RTEMS 6.3
This validation test suite provides enough resources to run tests for the directives of the Cache Manager. More...
Topics | |
| spec:/rtems/cache/val/cache | |
| Tests some Cache Manager directives. | |
| spec:/rtems/cache/val/cache-disable-data | |
| spec:/rtems/cache/val/cache-no-disable-data | |
Files | |
| file | testsuites/validation/ts-validation-cache.c |
| #define | CONFIGURE_MAXIMUM_PROCESSORS 4 |
| const char | rtems_test_name [] = "TestsuitesValidationCache" |
| Each test must define a test name string. | |
In SMP configurations, up to three scheduler instances using the SMP EDF scheduler are provided using up to four processors.
