBUG_TOG_ENHSTPULLDOWN_SHIFT (4U) |
| #define | USBPHY_DEBUG_TOG_ENHSTPULLDOWN(x) |
| #define | USBPHY_DEBUG_TOG_TX2RXCOUNT_MASK (0xF00U) |
| #define | USBPHY_DEBUG_TOG_TX2RXCOUNT_SHIFT (8U) |
| #define | USBPHY_DEBUG_TOG_TX2RXCOUNT(x) |
| #define | USBPHY_DEBUG_TOG_ENTX2RXCOUNT_MASK (0x1000U) |
| #define | USBPHY_DEBUG_TOG_ENTX2RXCOUNT_SHIFT (12U) |
| #define | USBPHY_DEBUG_TOG_ENTX2RXCOUNT(x) |
| #define | USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_MASK (0x1F0000U) |
| #define | USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_SHIFT (16U) |
| #define | USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT(x) |
| #define | USBPHY_DEBUG_TOG_ENSQUELCHRESET_MASK (0x1000000U) |
| #define | USBPHY_DEBUG_TOG_ENSQUELCHRESET_SHIFT (24U) |
| #define | USBPHY_DEBUG_TOG_ENSQUELCHRESET(x) |
| #define | USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_MASK (0x1E000000U) |
| #define | USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_SHIFT (25U) |
| #define | USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH(x) |
| #define | USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_MASK (0x20000000U) |
| #define | USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_SHIFT (29U) |
| #define | USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG(x) |
| #define | USBPHY_DEBUG_TOG_CLKGATE_MASK (0x40000000U) |
| #define | USBPHY_DEBUG_TOG_CLKGATE_SHIFT (30U) |
| #define | USBPHY_DEBUG_TOG_CLKGATE(x) |
| #define | USBPHY_DEBUG_TOG_RSVD0_MASK (0xC0U) |
| #define | USBPHY_DEBUG_TOG_RSVD0_SHIFT (6U) |
| #define | USBPHY_DEBUG_TOG_RSVD0(x) |
| #define | USBPHY_DEBUG_TOG_RSVD1_MASK (0xE000U) |
| #define | USBPHY_DEBUG_TOG_RSVD1_SHIFT (13U) |
| #define | USBPHY_DEBUG_TOG_RSVD1(x) |
| #define | USBPHY_DEBUG_TOG_RSVD2_MASK (0xE00000U) |
| #define | USBPHY_DEBUG_TOG_RSVD2_SHIFT (21U) |
| #define | USBPHY_DEBUG_TOG_RSVD2(x) |
| #define | USBPHY_DEBUG_TOG_RSVD3_MASK (0x80000000U) |
| #define | USBPHY_DEBUG_TOG_RSVD3_SHIFT (31U) |
| #define | USBPHY_DEBUG_TOG_RSVD3(x) |
DEBUG0_STATUS - UTMI Debug Status Register 0 | |
| #define | USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_MASK (0xFFFFU) |
| #define | USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_SHIFT (0U) |
| #define | USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT(x) |
| #define | USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_MASK (0x3FF0000U) |
| #define | USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_SHIFT (16U) |
| #define | USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT(x) |
| #define | USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_MASK (0xFC000000U) |
| #define | USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_SHIFT (26U) |
| #define | USBPHY_DEBUG0_STATUS_SQUELCH_COUNT(x) |
DEBUG1 - UTMI Debug Status Register 1 | |
| #define | USBPHY_DEBUG1_RSVD0_MASK (0x1FFFU) |
| #define | USBPHY_DEBUG1_RSVD0_SHIFT (0U) |
| #define | USBPHY_DEBUG1_RSVD0(x) |
| #define | USBPHY_DEBUG1_RSVD1_MASK (0xFFFF8000U) |
| #define | USBPHY_DEBUG1_RSVD1_SHIFT (15U) |
| #define | USBPHY_DEBUG1_RSVD1(x) |
| #define | USBPHY_DEBUG1_ENTAILADJVD_MASK (0x6000U) |
| #define | USBPHY_DEBUG1_ENTAILADJVD_SHIFT (13U) |
| #define | USBPHY_DEBUG1_ENTAILADJVD(x) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_MASK (0x8000U) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_SHIFT (15U) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF(x) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_MASK (0x10000U) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_SHIFT (16U) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP(x) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_MASK (0x20000U) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_SHIFT (17U) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR(x) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_MASK (0x1C0000U) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_SHIFT (18U) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ(x) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_TST_MASK (0x600000U) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_TST_SHIFT (21U) |
| #define | USBPHY_DEBUG1_USB2_REFBIAS_TST(x) |
DEBUG1_SET - UTMI Debug Status Register 1 | |
| #define | USBPHY_DEBUG1_SET_RSVD0_MASK (0x1FFFU) |
| #define | USBPHY_DEBUG1_SET_RSVD0_SHIFT (0U) |
| #define | USBPHY_DEBUG1_SET_RSVD0(x) |
| #define | USBPHY_DEBUG1_SET_RSVD1_MASK (0xFFFF8000U) |
| #define | USBPHY_DEBUG1_SET_RSVD1_SHIFT (15U) |
| #define | USBPHY_DEBUG1_SET_RSVD1(x) |
| #define | USBPHY_DEBUG1_SET_ENTAILADJVD_MASK (0x6000U) |
| #define | USBPHY_DEBUG1_SET_ENTAILADJVD_SHIFT (13U) |
| #define | USBPHY_DEBUG1_SET_ENTAILADJVD(x) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_MASK (0x8000U) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_SHIFT (15U) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF(x) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_MASK (0x10000U) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_SHIFT (16U) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP(x) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_MASK (0x20000U) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_SHIFT (17U) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR(x) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_MASK (0x1C0000U) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_SHIFT (18U) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ(x) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_MASK (0x600000U) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_SHIFT (21U) |
| #define | USBPHY_DEBUG1_SET_USB2_REFBIAS_TST(x) |
DEBUG1_CLR - UTMI Debug Status Register 1 | |
| #define | USBPHY_DEBUG1_CLR_RSVD0_MASK (0x1FFFU) |
| #define | USBPHY_DEBUG1_CLR_RSVD0_SHIFT (0U) |
| #define | USBPHY_DEBUG1_CLR_RSVD0(x) |
| #define | USBPHY_DEBUG1_CLR_RSVD1_MASK (0xFFFF8000U) |
| #define | USBPHY_DEBUG1_CLR_RSVD1_SHIFT (15U) |
| #define | USBPHY_DEBUG1_CLR_RSVD1(x) |
| #define | USBPHY_DEBUG1_CLR_ENTAILADJVD_MASK (0x6000U) |
| #define | USBPHY_DEBUG1_CLR_ENTAILADJVD_SHIFT (13U) |
| #define | USBPHY_DEBUG1_CLR_ENTAILADJVD(x) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_MASK (0x8000U) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_SHIFT (15U) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF(x) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_MASK (0x10000U) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_SHIFT (16U) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP(x) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_MASK (0x20000U) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_SHIFT (17U) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR(x) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_MASK (0x1C0000U) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_SHIFT (18U) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ(x) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_MASK (0x600000U) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_SHIFT (21U) |
| #define | USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST(x) |
DEBUG1_TOG - UTMI Debug Status Register 1 | |
| #define | USBPHY_DEBUG1_TOG_RSVD0_MASK (0x1FFFU) |
| #define | USBPHY_DEBUG1_TOG_RSVD0_SHIFT (0U) |
| #define | USBPHY_DEBUG1_TOG_RSVD0(x) |
| #define | USBPHY_DEBUG1_TOG_RSVD1_MASK (0xFFFF8000U) |
| #define | USBPHY_DEBUG1_TOG_RSVD1_SHIFT (15U) |
| #define | USBPHY_DEBUG1_TOG_RSVD1(x) |
| #define | USBPHY_DEBUG1_TOG_ENTAILADJVD_MASK (0x6000U) |
| #define | USBPHY_DEBUG1_TOG_ENTAILADJVD_SHIFT (13U) |
| #define | USBPHY_DEBUG1_TOG_ENTAILADJVD(x) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_MASK (0x8000U) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_SHIFT (15U) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF(x) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_MASK (0x10000U) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_SHIFT (16U) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP(x) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_MASK (0x20000U) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_SHIFT (17U) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR(x) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_MASK (0x1C0000U) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_SHIFT (18U) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ(x) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_MASK (0x600000U) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_SHIFT (21U) |
| #define | USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST(x) |
VERSION - UTMI RTL Version | |
| #define | USBPHY_VERSION_STEP_MASK (0xFFFFU) |
| #define | USBPHY_VERSION_STEP_SHIFT (0U) |
| #define | USBPHY_VERSION_STEP(x) |
| #define | USBPHY_VERSION_MINOR_MASK (0xFF0000U) |
| #define | USBPHY_VERSION_MINOR_SHIFT (16U) |
| #define | USBPHY_VERSION_MINOR(x) |
| #define | USBPHY_VERSION_MAJOR_MASK (0xFF000000U) |
| #define | USBPHY_VERSION_MAJOR_SHIFT (24U) |
| #define | USBPHY_VERSION_MAJOR(x) |
PLL_SIC - USB PHY PLL Control/Status Register | |
| #define | USBPHY_PLL_SIC_PLL_POSTDIV_MASK (0x1CU) |
| #define | USBPHY_PLL_SIC_PLL_POSTDIV_SHIFT (2U) |
| #define | USBPHY_PLL_SIC_PLL_POSTDIV(x) |
| #define | USBPHY_PLL_SIC_PLL_EN_USB_CLKS_MASK (0x40U) |
| #define | USBPHY_PLL_SIC_PLL_EN_USB_CLKS_SHIFT (6U) |
| #define | USBPHY_PLL_SIC_PLL_EN_USB_CLKS(x) |
| #define | USBPHY_PLL_SIC_PLL_POWER_MASK (0x1000U) |
| #define | USBPHY_PLL_SIC_PLL_POWER_SHIFT (12U) |
| #define | USBPHY_PLL_SIC_PLL_POWER(x) |
| #define | USBPHY_PLL_SIC_PLL_ENABLE_MASK (0x2000U) |
| #define | USBPHY_PLL_SIC_PLL_ENABLE_SHIFT (13U) |
| #define | USBPHY_PLL_SIC_PLL_ENABLE(x) |
| #define | USBPHY_PLL_SIC_PLL_BYPASS_MASK (0x10000U) |
| #define | USBPHY_PLL_SIC_PLL_BYPASS_SHIFT (16U) |
| #define | USBPHY_PLL_SIC_PLL_BYPASS(x) |
| #define | USBPHY_PLL_SIC_REFBIAS_PWD_SEL_MASK (0x80000U) |
| #define | USBPHY_PLL_SIC_REFBIAS_PWD_SEL_SHIFT (19U) |
| #define | USBPHY_PLL_SIC_REFBIAS_PWD_SEL(x) |
| #define | USBPHY_PLL_SIC_REFBIAS_PWD_MASK (0x100000U) |
| #define | USBPHY_PLL_SIC_REFBIAS_PWD_SHIFT (20U) |
| #define | USBPHY_PLL_SIC_REFBIAS_PWD(x) |
| #define | USBPHY_PLL_SIC_PLL_REG_ENABLE_MASK (0x200000U) |
| #define | USBPHY_PLL_SIC_PLL_REG_ENABLE_SHIFT (21U) |
| #define | USBPHY_PLL_SIC_PLL_REG_ENABLE(x) |
| #define | USBPHY_PLL_SIC_PLL_DIV_SEL_MASK (0x1C00000U) |
| #define | USBPHY_PLL_SIC_PLL_DIV_SEL_SHIFT (22U) |
| #define | USBPHY_PLL_SIC_PLL_DIV_SEL(x) |
| #define | USBPHY_PLL_SIC_PLL_LOCK_MASK (0x80000000U) |
| #define | USBPHY_PLL_SIC_PLL_LOCK_SHIFT (31U) |
| #define | USBPHY_PLL_SIC_PLL_LOCK(x) |
PLL_SIC_SET - USB PHY PLL Control/Status Register | |
| #define | USBPHY_PLL_SIC_SET_PLL_POSTDIV_MASK (0x1CU) |
| #define | USBPHY_PLL_SIC_SET_PLL_POSTDIV_SHIFT (2U) |
| #define | USBPHY_PLL_SIC_SET_PLL_POSTDIV(x) |
| #define | USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_MASK (0x40U) |
| #define | USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_SHIFT (6U) |
| #define | USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS(x) |
| #define | USBPHY_PLL_SIC_SET_PLL_POWER_MASK (0x1000U) |
| #define | USBPHY_PLL_SIC_SET_PLL_POWER_SHIFT (12U) |
| #define | USBPHY_PLL_SIC_SET_PLL_POWER(x) |
| #define | USBPHY_PLL_SIC_SET_PLL_ENABLE_MASK (0x2000U) |
| #define | USBPHY_PLL_SIC_SET_PLL_ENABLE_SHIFT (13U) |
| #define | USBPHY_PLL_SIC_SET_PLL_ENABLE(x) |
| #define | USBPHY_PLL_SIC_SET_PLL_BYPASS_MASK (0x10000U) |
| #define | USBPHY_PLL_SIC_SET_PLL_BYPASS_SHIFT (16U) |
| #define | USBPHY_PLL_SIC_SET_PLL_BYPASS(x) |
| #define | USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_MASK (0x80000U) |
| #define | USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_SHIFT (19U) |
| #define | USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL(x) |
| #define | USBPHY_PLL_SIC_SET_REFBIAS_PWD_MASK (0x100000U) |
| #define | USBPHY_PLL_SIC_SET_REFBIAS_PWD_SHIFT (20U) |
| #define | USBPHY_PLL_SIC_SET_REFBIAS_PWD(x) |
| #define | USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_MASK (0x200000U) |
| #define | USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_SHIFT (21U) |
| #define | USBPHY_PLL_SIC_SET_PLL_REG_ENABLE(x) |
| #define | USBPHY_PLL_SIC_SET_PLL_DIV_SEL_MASK (0x1C00000U) |
| #define | USBPHY_PLL_SIC_SET_PLL_DIV_SEL_SHIFT (22U) |
| #define | USBPHY_PLL_SIC_SET_PLL_DIV_SEL(x) |
| #define | USBPHY_PLL_SIC_SET_PLL_LOCK_MASK (0x80000000U) |
| #define | USBPHY_PLL_SIC_SET_PLL_LOCK_SHIFT (31U) |
| #define | USBPHY_PLL_SIC_SET_PLL_LOCK(x) |
PLL_SIC_CLR - USB PHY PLL Control/Status Register | |
| #define | USBPHY_PLL_SIC_CLR_PLL_POSTDIV_MASK (0x1CU) |
| #define | USBPHY_PLL_SIC_CLR_PLL_POSTDIV_SHIFT (2U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_POSTDIV(x) |
| #define | USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_MASK (0x40U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_SHIFT (6U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS(x) |
| #define | USBPHY_PLL_SIC_CLR_PLL_POWER_MASK (0x1000U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_POWER_SHIFT (12U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_POWER(x) |
| #define | USBPHY_PLL_SIC_CLR_PLL_ENABLE_MASK (0x2000U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_ENABLE_SHIFT (13U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_ENABLE(x) |
| #define | USBPHY_PLL_SIC_CLR_PLL_BYPASS_MASK (0x10000U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_BYPASS_SHIFT (16U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_BYPASS(x) |
| #define | USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_MASK (0x80000U) |
| #define | USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_SHIFT (19U) |
| #define | USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL(x) |
| #define | USBPHY_PLL_SIC_CLR_REFBIAS_PWD_MASK (0x100000U) |
| #define | USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SHIFT (20U) |
| #define | USBPHY_PLL_SIC_CLR_REFBIAS_PWD(x) |
| #define | USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_MASK (0x200000U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_SHIFT (21U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE(x) |
| #define | USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_MASK (0x1C00000U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_SHIFT (22U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_DIV_SEL(x) |
| #define | USBPHY_PLL_SIC_CLR_PLL_LOCK_MASK (0x80000000U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_LOCK_SHIFT (31U) |
| #define | USBPHY_PLL_SIC_CLR_PLL_LOCK(x) |
PLL_SIC_TOG - USB PHY PLL Control/Status Register | |
| #define | USBPHY_PLL_SIC_TOG_PLL_POSTDIV_MASK (0x1CU) |
| #define | USBPHY_PLL_SIC_TOG_PLL_POSTDIV_SHIFT (2U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_POSTDIV(x) |
| #define | USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_MASK (0x40U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_SHIFT (6U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS(x) |
| #define | USBPHY_PLL_SIC_TOG_PLL_POWER_MASK (0x1000U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_POWER_SHIFT (12U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_POWER(x) |
| #define | USBPHY_PLL_SIC_TOG_PLL_ENABLE_MASK (0x2000U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_ENABLE_SHIFT (13U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_ENABLE(x) |
| #define | USBPHY_PLL_SIC_TOG_PLL_BYPASS_MASK (0x10000U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_BYPASS_SHIFT (16U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_BYPASS(x) |
| #define | USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_MASK (0x80000U) |
| #define | USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_SHIFT (19U) |
| #define | USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL(x) |
| #define | USBPHY_PLL_SIC_TOG_REFBIAS_PWD_MASK (0x100000U) |
| #define | USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SHIFT (20U) |
| #define | USBPHY_PLL_SIC_TOG_REFBIAS_PWD(x) |
| #define | USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_MASK (0x200000U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_SHIFT (21U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE(x) |
| #define | USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_MASK (0x1C00000U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_SHIFT (22U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_DIV_SEL(x) |
