RTEMS 6.3
TEMPSENSE0 - Tempsensor Control Register 0
#define TEMPMON_TEMPSENSE0_POWER_DOWN_MASK   (0x1U)
#define TEMPMON_TEMPSENSE0_POWER_DOWN_SHIFT   (0U)
#define TEMPMON_TEMPSENSE0_POWER_DOWN(x)
#define TEMPMON_TEMPSENSE0_MEASURE_TEMP_MASK   (0x2U)
#define TEMPMON_TEMPSENSE0_MEASURE_TEMP_SHIFT   (1U)
#define TEMPMON_TEMPSENSE0_MEASURE_TEMP(x)
#define TEMPMON_TEMPSENSE0_FINISHED_MASK   (0x4U)
#define TEMPMON_TEMPSENSE0_FINISHED_SHIFT   (2U)
#define TEMPMON_TEMPSENSE0_FINISHED(x)
#define TEMPMON_TEMPSENSE0_TEMP_CNT_MASK   (0xFFF00U)
#define TEMPMON_TEMPSENSE0_TEMP_CNT_SHIFT   (8U)
#define TEMPMON_TEMPSENSE0_TEMP_CNT(x)
#define TEMPMON_TEMPSENSE0_ALARM_VALUE_MASK   (0xFFF00000U)
#define TEMPMON_TEMPSENSE0_ALARM_VALUE_SHIFT   (20U)
#define TEMPMON_TEMPSENSE0_ALARM_VALUE(x)
TEMPSENSE0_SET - Tempsensor Control Register 0
#define TEMPMON_TEMPSENSE0_SET_POWER_DOWN_MASK   (0x1U)
#define TEMPMON_TEMPSENSE0_SET_POWER_DOWN_SHIFT   (0U)
#define TEMPMON_TEMPSENSE0_SET_POWER_DOWN(x)
#define TEMPMON_TEMPSENSE0_SET_MEASURE_TEMP_MASK   (0x2U)
#define TEMPMON_TEMPSENSE0_SET_MEASURE_TEMP_SHIFT   (1U)
#define TEMPMON_TEMPSENSE0_SET_MEASURE_TEMP(x)
#define TEMPMON_TEMPSENSE0_SET_FINISHED_MASK   (0x4U)
#define TEMPMON_TEMPSENSE0_SET_FINISHED_SHIFT   (2U)
#define TEMPMON_TEMPSENSE0_SET_FINISHED(x)
#define TEMPMON_TEMPSENSE0_SET_TEMP_CNT_MASK   (0xFFF00U)
#define TEMPMON_TEMPSENSE0_SET_TEMP_CNT_SHIFT   (8U)
#define TEMPMON_TEMPSENSE0_SET_TEMP_CNT(x)
#define TEMPMON_TEMPSENSE0_SET_ALARM_VALUE_MASK   (0xFFF00000U)
#define TEMPMON_TEMPSENSE0_SET_ALARM_VALUE_SHIFT   (20U)
#define TEMPMON_TEMPSENSE0_SET_ALARM_VALUE(x)
TEMPSENSE0_CLR - Tempsensor Control Register 0
#define TEMPMON_TEMPSENSE0_CLR_POWER_DOWN_MASK   (0x1U)
#define TEMPMON_TEMPSENSE0_CLR_POWER_DOWN_SHIFT   (0U)
#define TEMPMON_TEMPSENSE0_CLR_POWER_DOWN(x)
#define TEMPMON_TEMPSENSE0_CLR_MEASURE_TEMP_MASK   (0x2U)
#define TEMPMON_TEMPSENSE0_CLR_MEASURE_TEMP_SHIFT   (1U)
#define TEMPMON_TEMPSENSE0_CLR_MEASURE_TEMP(x)
#define TEMPMON_TEMPSENSE0_CLR_FINISHED_MASK   (0x4U)
#define TEMPMON_TEMPSENSE0_CLR_FINISHED_SHIFT   (2U)
#define TEMPMON_TEMPSENSE0_CLR_FINISHED(x)
#define TEMPMON_TEMPSENSE0_CLR_TEMP_CNT_MASK   (0xFFF00U)
#define TEMPMON_TEMPSENSE0_CLR_TEMP_CNT_SHIFT   (8U)
#define TEMPMON_TEMPSENSE0_CLR_TEMP_CNT(x)
#define TEMPMON_TEMPSENSE0_CLR_ALARM_VALUE_MASK   (0xFFF00000U)
#define TEMPMON_TEMPSENSE0_CLR_ALARM_VALUE_SHIFT   (20U)
#define TEMPMON_TEMPSENSE0_CLR_ALARM_VALUE(x)
TEMPSENSE0_TOG - Tempsensor Control Register 0
#define TEMPMON_TEMPSENSE0_TOG_POWER_DOWN_MASK   (0x1U)
#define TEMPMON_TEMPSENSE0_TOG_POWER_DOWN_SHIFT   (0U)
#define TEMPMON_TEMPSENSE0_TOG_POWER_DOWN(x)
#define TEMPMON_TEMPSENSE0_TOG_MEASURE_TEMP_MASK   (0x2U)
#define TEMPMON_TEMPSENSE0_TOG_MEASURE_TEMP_SHIFT   (1U)
#define TEMPMON_TEMPSENSE0_TOG_MEASURE_TEMP(x)
#define TEMPMON_TEMPSENSE0_TOG_FINISHED_MASK   (0x4U)
#define TEMPMON_TEMPSENSE0_TOG_FINISHED_SHIFT   (2U)
