RTEMS 6.3
spec:/testsuites/bsps/fatal-sparc-leon3-cache-snooping-disabled-boot
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
Topics
 spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-boot
 Tests a fatal error.
file  testsuites/validation/bsps/ts-fatal-sparc-leon3-cache-snooping-disabled-boot.c
#define FATAL_SYSINIT_RUN   BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Run
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
const char rtems_test_name [] = "TestsuitesBspsFatalSparcLeon3CacheSnoopingDisabledBoot"
 Each test must define a test name string.