| #define | USBPHY_PLL_SIC_TOG_PLL_LOCK_MASK (0x80000000U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_LOCK_SHIFT (31U) |
| #define | USBPHY_PLL_SIC_TOG_PLL_LOCK(x) |
USB1_VBUS_DETECT - USB PHY VBUS Detect Control Register | |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_MASK (0x7U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_SHIFT (0U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH(x) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_MASK (0x8U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_SHIFT (3U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_MASK (0x10U) |
| #define | USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_SHIFT (4U) |
| #define | USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_MASK (0x20U) |
| #define | USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_SHIFT (5U) |
| #define | USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_MASK (0x40U) |
| #define | USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_SHIFT (6U) |
| #define | USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_MASK (0x80U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_SHIFT (7U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_MASK (0x100U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_SHIFT (8U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL(x) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_MASK (0x600U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_SHIFT (9U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL(x) |
| #define | USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_MASK (0x800U) |
| #define | USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_SHIFT (11U) |
| #define | USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN(x) |
| #define | USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_MASK (0x1000U) |
| #define | USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_SHIFT (12U) |
| #define | USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_MASK (0x40000U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_SHIFT (18U) |
| #define | USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID(x) |
| #define | USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_MASK (0x700000U) |
| #define | USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_SHIFT (20U) |
| #define | USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS(x) |
| #define | USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_MASK (0x4000000U) |
| #define | USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_SHIFT (26U) |
| #define | USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS(x) |
| #define | USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_MASK (0x80000000U) |
| #define | USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_SHIFT (31U) |
| #define | USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR(x) |
USB1_VBUS_DETECT_SET - USB PHY VBUS Detect Control Register | |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_MASK (0x7U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_SHIFT (0U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_MASK (0x8U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_SHIFT (3U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_MASK (0x10U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_SHIFT (4U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_MASK (0x20U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_SHIFT (5U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_MASK (0x40U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_SHIFT (6U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_MASK (0x80U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_SHIFT (7U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_MASK (0x100U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_SHIFT (8U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_MASK (0x600U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_SHIFT (9U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_MASK (0x800U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_SHIFT (11U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_MASK (0x1000U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_SHIFT (12U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_MASK (0x40000U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_SHIFT (18U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_MASK (0x700000U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_SHIFT (20U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_MASK (0x4000000U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_SHIFT (26U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS(x) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_MASK (0x80000000U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_SHIFT (31U) |
| #define | USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR(x) |
USB1_VBUS_DETECT_CLR - USB PHY VBUS Detect Control Register | |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_MASK (0x7U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_SHIFT (0U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_MASK (0x8U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_SHIFT (3U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_MASK (0x10U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_SHIFT (4U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_MASK (0x20U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_SHIFT (5U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_MASK (0x40U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_SHIFT (6U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_MASK (0x80U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_SHIFT (7U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_MASK (0x100U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_SHIFT (8U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_MASK (0x600U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_SHIFT (9U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_MASK (0x800U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_SHIFT (11U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_MASK (0x1000U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_SHIFT (12U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_MASK (0x40000U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_SHIFT (18U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_MASK (0x700000U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_SHIFT (20U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_MASK (0x4000000U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_SHIFT (26U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS(x) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_MASK (0x80000000U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_SHIFT (31U) |
| #define | USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR(x) |
USB1_VBUS_DETECT_TOG - USB PHY VBUS Detect Control Register | |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_MASK (0x7U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_SHIFT (0U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_MASK (0x8U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_SHIFT (3U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_MASK (0x10U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_SHIFT (4U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_MASK (0x20U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_SHIFT (5U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_MASK (0x40U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_SHIFT (6U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_MASK (0x80U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_SHIFT (7U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_MASK (0x100U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_SHIFT (8U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_MASK (0x600U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_SHIFT (9U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_MASK (0x800U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_SHIFT (11U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_MASK (0x1000U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_SHIFT (12U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_MASK (0x40000U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_SHIFT (18U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_MASK (0x700000U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_SHIFT (20U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_MASK (0x4000000U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_SHIFT (26U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS(x) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_MASK (0x80000000U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_SHIFT (31U) |
| #define | USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR(x) |
USB1_VBUS_DET_STAT - USB PHY VBUS Detector Status Register | |
| #define | USBPHY_USB1_VBUS_DET_STAT_SESSEND_MASK (0x1U) |
| #define | USBPHY_USB1_VBUS_DET_STAT_SESSEND_SHIFT (0U) |
| #define | USBPHY_USB1_VBUS_DET_STAT_SESSEND(x) |
| #define | USBPHY_USB1_VBUS_DET_STAT_BVALID_MASK (0x2U) |
| #define | USBPHY_USB1_VBUS_DET_STAT_BVALID_SHIFT (1U) |
| #define | USBPHY_USB1_VBUS_DET_STAT_BVALID(x) |
| #define | USBPHY_USB1_VBUS_DET_STAT_AVALID_MASK (0x4U) |
| #define | USBPHY_USB1_VBUS_DET_STAT_AVALID_SHIFT (2U) |
| #define | USBPHY_USB1_VBUS_DET_STAT_AVALID(x) |
| #define | USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_MASK (0x8U) |
| #define | USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_SHIFT (3U) |
| #define | USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID(x) |
| #define | USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_MASK (0x10U) |
| #define | USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_SHIFT (4U) |
| #define | USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V(x) |
USB1_CHRG_DETECT - USB PHY Charger Detect Control Register | |
| #define | USBPHY_USB1_CHRG_DETECT_PULLUP_DP_MASK (0x4U) |
| #define | USBPHY_USB1_CHRG_DETECT_PULLUP_DP_SHIFT (2U) |
| #define | USBPHY_USB1_CHRG_DETECT_PULLUP_DP(x) |
| #define | USBPHY_USB1_CHRG_DETECT_BGR_BIAS_MASK (0x800000U) |
| #define | USBPHY_USB1_CHRG_DETECT_BGR_BIAS_SHIFT (23U) |
| #define | USBPHY_USB1_CHRG_DETECT_BGR_BIAS(x) |
USB1_CHRG_DETECT_SET - USB PHY Charger Detect Control Register | |
| #define | USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_MASK (0x4U) |
| #define | USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_SHIFT (2U) |
| #define | USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP(x) |
| #define | USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_MASK (0x800000U) |
| #define | USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_SHIFT (23U) |
| #define | USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS(x) |
USB1_CHRG_DETECT_CLR - USB PHY Charger Detect Control Register | |
| #define | USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_MASK (0x4U) |
| #define | USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_SHIFT (2U) |
| #define | USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP(x) |
| #define | USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_MASK (0x800000U) |
| #define | USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_SHIFT (23U) |
| #define | USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS(x) |
USB1_CHRG_DETECT_TOG - USB PHY Charger Detect Control Register | |
| #define | USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_MASK (0x4U) |
| #define | USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_SHIFT (2U) |
| #define | USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP(x) |
| #define | USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_MASK (0x800000U) |
| #define | USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_SHIFT (23U) |
| #define | USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS(x) |
USB1_CHRG_DET_STAT - USB PHY Charger Detect Status Register | |
| #define | USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_MASK (0x1U) |
| #define | USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_SHIFT (0U) |
| #define | USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT(x) |
| #define | USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_MASK (0x2U) |
| #define | USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_SHIFT (1U) |
| #define | USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED(x) |
| #define | USBPHY_USB1_CHRG_DET_STAT_DN_STATE_MASK (0x4U) |
| #define | USBPHY_USB1_CHRG_DET_STAT_DN_STATE_SHIFT (2U) |
| #define | USBPHY_USB1_CHRG_DET_STAT_DN_STATE(x) |
| #define | USBPHY_USB1_CHRG_DET_STAT_DP_STATE_MASK (0x8U) |
| #define | USBPHY_USB1_CHRG_DET_STAT_DP_STATE_SHIFT (3U) |
| #define | USBPHY_USB1_CHRG_DET_STAT_DP_STATE(x) |
| #define | USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_MASK (0x10U) |
| #define | USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_SHIFT (4U) |
| #define | USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP(x) |
ANACTRL - USB PHY Analog Control Register | |
| #define | USBPHY_ANACTRL_DEV_PULLDOWN_MASK (0x400U) |
| #define | USBPHY_ANACTRL_DEV_PULLDOWN_SHIFT (10U) |
| #define | USBPHY_ANACTRL_DEV_PULLDOWN(x) |
ANACTRL_SET - USB PHY Analog Control Register | |
| #define | USBPHY_ANACTRL_SET_DEV_PULLDOWN_MASK (0x400U) |
| #define | USBPHY_ANACTRL_SET_DEV_PULLDOWN_SHIFT (10U) |
| #define | USBPHY_ANACTRL_SET_DEV_PULLDOWN(x) |
ANACTRL_CLR - USB PHY Analog Control Register | |
| #define | USBPHY_ANACTRL_CLR_DEV_PULLDOWN_MASK (0x400U) |
| #define | USBPHY_ANACTRL_CLR_DEV_PULLDOWN_SHIFT (10U) |
| #define | USBPHY_ANACTRL_CLR_DEV_PULLDOWN(x) |
ANACTRL_TOG - USB PHY Analog Control Register | |
| #define | USBPHY_ANACTRL_TOG_DEV_PULLDOWN_MASK (0x400U) |
| #define | USBPHY_ANACTRL_TOG_DEV_PULLDOWN_SHIFT (10U) |
| #define | USBPHY_ANACTRL_TOG_DEV_PULLDOWN(x) |
USB1_LOOPBACK - USB PHY Loopback Control/Status Register | |
| #define | USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_MASK (0x1U) |
| #define | USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_SHIFT (0U) |
| #define | USBPHY_USB1_LOOPBACK_UTMI_TESTSTART(x) |
| #define | USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_MASK (0x2U) |
| #define | USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_SHIFT (1U) |
| #define | USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0(x) |
| #define | USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_MASK (0x4U) |
| #define | USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_SHIFT (2U) |
| #define | USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1(x) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_MASK (0x8U) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_SHIFT (3U) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE(x) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_MASK (0x10U) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_SHIFT (4U) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE(x) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_EN_MASK (0x20U) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_EN_SHIFT (5U) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_EN(x) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_MASK (0x40U) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_SHIFT (6U) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ(x) |
| #define | USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_MASK (0x80U) |
| #define | USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_SHIFT (7U) |
| #define | USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0(x) |
| #define | USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_MASK (0x100U) |
| #define | USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_SHIFT (8U) |
| #define | USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1(x) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_MASK (0x8000U) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_SHIFT (15U) |
| #define | USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN(x) |
| #define | USBPHY_USB1_LOOPBACK_TSTPKT_MASK (0xFF0000U) |
