RTEMS 6.3
This validation test suite is used to validate the default value of application configuration options taking the optional BSP provided settings into account. More...
Topics | |
| spec:/acfg/val/appl-does-not-need-clock-driver | |
| Tests the effect of the CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER application configuration option. | |
| spec:/acfg/val/default | |
| Tests the default values of application configuration options. | |
Files | |
| file | testsuites/validation/ts-validation-acfg-0.c |
| #define | CONFIGURE_IDLE_TASK_STORAGE_SIZE RTEMS_MINIMUM_STACK_SIZE |
| #define | CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION |
| #define | CONFIGURE_IDLE_TASK_BODY IdleBody |
| #define | CONFIGURE_INIT |
| void * | IdleBody (uintptr_t ignored) |
| const char | rtems_test_name [] = "TestsuitesValidationAcfg0" |
| Each test must define a test name string. | |