#define TEMPMON_TEMPSENSE0_TOG_FINISHED(x)
#define TEMPMON_TEMPSENSE0_TOG_TEMP_CNT_MASK   (0xFFF00U)
#define TEMPMON_TEMPSENSE0_TOG_TEMP_CNT_SHIFT   (8U)
#define TEMPMON_TEMPSENSE0_TOG_TEMP_CNT(x)
#define TEMPMON_TEMPSENSE0_TOG_ALARM_VALUE_MASK   (0xFFF00000U)
#define TEMPMON_TEMPSENSE0_TOG_ALARM_VALUE_SHIFT   (20U)
#define TEMPMON_TEMPSENSE0_TOG_ALARM_VALUE(x)
TEMPSENSE1 - Tempsensor Control Register 1
#define TEMPMON_TEMPSENSE1_MEASURE_FREQ_MASK   (0xFFFFU)
#define TEMPMON_TEMPSENSE1_MEASURE_FREQ_SHIFT   (0U)
#define TEMPMON_TEMPSENSE1_MEASURE_FREQ(x)
TEMPSENSE1_SET - Tempsensor Control Register 1
#define TEMPMON_TEMPSENSE1_SET_MEASURE_FREQ_MASK   (0xFFFFU)
#define TEMPMON_TEMPSENSE1_SET_MEASURE_FREQ_SHIFT   (0U)
#define TEMPMON_TEMPSENSE1_SET_MEASURE_FREQ(x)
TEMPSENSE1_CLR - Tempsensor Control Register 1
#define TEMPMON_TEMPSENSE1_CLR_MEASURE_FREQ_MASK   (0xFFFFU)
#define TEMPMON_TEMPSENSE1_CLR_MEASURE_FREQ_SHIFT   (0U)
#define TEMPMON_TEMPSENSE1_CLR_MEASURE_FREQ(x)
TEMPSENSE1_TOG - Tempsensor Control Register 1
#define TEMPMON_TEMPSENSE1_TOG_MEASURE_FREQ_MASK   (0xFFFFU)
#define TEMPMON_TEMPSENSE1_TOG_MEASURE_FREQ_SHIFT   (0U)
#define TEMPMON_TEMPSENSE1_TOG_MEASURE_FREQ(x)
TEMPSENSE2 - Tempsensor Control Register 2
#define TEMPMON_TEMPSENSE2_LOW_ALARM_VALUE_MASK   (0xFFFU)
#define TEMPMON_TEMPSENSE2_LOW_ALARM_VALUE_SHIFT   (0U)
#define TEMPMON_TEMPSENSE2_LOW_ALARM_VALUE(x)
#define TEMPMON_TEMPSENSE2_PANIC_ALARM_VALUE_MASK   (0xFFF0000U)
#define TEMPMON_TEMPSENSE2_PANIC_ALARM_VALUE_SHIFT   (16U)
#define TEMPMON_TEMPSENSE2_PANIC_ALARM_VALUE(x)
TEMPSENSE2_SET - Tempsensor Control Register 2
#define TEMPMON_TEMPSENSE2_SET_LOW_ALARM_VALUE_MASK   (0xFFFU)
#define TEMPMON_TEMPSENSE2_SET_LOW_ALARM_VALUE_SHIFT   (0U)
#define TEMPMON_TEMPSENSE2_SET_LOW_ALARM_VALUE(x)
#define TEMPMON_TEMPSENSE2_SET_PANIC_ALARM_VALUE_MASK   (0xFFF0000U)
#define TEMPMON_TEMPSENSE2_SET_PANIC_ALARM_VALUE_SHIFT   (16U)
#define TEMPMON_TEMPSENSE2_SET_PANIC_ALARM_VALUE(x)
TEMPSENSE2_CLR - Tempsensor Control Register 2
#define TEMPMON_TEMPSENSE2_CLR_LOW_ALARM_VALUE_MASK   (0xFFFU)
#define TEMPMON_TEMPSENSE2_CLR_LOW_ALARM_VALUE_SHIFT   (0U)
#define TEMPMON_TEMPSENSE2_CLR_LOW_ALARM_VALUE(x)
#define TEMPMON_TEMPSENSE2_CLR_PANIC_ALARM_VALUE_MASK   (0xFFF0000U)
#define TEMPMON_TEMPSENSE2_CLR_PANIC_ALARM_VALUE_SHIFT   (16U)
#define TEMPMON_TEMPSENSE2_CLR_PANIC_ALARM_VALUE(x)
TEMPSENSE2_TOG - Tempsensor Control Register 2
#define TEMPMON_TEMPSENSE2_TOG_LOW_ALARM_VALUE_MASK   (0xFFFU)
#define TEMPMON_TEMPSENSE2_TOG_LOW_ALARM_VALUE_SHIFT   (0U)
#define TEMPMON_TEMPSENSE2_TOG_LOW_ALARM_VALUE(x)
#define TEMPMON_TEMPSENSE2_TOG_PANIC_ALARM_VALUE_MASK   (0xFFF0000U)
#define TEMPMON_TEMPSENSE2_TOG_PANIC_ALARM_VALUE_SHIFT   (16U)
#define TEMPMON_TEMPSENSE2_TOG_PANIC_ALARM_VALUE(x)
◆ TEMPMON_TEMPSENSE0_ALARM_VALUE
#define TEMPMON_TEMPSENSE0_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE0_ALARM_VALUE_MASK)