| #define | USBPHY_USB1_LOOPBACK_TSTPKT_SHIFT (16U) |
| #define | USBPHY_USB1_LOOPBACK_TSTPKT(x) |
USB1_LOOPBACK_SET - USB PHY Loopback Control/Status Register | |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_MASK (0x1U) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_SHIFT (0U) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART(x) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_MASK (0x2U) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_SHIFT (1U) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0(x) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_MASK (0x4U) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_SHIFT (2U) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1(x) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_MASK (0x8U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_SHIFT (3U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE(x) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_MASK (0x10U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_SHIFT (4U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE(x) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_MASK (0x20U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_SHIFT (5U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN(x) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_MASK (0x40U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_SHIFT (6U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ(x) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_MASK (0x80U) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_SHIFT (7U) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0(x) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_MASK (0x100U) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_SHIFT (8U) |
| #define | USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1(x) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_MASK (0x8000U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_SHIFT (15U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN(x) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTPKT_MASK (0xFF0000U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTPKT_SHIFT (16U) |
| #define | USBPHY_USB1_LOOPBACK_SET_TSTPKT(x) |
USB1_LOOPBACK_CLR - USB PHY Loopback Control/Status Register | |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_MASK (0x1U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_SHIFT (0U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART(x) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_MASK (0x2U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_SHIFT (1U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0(x) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_MASK (0x4U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_SHIFT (2U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1(x) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_MASK (0x8U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_SHIFT (3U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE(x) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_MASK (0x10U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_SHIFT (4U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE(x) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_MASK (0x20U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_SHIFT (5U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN(x) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_MASK (0x40U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_SHIFT (6U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ(x) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_MASK (0x80U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_SHIFT (7U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0(x) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_MASK (0x100U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_SHIFT (8U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1(x) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_MASK (0x8000U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_SHIFT (15U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN(x) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTPKT_MASK (0xFF0000U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTPKT_SHIFT (16U) |
| #define | USBPHY_USB1_LOOPBACK_CLR_TSTPKT(x) |
USB1_LOOPBACK_TOG - USB PHY Loopback Control/Status Register | |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_MASK (0x1U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_SHIFT (0U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART(x) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_MASK (0x2U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_SHIFT (1U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0(x) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_MASK (0x4U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_SHIFT (2U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1(x) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_MASK (0x8U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_SHIFT (3U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE(x) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_MASK (0x10U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_SHIFT (4U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE(x) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_MASK (0x20U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_SHIFT (5U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN(x) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_MASK (0x40U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_SHIFT (6U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ(x) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_MASK (0x80U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_SHIFT (7U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0(x) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_MASK (0x100U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_SHIFT (8U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1(x) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_MASK (0x8000U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_SHIFT (15U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN(x) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTPKT_MASK (0xFF0000U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTPKT_SHIFT (16U) |
| #define | USBPHY_USB1_LOOPBACK_TOG_TSTPKT(x) |
USB1_LOOPBACK_HSFSCNT - USB PHY Loopback Packet Number Select Register | |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_MASK (0xFFFFU) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_SHIFT (0U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER(x) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_MASK (0xFFFF0000U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_SHIFT (16U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER(x) |
USB1_LOOPBACK_HSFSCNT_SET - USB PHY Loopback Packet Number Select Register | |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_MASK (0xFFFFU) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_SHIFT (0U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER(x) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_MASK (0xFFFF0000U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_SHIFT (16U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER(x) |
USB1_LOOPBACK_HSFSCNT_CLR - USB PHY Loopback Packet Number Select Register | |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_MASK (0xFFFFU) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_SHIFT (0U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER(x) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_MASK (0xFFFF0000U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_SHIFT (16U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER(x) |
USB1_LOOPBACK_HSFSCNT_TOG - USB PHY Loopback Packet Number Select Register | |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_MASK (0xFFFFU) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_SHIFT (0U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER(x) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_MASK (0xFFFF0000U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_SHIFT (16U) |
| #define | USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER(x) |
TRIM_OVERRIDE_EN - USB PHY Trim Override Enable Register | |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_MASK (0x1U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_SHIFT (0U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK (0x2U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT (1U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_MASK (0x4U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_SHIFT (2U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_MASK (0x8U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_SHIFT (3U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_MASK (0x10U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_SHIFT (4U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK (0x20U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT (5U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_MASK (0x40U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_SHIFT (6U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_MASK (0x1C00U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_SHIFT (10U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_MASK (0x6000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_SHIFT (13U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_MASK (0x38000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_SHIFT (15U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK (0xC0000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT (18U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_MASK (0xF00000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_SHIFT (20U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_MASK (0xF000000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_SHIFT (24U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_MASK (0xF0000000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_SHIFT (28U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN(x) |
TRIM_OVERRIDE_EN_SET - USB PHY Trim Override Enable Register | |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_MASK (0x1U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_SHIFT (0U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK (0x2U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT (1U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_MASK (0x4U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_SHIFT (2U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_MASK (0x8U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_SHIFT (3U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_MASK (0x10U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_SHIFT (4U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK (0x20U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT (5U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_MASK (0x40U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_SHIFT (6U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_MASK (0x1C00U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_SHIFT (10U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_MASK (0x6000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_SHIFT (13U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_MASK (0x38000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_SHIFT (15U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK (0xC0000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT (18U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_MASK (0xF00000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_SHIFT (20U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_MASK (0xF000000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_SHIFT (24U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_MASK (0xF0000000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_SHIFT (28U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN(x) |
TRIM_OVERRIDE_EN_CLR - USB PHY Trim Override Enable Register | |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_MASK (0x1U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_SHIFT (0U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK (0x2U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT (1U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_MASK (0x4U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_SHIFT (2U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_MASK (0x8U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_SHIFT (3U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_MASK (0x10U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_SHIFT (4U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK (0x20U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT (5U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_MASK (0x40U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_SHIFT (6U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_MASK (0x1C00U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_SHIFT (10U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_MASK (0x6000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_SHIFT (13U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_MASK (0x38000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_SHIFT (15U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK (0xC0000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT (18U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_MASK (0xF00000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_SHIFT (20U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_MASK (0xF000000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_SHIFT (24U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_MASK (0xF0000000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_SHIFT (28U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN(x) |
TRIM_OVERRIDE_EN_TOG - USB PHY Trim Override Enable Register | |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_MASK (0x1U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_SHIFT (0U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK (0x2U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT (1U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_MASK (0x4U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_SHIFT (2U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_MASK (0x8U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_SHIFT (3U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_MASK (0x10U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_SHIFT (4U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK (0x20U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT (5U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_MASK (0x40U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_SHIFT (6U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_MASK (0x1C00U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_SHIFT (10U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_MASK (0x6000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_SHIFT (13U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_MASK (0x38000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_SHIFT (15U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK (0xC0000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT (18U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_MASK (0xF00000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_SHIFT (20U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_MASK (0xF000000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_SHIFT (24U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP(x) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_MASK (0xF0000000U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_SHIFT (28U) |
| #define | USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN(x) |
| #define USBPHY_ANACTRL_CLR_DEV_PULLDOWN | ( | x | ) |
DEV_PULLDOWN - DEV_PULLDOWN
| #define USBPHY_ANACTRL_DEV_PULLDOWN | ( | x | ) |
DEV_PULLDOWN - DEV_PULLDOWN 0b0..The 15kohm nominal pulldowns on the DP and DN pinsare disabled in device mode. 0b1..The 15kohm nominal pulldowns on the DP and DN pinsare enabled in device mode.
