RTEMS 6.3
spec:/testsuites/validation-0
This general purpose validation test suite provides enough resources to run basic tests for all specified managers and functions. More...
Topics
 spec:/acfg/val/appl-needs-clock-driver
 Tests the effect of the CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER application configuration option.
 spec:/rtems/event/req/send-receive
 spec:/rtems/event/val/send-receive
 Tests the rtems_event_send() and rtems_event_receive() directives.
 spec:/rtems/event/val/system-send-receive
 Tests the rtems_event_system_send() and rtems_event_system_receive() directives.
 spec:/score/thread/val/idle-body-no-return
 Tests thread idle body behaviour.
file  testsuites/validation/ts-validation-0.c
#define CONFIGURE_MAXIMUM_PROCESSORS   5
const char rtems_test_name [] = "TestsuitesValidation0"
 Each test must define a test name string.
In SMP configurations, up to three scheduler instances using the SMP EDF scheduler are provided using up to four processors.