◆ TEMPMON_TEMPSENSE0_CLR_ALARM_VALUE
#define TEMPMON_TEMPSENSE0_CLR_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_CLR_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE0_CLR_ALARM_VALUE_MASK)
◆ TEMPMON_TEMPSENSE0_CLR_FINISHED
#define TEMPMON_TEMPSENSE0_CLR_FINISHED ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_CLR_FINISHED_SHIFT)) & TEMPMON_TEMPSENSE0_CLR_FINISHED_MASK)
FINISHED 0b0..Last measurement is not ready yet. 0b1..Last measurement is valid.
◆ TEMPMON_TEMPSENSE0_CLR_MEASURE_TEMP
#define TEMPMON_TEMPSENSE0_CLR_MEASURE_TEMP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_CLR_MEASURE_TEMP_SHIFT)) & TEMPMON_TEMPSENSE0_CLR_MEASURE_TEMP_MASK)
MEASURE_TEMP 0b0..Do not start the measurement process. 0b1..Start the measurement process.
◆ TEMPMON_TEMPSENSE0_CLR_POWER_DOWN
#define TEMPMON_TEMPSENSE0_CLR_POWER_DOWN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_CLR_POWER_DOWN_SHIFT)) & TEMPMON_TEMPSENSE0_CLR_POWER_DOWN_MASK)
POWER_DOWN 0b0..Enable power to the temperature sensor. 0b1..Power down the temperature sensor.
◆ TEMPMON_TEMPSENSE0_CLR_TEMP_CNT
#define TEMPMON_TEMPSENSE0_CLR_TEMP_CNT ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_CLR_TEMP_CNT_SHIFT)) & TEMPMON_TEMPSENSE0_CLR_TEMP_CNT_MASK)
◆ TEMPMON_TEMPSENSE0_FINISHED
#define TEMPMON_TEMPSENSE0_FINISHED ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_FINISHED_SHIFT)) & TEMPMON_TEMPSENSE0_FINISHED_MASK)
◆ TEMPMON_TEMPSENSE0_MEASURE_TEMP
#define TEMPMON_TEMPSENSE0_MEASURE_TEMP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_MEASURE_TEMP_SHIFT)) & TEMPMON_TEMPSENSE0_MEASURE_TEMP_MASK)
◆ TEMPMON_TEMPSENSE0_POWER_DOWN
#define TEMPMON_TEMPSENSE0_POWER_DOWN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_POWER_DOWN_SHIFT)) & TEMPMON_TEMPSENSE0_POWER_DOWN_MASK)
◆ TEMPMON_TEMPSENSE0_SET_ALARM_VALUE
#define TEMPMON_TEMPSENSE0_SET_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_SET_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE0_SET_ALARM_VALUE_MASK)
◆ TEMPMON_TEMPSENSE0_SET_FINISHED
#define TEMPMON_TEMPSENSE0_SET_FINISHED ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_SET_FINISHED_SHIFT)) & TEMPMON_TEMPSENSE0_SET_FINISHED_MASK)
◆ TEMPMON_TEMPSENSE0_SET_MEASURE_TEMP
#define TEMPMON_TEMPSENSE0_SET_MEASURE_TEMP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_SET_MEASURE_TEMP_SHIFT)) & TEMPMON_TEMPSENSE0_SET_MEASURE_TEMP_MASK)
◆ TEMPMON_TEMPSENSE0_SET_POWER_DOWN
#define TEMPMON_TEMPSENSE0_SET_POWER_DOWN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_SET_POWER_DOWN_SHIFT)) & TEMPMON_TEMPSENSE0_SET_POWER_DOWN_MASK)
◆ TEMPMON_TEMPSENSE0_SET_TEMP_CNT
#define TEMPMON_TEMPSENSE0_SET_TEMP_CNT ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_SET_TEMP_CNT_SHIFT)) & TEMPMON_TEMPSENSE0_SET_TEMP_CNT_MASK)
◆ TEMPMON_TEMPSENSE0_TEMP_CNT
#define TEMPMON_TEMPSENSE0_TEMP_CNT ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_TEMP_CNT_SHIFT)) & TEMPMON_TEMPSENSE0_TEMP_CNT_MASK)