| #define USBPHY_ANACTRL_SET_DEV_PULLDOWN | ( | x | ) |
| #define USBPHY_ANACTRL_TOG_DEV_PULLDOWN | ( | x | ) |
| #define USBPHY_CTRL_AUTORESUME_EN | ( | x | ) |
AUTORESUME_EN - AUTORESUME_EN
| #define USBPHY_CTRL_CLKGATE | ( | x | ) |
CLKGATE - CLKGATE
CLKGATE - CLKGATE
CLKGATE - CLKGATE
| #define USBPHY_CTRL_CLR_AUTORESUME_EN | ( | x | ) |
| #define USBPHY_CTRL_CLR_CLKGATE | ( | x | ) |
CLKGATE - CLKGATE
CLKGATE - CLKGATE
CLKGATE - CLKGATE
| #define USBPHY_CTRL_CLR_DATA_ON_LRADC | ( | x | ) |
| #define USBPHY_CTRL_CLR_DEVPLUGIN_IRQ | ( | x | ) |
DEVPLUGIN_IRQ - DEVPLUGIN_IRQ
| #define USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY | ( | x | ) |
DEVPLUGIN_POLARITY - DEVPLUGIN_POLARITY
| #define USBPHY_CTRL_CLR_ENAUTO_PWRON_PLL | ( | x | ) |
| #define USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE | ( | x | ) |
ENAUTOCLR_CLKGATE - ENAUTOCLR_CLKGATE
| #define USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD | ( | x | ) |
ENAUTOCLR_PHY_PWD - ENAUTOCLR_PHY_PWD
| #define USBPHY_CTRL_CLR_ENDEVPLUGINDETECT | ( | x | ) |
ENDEVPLUGINDETECT - Enables non-standard resistive plugged-in detection
| #define USBPHY_CTRL_CLR_ENDPDMCHG_WKUP | ( | x | ) |
ENDPDMCHG_WKUP - ENDPDMCHG_WKUP
| #define USBPHY_CTRL_CLR_ENHOSTDISCONDETECT | ( | x | ) |
ENHOSTDISCONDETECT - ENHOSTDISCONDETECT
| #define USBPHY_CTRL_CLR_ENIDCHG_WKUP | ( | x | ) |
ENIDCHG_WKUP - ENIDCHG_WKUP
| #define USBPHY_CTRL_CLR_ENIRQDEVPLUGIN | ( | x | ) |
ENIRQDEVPLUGIN - ENIRQDEVPLUGIN
| #define USBPHY_CTRL_CLR_ENIRQHOSTDISCON | ( | x | ) |
ENIRQHOSTDISCON - ENIRQHOSTDISCON
| #define USBPHY_CTRL_CLR_ENIRQRESUMEDETECT | ( | x | ) |
ENIRQRESUMEDETECT - ENIRQRESUMEDETECT
| #define USBPHY_CTRL_CLR_ENIRQWAKEUP | ( | x | ) |
ENIRQWAKEUP - ENIRQWAKEUP
| #define USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ | ( | x | ) |
ENOTG_ID_CHG_IRQ - ENOTG_ID_CHG_IRQ
| #define USBPHY_CTRL_CLR_ENOTGIDDETECT | ( | x | ) |
ENOTGIDDETECT - ENOTGIDDETECT
| #define USBPHY_CTRL_CLR_ENUTMILEVEL2 | ( | x | ) |
ENUTMILEVEL2 - ENUTMILEVEL2
| #define USBPHY_CTRL_CLR_ENUTMILEVEL3 | ( | x | ) |
ENUTMILEVEL3 - ENUTMILEVEL3
| #define USBPHY_CTRL_CLR_ENVBUSCHG_WKUP | ( | x | ) |
ENVBUSCHG_WKUP - ENVBUSCHG_WKUP
| #define USBPHY_CTRL_CLR_FSDLL_RST_EN | ( | x | ) |
FSDLL_RST_EN - FSDLL_RST_EN
| #define USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0 | ( | x | ) |
HOST_FORCE_LS_SE0 - HOST_FORCE_LS_SE0
| #define USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ | ( | x | ) |
HOSTDISCONDETECT_IRQ - HOSTDISCONDETECT_IRQ
| #define USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ | ( | x | ) |
OTG_ID_CHG_IRQ - OTG_ID_CHG_IRQ
| #define USBPHY_CTRL_CLR_OTG_ID_VALUE | ( | x | ) |
OTG_ID_VALUE - OTG_ID_VALUE
| #define USBPHY_CTRL_CLR_RESUME_IRQ | ( | x | ) |
RESUME_IRQ - RESUME_IRQ
| #define USBPHY_CTRL_CLR_RESUMEIRQSTICKY | ( | x | ) |
RESUMEIRQSTICKY - RESUMEIRQSTICKY
| #define USBPHY_CTRL_CLR_RSVD1 | ( | x | ) |
| #define USBPHY_CTRL_CLR_SFTRST | ( | x | ) |
SFTRST - SFTRST
SFTRST - SFTRST
SFTRST - SFTRST
| #define USBPHY_CTRL_CLR_UTMI_SUSPENDM | ( | x | ) |
UTMI_SUSPENDM - UTMI_SUSPENDM
| #define USBPHY_CTRL_CLR_WAKEUP_IRQ | ( | x | ) |
WAKEUP_IRQ - WAKEUP_IRQ
| #define USBPHY_CTRL_DATA_ON_LRADC | ( | x | ) |
| #define USBPHY_CTRL_DEVPLUGIN_IRQ | ( | x | ) |
| #define USBPHY_CTRL_DEVPLUGIN_POLARITY | ( | x | ) |
| #define USBPHY_CTRL_ENAUTO_PWRON_PLL | ( | x | ) |
| #define USBPHY_CTRL_ENAUTOCLR_CLKGATE | ( | x | ) |
| #define USBPHY_CTRL_ENAUTOCLR_PHY_PWD | ( | x | ) |
| #define USBPHY_CTRL_ENDEVPLUGINDETECT | ( | x | ) |
ENDEVPLUGINDETECT - Enables non-standard resistive plugged-in detection 0b0..Disables 200kohm pullup resistors on DP and DN pins 0b1..Enables 200kohm pullup resistors on DP and DN pins
| #define USBPHY_CTRL_ENDPDMCHG_WKUP | ( | x | ) |
| #define USBPHY_CTRL_ENHOSTDISCONDETECT | ( | x | ) |
| #define USBPHY_CTRL_ENIDCHG_WKUP | ( | x | ) |
| #define USBPHY_CTRL_ENIRQDEVPLUGIN | ( | x | ) |
| #define USBPHY_CTRL_ENIRQHOSTDISCON | ( | x | ) |
| #define USBPHY_CTRL_ENIRQRESUMEDETECT | ( | x | ) |
| #define USBPHY_CTRL_ENIRQWAKEUP | ( | x | ) |
| #define USBPHY_CTRL_ENOTG_ID_CHG_IRQ | ( | x | ) |
| #define USBPHY_CTRL_ENOTGIDDETECT | ( | x | ) |
| #define USBPHY_CTRL_ENUTMILEVEL2 | ( | x | ) |
| #define USBPHY_CTRL_ENUTMILEVEL3 | ( | x | ) |
| #define USBPHY_CTRL_ENVBUSCHG_WKUP | ( | x | ) |
| #define USBPHY_CTRL_FSDLL_RST_EN | ( | x | ) |
| #define USBPHY_CTRL_HOST_FORCE_LS_SE0 | ( | x | ) |
| #define USBPHY_CTRL_HOSTDISCONDETECT_IRQ | ( | x | ) |
| #define USBPHY_CTRL_OTG_ID_CHG_IRQ | ( | x | ) |
| #define USBPHY_CTRL_OTG_ID_VALUE | ( | x | ) |
| #define USBPHY_CTRL_RESUME_IRQ | ( | x | ) |
| #define USBPHY_CTRL_RESUMEIRQSTICKY | ( | x | ) |
| #define USBPHY_CTRL_RSVD1 | ( | x | ) |
| #define USBPHY_CTRL_SET_AUTORESUME_EN | ( | x | ) |
| #define USBPHY_CTRL_SET_CLKGATE | ( | x | ) |
CLKGATE - CLKGATE
CLKGATE - CLKGATE
CLKGATE - CLKGATE
| #define USBPHY_CTRL_SET_DATA_ON_LRADC | ( | x | ) |
| #define USBPHY_CTRL_SET_DEVPLUGIN_IRQ | ( | x | ) |
| #define USBPHY_CTRL_SET_DEVPLUGIN_POLARITY | ( | x | ) |
| #define USBPHY_CTRL_SET_ENAUTO_PWRON_PLL | ( | x | ) |
| #define USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE | ( | x | ) |
| #define USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD | ( | x | ) |
| #define USBPHY_CTRL_SET_ENDEVPLUGINDETECT | ( | x | ) |
| #define USBPHY_CTRL_SET_ENDPDMCHG_WKUP | ( | x | ) |
| #define USBPHY_CTRL_SET_ENHOSTDISCONDETECT | ( | x | ) |
| #define USBPHY_CTRL_SET_ENIDCHG_WKUP | ( | x | ) |
| #define USBPHY_CTRL_SET_ENIRQDEVPLUGIN | ( | x | ) |
| #define USBPHY_CTRL_SET_ENIRQHOSTDISCON | ( | x | ) |
| #define USBPHY_CTRL_SET_ENIRQRESUMEDETECT | ( | x | ) |
| #define USBPHY_CTRL_SET_ENIRQWAKEUP | ( | x | ) |
| #define USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ | ( | x | ) |
| #define USBPHY_CTRL_SET_ENOTGIDDETECT | ( | x | ) |
| #define USBPHY_CTRL_SET_ENUTMILEVEL2 | ( | x | ) |
| #define USBPHY_CTRL_SET_ENUTMILEVEL3 | ( | x | ) |
| #define USBPHY_CTRL_SET_ENVBUSCHG_WKUP | ( | x | ) |
| #define USBPHY_CTRL_SET_FSDLL_RST_EN | ( | x | ) |
| #define USBPHY_CTRL_SET_HOST_FORCE_LS_SE0 | ( | x | ) |
| #define USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ | ( | x | ) |
| #define USBPHY_CTRL_SET_OTG_ID_CHG_IRQ | ( | x | ) |
| #define USBPHY_CTRL_SET_OTG_ID_VALUE | ( | x | ) |
| #define USBPHY_CTRL_SET_RESUME_IRQ | ( | x | ) |
| #define USBPHY_CTRL_SET_RESUMEIRQSTICKY | ( | x | ) |
| #define USBPHY_CTRL_SET_RSVD1 | ( | x | ) |
| #define USBPHY_CTRL_SET_SFTRST | ( | x | ) |
SFTRST - SFTRST
SFTRST - SFTRST
SFTRST - SFTRST
| #define USBPHY_CTRL_SET_UTMI_SUSPENDM | ( | x | ) |
