RTEMS 6.3
| struct | ALT_16550_HANDLE_s |
Typedefs | |
| typedef enum ALT_16550_DEVICE_e | ALT_16550_DEVICE_t |
| typedef struct ALT_16550_HANDLE_s | ALT_16550_HANDLE_t |
Enumerations | |
| enum | ALT_16550_DEVICE_e { ALT_16550_DEVICE_SOCFPGA_UART0 = 0 , ALT_16550_DEVICE_SOCFPGA_UART1 = 1 , ALT_16550_DEVICE_ALTERA_16550_UART = 0x100 } |
| ALT_STATUS_CODE | alt_16550_init (ALT_16550_DEVICE_t device, void *location, alt_freq_t clock_freq, ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_uninit (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_reset (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_enable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_disable (ALT_16550_HANDLE_t *handle) |
| ALT_STATUS_CODE | alt_16550_read (ALT_16550_HANDLE_t *handle, char *item) |
| ALT_STATUS_CODE | alt_16550_write (ALT_16550_HANDLE_t *handle, char item) |
This group of APIs provides basic access to the UART to initialize, uninitialize, read, write, and reset the UART.
| typedef enum ALT_16550_DEVICE_e ALT_16550_DEVICE_t |
This type definition enumerates the list of UARTs available on the system.
| typedef struct ALT_16550_HANDLE_s ALT_16550_HANDLE_t |
This structure is used to represent a handle to a specific UART on the system. The internal members are undocumented and should be not altered outside of this API.
| ALT_STATUS_CODE alt_16550_disable | ( | ALT_16550_HANDLE_t * | handle | ) |
Stops the UART. While UART configuration can be done while enabled, it is not recommended.
| handle | The UART device handle. |
| ALT_E_SUCCESS | The operation was successful. |
| ALT_E_ERROR | The operation failed. |
| ALT_E_BAD_ARG | The given UART device handle is invalid. |
| ALT_STATUS_CODE alt_16550_enable | ( | ALT_16550_HANDLE_t * | handle | ) |
Starts the UART after all configuration has been completed.
| ALT_STATUS_CODE alt_16550_init | ( | ALT_16550_DEVICE_t | device, |
| void * | location, | ||
| alt_freq_t | clock_freq, | ||
| ALT_16550_HANDLE_t * | handle ) |
Performs the initialization steps needed by the UART. This should be the first API call made when accessing a particular UART
The default UART setting is 8 databits, no parity, 1 stopbit, and 57600 baud.
For the SoCFPGA UARTs, The ALT_CLK_L4_SP clock needs to be setup before initialization.
| device | The UART device identifier. |
| location | The memory of the location for the given UART. For SoCFPGA UARTs, this parameter is ignored. |
| clock_freq | The clock frequency of the serial clock for the given UART. For SoCFPGA UARTs, this paramter is ignored. |
| handle | [out] A pointer to a handle that will represent the UART. This handle should subsequently be used when calling other UART APIs. |
| ALT_E_BAD_ARG | The given UART device identifier is invalid. |
| ALT_E_BAD_CLK | The required clock is not yet setup. |
| ALT_STATUS_CODE alt_16550_read | ( | ALT_16550_HANDLE_t * | handle, |
| char * | item ) |
Reads a single character from the UART receiver buffer. This API should only be used when FIFOs are disabled.
| item | [out] Pointer to an output parameter that contains the in receiver buffer of the UART. |
| ALT_STATUS_CODE alt_16550_reset | ( | ALT_16550_HANDLE_t * | handle | ) |
Resets the UART to the default configuration. The UART will be reset and reinitialized.
| ALT_STATUS_CODE alt_16550_uninit | ( | ALT_16550_HANDLE_t * | handle | ) |
Performs the uninitialization steps for the UART. This should be the last API call made to cleanup the UART.
After calling this function, the handle will need to be initialized again before being used by calling alt_16550_init().
| ALT_STATUS_CODE alt_16550_write | ( | ALT_16550_HANDLE_t * | handle, |
| char | item ) |
Writes a single character to the UART transmitter buffer. This API should only be used when FIFOs are disabled.
| item | The character to write to the transmitter buffer of the UART. |
