RTEMS 6.3
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
Topics | |
| spec:/dev/clock/xil-ttc/val/fatal-irq-install | |
| Tests a fatal error. | |
Files | |
| file | testsuites/validation/bsps/ts-fatal-clock-xil-ttc-irq-install.c |
| #define | FATAL_SYSINIT_RUN DevClockXilTtcValFatalIrqInstall_Run |
| #define | CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER |
| const char | rtems_test_name [] = "TestsuitesBspsFatalClockXilTtcIrqInstall" |
| Each test must define a test name string. | |