| #define USBPHY_CTRL_SET_WAKEUP_IRQ | ( | x | ) |
| #define USBPHY_CTRL_SFTRST | ( | x | ) |
SFTRST - SFTRST
SFTRST - SFTRST
SFTRST - SFTRST
| #define USBPHY_CTRL_TOG_AUTORESUME_EN | ( | x | ) |
| #define USBPHY_CTRL_TOG_CLKGATE | ( | x | ) |
CLKGATE - CLKGATE
CLKGATE - CLKGATE
CLKGATE - CLKGATE
| #define USBPHY_CTRL_TOG_DATA_ON_LRADC | ( | x | ) |
| #define USBPHY_CTRL_TOG_DEVPLUGIN_IRQ | ( | x | ) |
| #define USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENAUTO_PWRON_PLL | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENDEVPLUGINDETECT | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENDPDMCHG_WKUP | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENHOSTDISCONDETECT | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENIDCHG_WKUP | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENIRQDEVPLUGIN | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENIRQHOSTDISCON | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENIRQRESUMEDETECT | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENIRQWAKEUP | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENOTGIDDETECT | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENUTMILEVEL2 | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENUTMILEVEL3 | ( | x | ) |
| #define USBPHY_CTRL_TOG_ENVBUSCHG_WKUP | ( | x | ) |
| #define USBPHY_CTRL_TOG_FSDLL_RST_EN | ( | x | ) |
| #define USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0 | ( | x | ) |
| #define USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ | ( | x | ) |
| #define USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ | ( | x | ) |
| #define USBPHY_CTRL_TOG_OTG_ID_VALUE | ( | x | ) |
| #define USBPHY_CTRL_TOG_RESUME_IRQ | ( | x | ) |
| #define USBPHY_CTRL_TOG_RESUMEIRQSTICKY | ( | x | ) |
| #define USBPHY_CTRL_TOG_RSVD1 | ( | x | ) |
| #define USBPHY_CTRL_TOG_SFTRST | ( | x | ) |
SFTRST - SFTRST
SFTRST - SFTRST
SFTRST - SFTRST
| #define USBPHY_CTRL_TOG_UTMI_SUSPENDM | ( | x | ) |
| #define USBPHY_CTRL_TOG_WAKEUP_IRQ | ( | x | ) |
| #define USBPHY_CTRL_UTMI_SUSPENDM | ( | x | ) |
| #define USBPHY_CTRL_WAKEUP_IRQ | ( | x | ) |
| #define USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT | ( | x | ) |
LOOP_BACK_FAIL_COUNT - LOOP_BACK_FAIL_COUNT
| #define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT | ( | x | ) |
SQUELCH_COUNT - SQUELCH_COUNT
| #define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT | ( | x | ) |
UTMI_RXERROR_FAIL_COUNT - UTMI_RXERROR_FAIL_COUNT
| #define USBPHY_DEBUG1_CLR_ENTAILADJVD | ( | x | ) |
ENTAILADJVD - ENTAILADJVD
| #define USBPHY_DEBUG1_CLR_RSVD0 | ( | x | ) |
| #define USBPHY_DEBUG1_CLR_RSVD1 | ( | x | ) |
| #define USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR | ( | x | ) |
USB2_REFBIAS_LOWPWR - to be added
| #define USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP | ( | x | ) |
USB2_REFBIAS_PWDVBGUP - Powers down the bandgap detect logic, will affect vbgup on misc1 register.
| #define USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF | ( | x | ) |
USB2_REFBIAS_SELFBIASOFF - Set to 1 to disable self bias, 100 us after power up refbias(usb2_refbias_pwd).This can reduce noise on power.
| #define USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST | ( | x | ) |
USB2_REFBIAS_TST - Bias current control for usb2_phy
| #define USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ | ( | x | ) |
USB2_REFBIAS_VBGADJ - Adjustment bits on bandgap
| #define USBPHY_DEBUG1_ENTAILADJVD | ( | x | ) |
ENTAILADJVD - ENTAILADJVD 0b00..Delay is nominal 0b01..Delay is +20% 0b10..Delay is -20% 0b11..Delay is -40%
| #define USBPHY_DEBUG1_RSVD0 | ( | x | ) |
| #define USBPHY_DEBUG1_RSVD1 | ( | x | ) |
| #define USBPHY_DEBUG1_SET_ENTAILADJVD | ( | x | ) |
| #define USBPHY_DEBUG1_SET_RSVD0 | ( | x | ) |
| #define USBPHY_DEBUG1_SET_RSVD1 | ( | x | ) |
| #define USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR | ( | x | ) |
| #define USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP | ( | x | ) |
| #define USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF | ( | x | ) |
| #define USBPHY_DEBUG1_SET_USB2_REFBIAS_TST | ( | x | ) |
| #define USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ | ( | x | ) |
| #define USBPHY_DEBUG1_TOG_ENTAILADJVD | ( | x | ) |
| #define USBPHY_DEBUG1_TOG_RSVD0 | ( | x | ) |
| #define USBPHY_DEBUG1_TOG_RSVD1 | ( | x | ) |
| #define USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR | ( | x | ) |
| #define USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP | ( | x | ) |
| #define USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF | ( | x | ) |
| #define USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST | ( | x | ) |
| #define USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ | ( | x | ) |
| #define USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR | ( | x | ) |
| #define USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP | ( | x | ) |
| #define USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF | ( | x | ) |
| #define USBPHY_DEBUG1_USB2_REFBIAS_TST | ( | x | ) |
| #define USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ | ( | x | ) |
| #define USBPHY_DEBUG_CLKGATE | ( | x | ) |
CLKGATE - CLKGATE
CLKGATE - CLKGATE
CLKGATE - CLKGATE
| #define USBPHY_DEBUG_CLR_CLKGATE | ( | x | ) |
CLKGATE - CLKGATE
CLKGATE - CLKGATE
CLKGATE - CLKGATE
| #define USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD | ( | x | ) |
DEBUG_INTERFACE_HOLD - DEBUG_INTERFACE_HOLD
| #define USBPHY_DEBUG_CLR_ENHSTPULLDOWN | ( | x | ) |
ENHSTPULLDOWN - ENHSTPULLDOWN
| #define USBPHY_DEBUG_CLR_ENSQUELCHRESET | ( | x | ) |
ENSQUELCHRESET - ENSQUELCHRESET
| #define USBPHY_DEBUG_CLR_ENTX2RXCOUNT | ( | x | ) |
ENTX2RXCOUNT - ENTX2RXCOUNT
| #define USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG | ( | x | ) |
HOST_RESUME_DEBUG - HOST_RESUME_DEBUG
| #define USBPHY_DEBUG_CLR_HSTPULLDOWN | ( | x | ) |
HSTPULLDOWN - HSTPULLDOWN
| #define USBPHY_DEBUG_CLR_OTGIDPIOLOCK | ( | x | ) |
OTGIDPIOLOCK - OTGIDPIOLOCK
| #define USBPHY_DEBUG_CLR_RSVD0 | ( | x | ) |
| #define USBPHY_DEBUG_CLR_RSVD1 | ( | x | ) |
| #define USBPHY_DEBUG_CLR_RSVD2 | ( | x | ) |
| #define USBPHY_DEBUG_CLR_RSVD3 | ( | x | ) |
| #define USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT | ( | x | ) |
SQUELCHRESETCOUNT - SQUELCHRESETCOUNT
| #define USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH | ( | x | ) |
SQUELCHRESETLENGTH - SQUELCHRESETLENGTH
| #define USBPHY_DEBUG_CLR_TX2RXCOUNT | ( | x | ) |
TX2RXCOUNT - TX2RXCOUNT
| #define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD | ( | x | ) |
| #define USBPHY_DEBUG_ENHSTPULLDOWN | ( | x | ) |
| #define USBPHY_DEBUG_ENSQUELCHRESET | ( | x | ) |
| #define USBPHY_DEBUG_ENTX2RXCOUNT | ( | x | ) |
| #define USBPHY_DEBUG_HOST_RESUME_DEBUG | ( | x | ) |
| #define USBPHY_DEBUG_HSTPULLDOWN | ( | x | ) |
| #define USBPHY_DEBUG_OTGIDPIOLOCK | ( | x | ) |
| #define USBPHY_DEBUG_RSVD0 | ( | x | ) |
| #define USBPHY_DEBUG_RSVD1 | ( | x | ) |
| #define USBPHY_DEBUG_RSVD2 | ( | x | ) |
| #define USBPHY_DEBUG_RSVD3 | ( | x | ) |
| #define USBPHY_DEBUG_SET_CLKGATE | ( | x | ) |
CLKGATE - CLKGATE
CLKGATE - CLKGATE
CLKGATE - CLKGATE
| #define USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD | ( | x | ) |
| #define USBPHY_DEBUG_SET_ENHSTPULLDOWN | ( | x | ) |
| #define USBPHY_DEBUG_SET_ENSQUELCHRESET | ( | x | ) |
| #define USBPHY_DEBUG_SET_ENTX2RXCOUNT | ( | x | ) |
| #define USBPHY_DEBUG_SET_HOST_RESUME_DEBUG | ( | x | ) |
| #define USBPHY_DEBUG_SET_HSTPULLDOWN | ( | x | ) |
| #define USBPHY_DEBUG_SET_OTGIDPIOLOCK | ( | x | ) |
| #define USBPHY_DEBUG_SET_RSVD0 | ( | x | ) |
| #define USBPHY_DEBUG_SET_RSVD1 | ( | x | ) |
| #define USBPHY_DEBUG_SET_RSVD2 | ( | x | ) |
| #define USBPHY_DEBUG_SET_RSVD3 | ( | x | ) |
| #define USBPHY_DEBUG_SET_SQUELCHRESETCOUNT | ( | x | ) |
| #define USBPHY_DEBUG_SET_SQUELCHRESETLENGTH | ( | x | ) |
| #define USBPHY_DEBUG_SET_TX2RXCOUNT | ( | x | ) |
| #define USBPHY_DEBUG_SQUELCHRESETCOUNT | ( | x | ) |
| #define USBPHY_DEBUG_SQUELCHRESETLENGTH | ( | x | ) |
| #define USBPHY_DEBUG_TOG_CLKGATE | ( | x | ) |
CLKGATE - CLKGATE
CLKGATE - CLKGATE
CLKGATE - CLKGATE
| #define USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD | ( | x | ) |
| #define USBPHY_DEBUG_TOG_ENHSTPULLDOWN | ( | x | ) |
| #define USBPHY_DEBUG_TOG_ENSQUELCHRESET | ( | x | ) |
| #define USBPHY_DEBUG_TOG_ENTX2RXCOUNT | ( | x | ) |
| #define USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG | ( | x | ) |
| #define USBPHY_DEBUG_TOG_HSTPULLDOWN | ( | x | ) |
| #define USBPHY_DEBUG_TOG_OTGIDPIOLOCK | ( | x | ) |
| #define USBPHY_DEBUG_TOG_RSVD0 | ( | x | ) |
| #define USBPHY_DEBUG_TOG_RSVD1 | ( | x | ) |
| #define USBPHY_DEBUG_TOG_RSVD2 | ( | x | ) |
| #define USBPHY_DEBUG_TOG_RSVD3 | ( | x | ) |
| #define USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT | ( | x | ) |
| #define USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH | ( | x | ) |
| #define USBPHY_DEBUG_TOG_TX2RXCOUNT | ( | x | ) |
| #define USBPHY_DEBUG_TX2RXCOUNT | ( | x | ) |
| #define USBPHY_PLL_SIC_CLR_PLL_BYPASS | ( | x | ) |
PLL_BYPASS - PLL_BYPASS
| #define USBPHY_PLL_SIC_CLR_PLL_DIV_SEL | ( | x | ) |
PLL_DIV_SEL - PLL_DIV_SEL
| #define USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS | ( | x | ) |
PLL_EN_USB_CLKS - PLL_EN_USB_CLKS
| #define USBPHY_PLL_SIC_CLR_PLL_ENABLE | ( | x | ) |
PLL_ENABLE - PLL_ENABLE
| #define USBPHY_PLL_SIC_CLR_PLL_LOCK | ( | x | ) |
PLL_LOCK - PLL_LOCK
PLL_LOCK - PLL_LOCK
| #define USBPHY_PLL_SIC_CLR_PLL_POSTDIV | ( | x | ) |
PLL_POSTDIV - PLL_POSTDIV
| #define USBPHY_PLL_SIC_CLR_PLL_POWER | ( | x | ) |
PLL_POWER - PLL_POWER
| #define USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE | ( | x | ) |
PLL_REG_ENABLE - PLL_REG_ENABLE
| #define USBPHY_PLL_SIC_CLR_REFBIAS_PWD | ( | x | ) |
REFBIAS_PWD - Power down the reference bias
| #define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL | ( | x | ) |
REFBIAS_PWD_SEL - REFBIAS_PWD_SEL
| #define USBPHY_PLL_SIC_PLL_BYPASS | ( | x | ) |
| #define USBPHY_PLL_SIC_PLL_DIV_SEL | ( | x | ) |
PLL_DIV_SEL - PLL_DIV_SEL 0b000..Divide by 13 0b001..Divide by 15 0b010..Divide by 16 0b011..Divide by 20 0b100..Divide by 22 0b101..Divide by 25 0b110..Divide by 30 0b111..Divide by 240
| #define USBPHY_PLL_SIC_PLL_EN_USB_CLKS | ( | x | ) |
| #define USBPHY_PLL_SIC_PLL_ENABLE | ( | x | ) |
| #define USBPHY_PLL_SIC_PLL_LOCK | ( | x | ) |
PLL_LOCK - PLL_LOCK 0b0..PLL is not currently locked 0b1..PLL is currently locked
| #define USBPHY_PLL_SIC_PLL_POSTDIV | ( | x | ) |
| #define USBPHY_PLL_SIC_PLL_POWER | ( | x | ) |
| #define USBPHY_PLL_SIC_PLL_REG_ENABLE | ( | x | ) |
| #define USBPHY_PLL_SIC_REFBIAS_PWD | ( | x | ) |
| #define USBPHY_PLL_SIC_REFBIAS_PWD_SEL | ( | x | ) |
REFBIAS_PWD_SEL - REFBIAS_PWD_SEL 0b0..Selects PLL_POWER to control the reference bias 0b1..Selects REFBIAS_PWD to control the reference bias.
| #define USBPHY_PLL_SIC_SET_PLL_BYPASS | ( | x | ) |
| #define USBPHY_PLL_SIC_SET_PLL_DIV_SEL | ( | x | ) |
| #define USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS | ( | x | ) |
| #define USBPHY_PLL_SIC_SET_PLL_ENABLE | ( | x | ) |
| #define USBPHY_PLL_SIC_SET_PLL_LOCK | ( | x | ) |
PLL_LOCK - PLL_LOCK
PLL_LOCK - PLL_LOCK
| #define USBPHY_PLL_SIC_SET_PLL_POSTDIV | ( | x | ) |
| #define USBPHY_PLL_SIC_SET_PLL_POWER | ( | x | ) |
| #define USBPHY_PLL_SIC_SET_PLL_REG_ENABLE | ( | x | ) |
| #define USBPHY_PLL_SIC_SET_REFBIAS_PWD | ( | x | ) |
| #define USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL | ( | x | ) |
| #define USBPHY_PLL_SIC_TOG_PLL_BYPASS | ( | x | ) |
| #define USBPHY_PLL_SIC_TOG_PLL_DIV_SEL | ( | x | ) |
| #define USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS | ( | x | ) |
| #define USBPHY_PLL_SIC_TOG_PLL_ENABLE | ( | x | ) |
| #define USBPHY_PLL_SIC_TOG_PLL_LOCK | ( | x | ) |
PLL_LOCK - PLL_LOCK
PLL_LOCK - PLL_LOCK
| #define USBPHY_PLL_SIC_TOG_PLL_POSTDIV | ( | x | ) |
| #define USBPHY_PLL_SIC_TOG_PLL_POWER | ( | x | ) |
| #define USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE | ( | x | ) |
| #define USBPHY_PLL_SIC_TOG_REFBIAS_PWD | ( | x | ) |
| #define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL | ( | x | ) |
| #define USBPHY_PWD_CLR_RSVD0 | ( | x | ) |
| #define USBPHY_PWD_CLR_RSVD1 | ( | x | ) |
| #define USBPHY_PWD_CLR_RSVD2 | ( | x | ) |
| #define USBPHY_PWD_CLR_RXPWD1PT1 | ( | x | ) |
RXPWD1PT1 - RXPWD1PT1
| #define USBPHY_PWD_CLR_RXPWDDIFF | ( | x | ) |
RXPWDDIFF - RXPWDDIFF
| #define USBPHY_PWD_CLR_RXPWDENV | ( | x | ) |
RXPWDENV - RXPWDENV
RXPWDENV - RXPWDENV
RXPWDENV - RXPWDENV
| #define USBPHY_PWD_CLR_RXPWDRX | ( | x | ) |
RXPWDRX - RXPWDRX
RXPWDRX - RXPWDRX
RXPWDRX - RXPWDRX
| #define USBPHY_PWD_CLR_TXPWDFS | ( | x | ) |
TXPWDFS - TXPWDFS
TXPWDFS - TXPWDFS
TXPWDFS - TXPWDFS
| #define USBPHY_PWD_CLR_TXPWDIBIAS | ( | x | ) |
TXPWDIBIAS - TXPWDIBIAS
| #define USBPHY_PWD_CLR_TXPWDV2I | ( | x | ) |
TXPWDV2I - TXPWDV2I
TXPWDV2I - TXPWDV2I
TXPWDV2I - TXPWDV2I
| #define USBPHY_PWD_RSVD0 | ( | x | ) |
| #define USBPHY_PWD_RSVD1 | ( | x | ) |
| #define USBPHY_PWD_RSVD2 | ( | x | ) |
| #define USBPHY_PWD_RXPWD1PT1 | ( | x | ) |
RXPWD1PT1 - RXPWD1PT1 0b0..Normal operation 0b1..Power-down the USB full-speed differential receiver.
| #define USBPHY_PWD_RXPWDDIFF | ( | x | ) |
RXPWDDIFF - RXPWDDIFF 0b0..Normal operation. 0b1..Power-down the USB high-speed differential receiver
| #define USBPHY_PWD_RXPWDENV | ( | x | ) |
RXPWDENV - RXPWDENV 0b0..Normal operation. 0b1..Power-down the USB high-speed receiver envelope detector (squelch signal)
| #define USBPHY_PWD_RXPWDRX | ( | x | ) |
RXPWDRX - RXPWDRX 0b0..Normal operation 0b1..Power-down the entire USB PHY receiver block except for the full-speed differential receiver
| #define USBPHY_PWD_SET_RSVD0 | ( | x | ) |
| #define USBPHY_PWD_SET_RSVD1 | ( | x | ) |
| #define USBPHY_PWD_SET_RSVD2 | ( | x | ) |
| #define USBPHY_PWD_SET_RXPWD1PT1 | ( | x | ) |
| #define USBPHY_PWD_SET_RXPWDDIFF | ( | x | ) |
| #define USBPHY_PWD_SET_RXPWDENV | ( | x | ) |
RXPWDENV - RXPWDENV
RXPWDENV - RXPWDENV
RXPWDENV - RXPWDENV
| #define USBPHY_PWD_SET_RXPWDRX | ( | x | ) |
RXPWDRX - RXPWDRX
RXPWDRX - RXPWDRX
RXPWDRX - RXPWDRX
| #define USBPHY_PWD_SET_TXPWDFS | ( | x | ) |
TXPWDFS - TXPWDFS
TXPWDFS - TXPWDFS
TXPWDFS - TXPWDFS
| #define USBPHY_PWD_SET_TXPWDIBIAS | ( | x | ) |
| #define USBPHY_PWD_SET_TXPWDV2I | ( | x | ) |
TXPWDV2I - TXPWDV2I
TXPWDV2I - TXPWDV2I
TXPWDV2I - TXPWDV2I
| #define USBPHY_PWD_TOG_RSVD0 | ( | x | ) |
| #define USBPHY_PWD_TOG_RSVD1 | ( | x | ) |
| #define USBPHY_PWD_TOG_RSVD2 | ( | x | ) |
| #define USBPHY_PWD_TOG_RXPWD1PT1 | ( | x | ) |
| #define USBPHY_PWD_TOG_RXPWDDIFF | ( | x | ) |
| #define USBPHY_PWD_TOG_RXPWDENV | ( | x | ) |
RXPWDENV - RXPWDENV
RXPWDENV - RXPWDENV
RXPWDENV - RXPWDENV
| #define USBPHY_PWD_TOG_RXPWDRX | ( | x | ) |
RXPWDRX - RXPWDRX
RXPWDRX - RXPWDRX
RXPWDRX - RXPWDRX
| #define USBPHY_PWD_TOG_TXPWDFS | ( | x | ) |
TXPWDFS - TXPWDFS
TXPWDFS - TXPWDFS
TXPWDFS - TXPWDFS
| #define USBPHY_PWD_TOG_TXPWDIBIAS | ( | x | ) |
| #define USBPHY_PWD_TOG_TXPWDV2I | ( | x | ) |
TXPWDV2I - TXPWDV2I
TXPWDV2I - TXPWDV2I
TXPWDV2I - TXPWDV2I
| #define USBPHY_PWD_TXPWDFS | ( | x | ) |
TXPWDFS - TXPWDFS 0b0..Normal operation. 0b1..Power-down the USB full-speed drivers. This turns off the current starvation sources and puts the drivers into high-impedance output
| #define USBPHY_PWD_TXPWDIBIAS | ( | x | ) |
TXPWDIBIAS - TXPWDIBIAS 0b0..Normal operation 0b1..Power-down the USB PHY current bias block for the transmitter. This bit should be set only when the USB is in suspend mode. This effectively powers down the entire USB transmit path
| #define USBPHY_PWD_TXPWDV2I | ( | x | ) |
TXPWDV2I - TXPWDV2I 0b0..Normal operation. 0b1..Power-down the USB PHY transmit V-to-I converter and the current mirror
| #define USBPHY_RX_CLR_DISCONADJ | ( | x | ) |
DISCONADJ - DISCONADJ
| #define USBPHY_RX_CLR_ENVADJ | ( | x | ) |
ENVADJ - ENVADJ
ENVADJ - ENVADJ
ENVADJ - ENVADJ
| #define USBPHY_RX_CLR_RSVD0 | ( | x | ) |
| #define USBPHY_RX_CLR_RSVD1 | ( | x | ) |
| #define USBPHY_RX_CLR_RSVD2 | ( | x | ) |
| #define USBPHY_RX_CLR_RXDBYPASS | ( | x | ) |
RXDBYPASS - RXDBYPASS
| #define USBPHY_RX_DISCONADJ | ( | x | ) |
DISCONADJ - DISCONADJ 0b000..Trip-Level Voltage is 0.56875 V 0b001..Trip-Level Voltage is 0.55000 V 0b010..Trip-Level Voltage is 0.58125 V 0b011..Trip-Level Voltage is 0.60000 V 0b1xx..Reserved
| #define USBPHY_RX_ENVADJ | ( | x | ) |
ENVADJ - ENVADJ 0b000..Trip-Level Voltage is 0.1000 V 0b001..Trip-Level Voltage is 0.1125 V 0b010..Trip-Level Voltage is 0.1250 V 0b011..Trip-Level Voltage is 0.0875 V 0b1xx..Reserved
| #define USBPHY_RX_RSVD0 | ( | x | ) |
| #define USBPHY_RX_RSVD1 | ( | x | ) |
| #define USBPHY_RX_RSVD2 | ( | x | ) |
| #define USBPHY_RX_RXDBYPASS | ( | x | ) |
RXDBYPASS - RXDBYPASS 0b0..Normal operation. 0b1..Use the output of the USB_DP single-ended receiver in place of the full-speed differential receiver
| #define USBPHY_RX_SET_DISCONADJ | ( | x | ) |
| #define USBPHY_RX_SET_ENVADJ | ( | x | ) |
ENVADJ - ENVADJ
ENVADJ - ENVADJ
ENVADJ - ENVADJ
| #define USBPHY_RX_SET_RSVD0 | ( | x | ) |
| #define USBPHY_RX_SET_RSVD1 | ( | x | ) |
| #define USBPHY_RX_SET_RSVD2 | ( | x | ) |
| #define USBPHY_RX_SET_RXDBYPASS | ( | x | ) |
| #define USBPHY_RX_TOG_DISCONADJ | ( | x | ) |
| #define USBPHY_RX_TOG_ENVADJ | ( | x | ) |
ENVADJ - ENVADJ
ENVADJ - ENVADJ
ENVADJ - ENVADJ
| #define USBPHY_RX_TOG_RSVD0 | ( | x | ) |
| #define USBPHY_RX_TOG_RSVD1 | ( | x | ) |
| #define USBPHY_RX_TOG_RSVD2 | ( | x | ) |
| #define USBPHY_RX_TOG_RXDBYPASS | ( | x | ) |
| #define USBPHY_STATUS_DEVPLUGIN_STATUS | ( | x | ) |
DEVPLUGIN_STATUS - Status indicator for non-standard resistive plugged-in detection 0b0..No attachment to a USB host is detected 0b1..Cable attachment to a USB host is detected
| #define USBPHY_STATUS_HOSTDISCONDETECT_STATUS | ( | x | ) |
HOSTDISCONDETECT_STATUS - HOSTDISCONDETECT_STATUS 0b0..USB cable disconnect has not been detected at the local host 0b1..USB cable disconnect has been detected at the local host
| #define USBPHY_STATUS_OTGID_STATUS | ( | x | ) |
OTGID_STATUS - OTGID_STATUS
| #define USBPHY_STATUS_RESUME_STATUS | ( | x | ) |
RESUME_STATUS - RESUME_STATUS
| #define USBPHY_STATUS_RSVD0 | ( | x | ) |
| #define USBPHY_STATUS_RSVD1 | ( | x | ) |
| #define USBPHY_STATUS_RSVD2 | ( | x | ) |
| #define USBPHY_STATUS_RSVD3 | ( | x | ) |
| #define USBPHY_STATUS_RSVD4 | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE | ( | x | ) |
TRIM_DIV_SEL_OVERRIDE - TRIM_DIV_SEL_OVERRIDE
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE | ( | x | ) |
TRIM_ENV_TAIL_ADJ_VD_OVERRIDE - TRIM_ENV_TAIL_ADJ_VD_OVERRIDE
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL | ( | x | ) |
TRIM_PLL_CTRL0_DIV_SEL - TRIM_PLL_CTRL0_DIV_SEL
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE | ( | x | ) |
TRIM_REFBIAS_TST_OVERRIDE - Override enable for bias current control
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE | ( | x | ) |
TRIM_REFBIAS_VBGADJ_OVERRIDE - Override enable for bandgap adjustment.
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE | ( | x | ) |
TRIM_TX_CAL45DN_OVERRIDE - TRIM_TX_CAL45DN_OVERRIDE
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE | ( | x | ) |
TRIM_TX_CAL45DP_OVERRIDE - TRIM_TX_CAL45DP_OVERRIDE
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE | ( | x | ) |
TRIM_TX_D_CAL_OVERRIDE - TRIM_TX_D_CAL_OVERRIDE
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST | ( | x | ) |
TRIM_USB2_REFBIAS_TST - TRIM_USB2_REFBIAS_TST
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ | ( | x | ) |
TRIM_USB2_REFBIAS_VBGADJ - TRIM_USB2_REFBIAS_VBGADJ
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD | ( | x | ) |
TRIM_USB_REG_ENV_TAIL_ADJ_VD - TRIM_USB_REG_ENV_TAIL_ADJ_VD
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN | ( | x | ) |
TRIM_USBPHY_TX_CAL45DN - TRIM_USBPHY_TX_CAL45DN
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP | ( | x | ) |
TRIM_USBPHY_TX_CAL45DP - TRIM_USBPHY_TX_CAL45DP
| #define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL | ( | x | ) |
TRIM_USBPHY_TX_D_CAL - TRIM_USBPHY_TX_D_CAL
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP | ( | x | ) |
| #define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL | ( | x | ) |
| #define USBPHY_TX_CLR_D_CAL | ( | x | ) |
D_CAL - D_CAL
D_CAL - D_CAL
D_CAL - D_CAL
| #define USBPHY_TX_CLR_RSVD0 | ( | x | ) |
| #define USBPHY_TX_CLR_RSVD1 | ( | x | ) |
| #define USBPHY_TX_CLR_RSVD2 | ( | x | ) |
| #define USBPHY_TX_CLR_RSVD5 | ( | x | ) |
| #define USBPHY_TX_CLR_TXCAL45DN | ( | x | ) |
TXCAL45DN - TXCAL45DN
| #define USBPHY_TX_CLR_TXCAL45DP | ( | x | ) |
TXCAL45DP - TXCAL45DP
| #define USBPHY_TX_CLR_USBPHY_TX_EDGECTRL | ( | x | ) |
| #define USBPHY_TX_D_CAL | ( | x | ) |
D_CAL - D_CAL 0b0000..Maximum current, approximately 19% above nominal. 0b0111..Nominal 0b1111..Minimum current, approximately 19% below nominal.
| #define USBPHY_TX_RSVD0 | ( | x | ) |
| #define USBPHY_TX_RSVD1 | ( | x | ) |
| #define USBPHY_TX_RSVD2 | ( | x | ) |
| #define USBPHY_TX_RSVD5 | ( | x | ) |
| #define USBPHY_TX_SET_D_CAL | ( | x | ) |
D_CAL - D_CAL
D_CAL - D_CAL
D_CAL - D_CAL
| #define USBPHY_TX_SET_RSVD0 | ( | x | ) |
| #define USBPHY_TX_SET_RSVD1 | ( | x | ) |
| #define USBPHY_TX_SET_RSVD2 | ( | x | ) |
| #define USBPHY_TX_SET_RSVD5 | ( | x | ) |
| #define USBPHY_TX_SET_TXCAL45DN | ( | x | ) |
| #define USBPHY_TX_SET_TXCAL45DP | ( | x | ) |
| #define USBPHY_TX_SET_USBPHY_TX_EDGECTRL | ( | x | ) |
| #define USBPHY_TX_TOG_D_CAL | ( | x | ) |
D_CAL - D_CAL
D_CAL - D_CAL
D_CAL - D_CAL
| #define USBPHY_TX_TOG_RSVD0 | ( | x | ) |
| #define USBPHY_TX_TOG_RSVD1 | ( | x | ) |
| #define USBPHY_TX_TOG_RSVD2 | ( | x | ) |
| #define USBPHY_TX_TOG_RSVD5 | ( | x | ) |
| #define USBPHY_TX_TOG_TXCAL45DN | ( | x | ) |
| #define USBPHY_TX_TOG_TXCAL45DP | ( | x | ) |
| #define USBPHY_TX_TOG_USBPHY_TX_EDGECTRL | ( | x | ) |
| #define USBPHY_TX_TXCAL45DN | ( | x | ) |
| #define USBPHY_TX_TXCAL45DP | ( | x | ) |
| #define USBPHY_TX_USBPHY_TX_EDGECTRL | ( | x | ) |
| #define USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED | ( | x | ) |
CHRG_DETECTED - Battery Charging Primary Detection phase output 0b0..Standard Downstream Port (SDP) has been detected 0b1..Charging Port has been detected
| #define USBPHY_USB1_CHRG_DET_STAT_DN_STATE | ( | x | ) |
DN_STATE - DN_STATE 0b0..DN pin voltage is < 0.8V 0b1..DN pin voltage is > 2.0V
| #define USBPHY_USB1_CHRG_DET_STAT_DP_STATE | ( | x | ) |
DP_STATE - DP_STATE 0b0..DP pin voltage is < 0.8V 0b1..DP pin voltage is > 2.0V
| #define USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT | ( | x | ) |
PLUG_CONTACT - Battery Charging Data Contact Detection phase output 0b0..No USB cable attachment has been detected 0b1..A USB cable attachment between the device and host has been detected
| #define USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP | ( | x | ) |
SECDET_DCP - Battery Charging Secondary Detection phase output 0b0..Charging Downstream Port (CDP) has been detected 0b1..Downstream Charging Port (DCP) has been detected
| #define USBPHY_USB1_CHRG_DETECT_BGR_BIAS | ( | x | ) |
BGR_BIAS - BGR_BIAS 0b0..Use local bias powered from USB1_VBUS for 10uA reference (Default) 0b1..Use bandgap bias powered from VREGIN0/VREGIN1 for 10uA reference
| #define USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS | ( | x | ) |
BGR_BIAS - BGR_BIAS
BGR_BIAS - BGR_BIAS
| #define USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP | ( | x | ) |
PULLUP_DP - PULLUP_DP
| #define USBPHY_USB1_CHRG_DETECT_PULLUP_DP | ( | x | ) |
| #define USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS | ( | x | ) |
BGR_BIAS - BGR_BIAS
BGR_BIAS - BGR_BIAS
| #define USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP | ( | x | ) |
| #define USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS | ( | x | ) |
BGR_BIAS - BGR_BIAS
BGR_BIAS - BGR_BIAS
| #define USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN | ( | x | ) |
TSTI_HSFS_MODE_EN - TSTI_HSFS_MODE_EN
| #define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN | ( | x | ) |
TSTI_TX_EN - TSTI_TX_EN
| #define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ | ( | x | ) |
TSTI_TX_HIZ - TSTI_TX_HIZ
| #define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE | ( | x | ) |
TSTI_TX_HS_MODE - TSTI_TX_HS_MODE
| #define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE | ( | x | ) |
TSTI_TX_LS_MODE - TSTI_TX_LS_MODE
| #define USBPHY_USB1_LOOPBACK_CLR_TSTPKT | ( | x | ) |
TSTPKT - TSTPKT
TSTPKT - TSTPKT
| #define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0 | ( | x | ) |
UTMI_DIG_TST0 - UTMI_DIG_TST0
| #define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1 | ( | x | ) |
UTMI_DIG_TST1 - UTMI_DIG_TST1
| #define USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART | ( | x | ) |
UTMI_TESTSTART - UTMI_TESTSTART
| #define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0 | ( | x | ) |
UTMO_DIG_TST0 - UTMO_DIG_TST0
| #define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1 | ( | x | ) |
UTMO_DIG_TST1 - UTMO_DIG_TST1
| #define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER | ( | x | ) |
TSTI_FS_NUMBER - TSTI_FS_NUMBER
| #define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER | ( | x | ) |
TSTI_HS_NUMBER - TSTI_HS_NUMBER
| #define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_SET_TSTPKT | ( | x | ) |
TSTPKT - TSTPKT
TSTPKT - TSTPKT
| #define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0 | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1 | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0 | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1 | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TOG_TSTPKT | ( | x | ) |
TSTPKT - TSTPKT
TSTPKT - TSTPKT
| #define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0 | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1 | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0 | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1 | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TSTI_TX_EN | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_TSTPKT | ( | x | ) |
TSTPKT - TSTPKT
TSTPKT - TSTPKT
| #define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0 | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1 | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_UTMI_TESTSTART | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0 | ( | x | ) |
| #define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1 | ( | x | ) |
| #define USBPHY_USB1_VBUS_DET_STAT_AVALID | ( | x | ) |
AVALID - A-Device Session Valid status 0b0..The VBUS voltage is below the Session Valid threshold 0b1..The VBUS voltage is above the Session Valid threshold
| #define USBPHY_USB1_VBUS_DET_STAT_BVALID | ( | x | ) |
BVALID - B-Device Session Valid status 0b0..The VBUS voltage is below the Session Valid threshold 0b1..The VBUS voltage is above the Session Valid threshold
| #define USBPHY_USB1_VBUS_DET_STAT_SESSEND | ( | x | ) |
SESSEND - Session End indicator 0b0..The VBUS voltage is above the Session Valid threshold 0b1..The VBUS voltage is below the Session Valid threshold
| #define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID | ( | x | ) |
VBUS_VALID - VBUS voltage status 0b0..VBUS is below the comparator threshold 0b1..VBUS is above the comparator threshold
| #define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V | ( | x | ) |
VBUS_VALID_3V - VBUS_VALID_3V detector status 0b0..VBUS voltage is below VBUS_VALID_3V threshold 0b1..VBUS voltage is above VBUS_VALID_3V threshold
| #define USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE | ( | x | ) |
AVALID_OVERRIDE - Override value for A-Device Session Valid
| #define USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE | ( | x | ) |
BVALID_OVERRIDE - Override value for B-Device Session Valid
| #define USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS | ( | x | ) |
DISCHARGE_VBUS - Controls VBUS discharge resistor
| #define USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR | ( | x | ) |
EN_CHARGER_RESISTOR - Enables resistors used for an older method of resistive battery charger detection
| #define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE | ( | x | ) |
ID_OVERRIDE - TBA
ID_OVERRIDE - TBA
| #define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN | ( | x | ) |
ID_OVERRIDE_EN - TBA
| #define USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS | ( | x | ) |
PWRUP_CMPS - Enables the VBUS_VALID comparator
| #define USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE | ( | x | ) |
SESSEND_OVERRIDE - Override value for SESSEND
| #define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN | ( | x | ) |
VBUS_OVERRIDE_EN - VBUS detect signal override enable
| #define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL | ( | x | ) |
VBUS_SOURCE_SEL - Selects the source of the VBUS_VALID signal reported to the USB controller
| #define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE | ( | x | ) |
VBUSVALID_OVERRIDE - Override value for VBUS_VALID signal sent to USB controller
| #define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL | ( | x | ) |
VBUSVALID_SEL - Selects the source of the VBUS_VALID signal reported to the USB controller
| #define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH | ( | x | ) |
VBUSVALID_THRESH - VBUSVALID_THRESH
| #define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID | ( | x | ) |
VBUSVALID_TO_SESSVALID - Selects the comparator used for VBUS_VALID
| #define USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS | ( | x | ) |
DISCHARGE_VBUS - Controls VBUS discharge resistor 0b0..VBUS discharge resistor is disabled (Default) 0b1..VBUS discharge resistor is enabled
| #define USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR | ( | x | ) |
EN_CHARGER_RESISTOR - Enables resistors used for an older method of resistive battery charger detection 0b0..Disable resistive charger detection resistors on DP and DP 0b1..Enable resistive charger detection resistors on DP and DP
| #define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE | ( | x | ) |
ID_OVERRIDE - TBA
ID_OVERRIDE - TBA
| #define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS | ( | x | ) |
PWRUP_CMPS - Enables the VBUS_VALID comparator 0b000..Powers down the VBUS_VALID comparator 0b001..Enables the SESS_VALID comparator (default) 0b010..Enables the 3Vdetect (default)
| #define USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE | ( | x | ) |
ID_OVERRIDE - TBA
ID_OVERRIDE - TBA
| #define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE | ( | x | ) |
ID_OVERRIDE - TBA
ID_OVERRIDE - TBA
| #define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN | ( | x | ) |
VBUS_OVERRIDE_EN - VBUS detect signal override enable 0b0..Use the results of the internal VBUS_VALID and Session Valid comparators for VBUS_VALID, AVALID, BVALID, and SESSEND (Default) 0b1..Use the override values for VBUS_VALID, AVALID, BVALID, and SESSEND
| #define USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL | ( | x | ) |
VBUS_SOURCE_SEL - Selects the source of the VBUS_VALID signal reported to the USB controller 0b00..Use the VBUS_VALID comparator results for signal reported to the USB controller (Default) 0b01..Use the Session Valid comparator results for signal reported to the USB controller 0b10..Use the Session Valid comparator results for signal reported to the USB controller 0b11..Reserved, do not use
| #define USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE | ( | x | ) |
| #define USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL | ( | x | ) |
VBUSVALID_SEL - Selects the source of the VBUS_VALID signal reported to the USB controller 0b0..Use the VBUS_VALID comparator results for signal reported to the USB controller (Default) 0b1..Use the VBUS_VALID_3V detector results for signal reported to the USB controller
| #define USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH | ( | x | ) |
VBUSVALID_THRESH - VBUSVALID_THRESH 0b000..4.0 V 0b001..4.1 V 0b010..4.2 V 0b011..4.3 V 0b100..4.4 V (Default) 0b101..4.5 V 0b110..4.6 V 0b111..4.7 V
| #define USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID | ( | x | ) |
VBUSVALID_TO_SESSVALID - Selects the comparator used for VBUS_VALID 0b0..Use the VBUS_VALID comparator for VBUS_VALID results 0b1..Use the Session End comparator for VBUS_VALID results. The Session End threshold is >0.8V and <4.0V.
| #define USBPHY_VERSION_MAJOR | ( | x | ) |
MAJOR - MAJOR
MAJOR - MAJOR
MAJOR - MAJOR
| #define USBPHY_VERSION_MINOR | ( | x | ) |
MINOR - MINOR
MINOR - MINOR
MINOR - MINOR
| #define USBPHY_VERSION_STEP | ( | x | ) |
STEP - STEP
STEP - STEP
STEP - STEP