◆ TEMPMON_TEMPSENSE0_TOG_ALARM_VALUE
#define TEMPMON_TEMPSENSE0_TOG_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_TOG_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE0_TOG_ALARM_VALUE_MASK)
◆ TEMPMON_TEMPSENSE0_TOG_FINISHED
#define TEMPMON_TEMPSENSE0_TOG_FINISHED ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_TOG_FINISHED_SHIFT)) & TEMPMON_TEMPSENSE0_TOG_FINISHED_MASK)
◆ TEMPMON_TEMPSENSE0_TOG_MEASURE_TEMP
#define TEMPMON_TEMPSENSE0_TOG_MEASURE_TEMP ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_TOG_MEASURE_TEMP_SHIFT)) & TEMPMON_TEMPSENSE0_TOG_MEASURE_TEMP_MASK)
◆ TEMPMON_TEMPSENSE0_TOG_POWER_DOWN
#define TEMPMON_TEMPSENSE0_TOG_POWER_DOWN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_TOG_POWER_DOWN_SHIFT)) & TEMPMON_TEMPSENSE0_TOG_POWER_DOWN_MASK)
◆ TEMPMON_TEMPSENSE0_TOG_TEMP_CNT
#define TEMPMON_TEMPSENSE0_TOG_TEMP_CNT ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE0_TOG_TEMP_CNT_SHIFT)) & TEMPMON_TEMPSENSE0_TOG_TEMP_CNT_MASK)
◆ TEMPMON_TEMPSENSE1_CLR_MEASURE_FREQ
#define TEMPMON_TEMPSENSE1_CLR_MEASURE_FREQ ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE1_CLR_MEASURE_FREQ_SHIFT)) & TEMPMON_TEMPSENSE1_CLR_MEASURE_FREQ_MASK)
MEASURE_FREQ 0b0000000000000000..Defines a single measurement with no repeat. 0b0000000000000001..Updates the temperature value at a RTC clock rate. 0b0000000000000010..Updates the temperature value at a RTC/2 clock rate. 0b1111111111111111..Determines a two second sample period with a 32.768KHz RTC clock. Exact timings depend on the accuracy of the RTC clock.
◆ TEMPMON_TEMPSENSE1_MEASURE_FREQ
#define TEMPMON_TEMPSENSE1_MEASURE_FREQ ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE1_MEASURE_FREQ_SHIFT)) & TEMPMON_TEMPSENSE1_MEASURE_FREQ_MASK)
◆ TEMPMON_TEMPSENSE1_SET_MEASURE_FREQ
#define TEMPMON_TEMPSENSE1_SET_MEASURE_FREQ ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE1_SET_MEASURE_FREQ_SHIFT)) & TEMPMON_TEMPSENSE1_SET_MEASURE_FREQ_MASK)
◆ TEMPMON_TEMPSENSE1_TOG_MEASURE_FREQ
#define TEMPMON_TEMPSENSE1_TOG_MEASURE_FREQ ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE1_TOG_MEASURE_FREQ_SHIFT)) & TEMPMON_TEMPSENSE1_TOG_MEASURE_FREQ_MASK)
◆ TEMPMON_TEMPSENSE2_CLR_LOW_ALARM_VALUE
#define TEMPMON_TEMPSENSE2_CLR_LOW_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE2_CLR_LOW_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE2_CLR_LOW_ALARM_VALUE_MASK)
◆ TEMPMON_TEMPSENSE2_CLR_PANIC_ALARM_VALUE
#define TEMPMON_TEMPSENSE2_CLR_PANIC_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE2_CLR_PANIC_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE2_CLR_PANIC_ALARM_VALUE_MASK)
◆ TEMPMON_TEMPSENSE2_LOW_ALARM_VALUE
#define TEMPMON_TEMPSENSE2_LOW_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE2_LOW_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE2_LOW_ALARM_VALUE_MASK)
◆ TEMPMON_TEMPSENSE2_PANIC_ALARM_VALUE
#define TEMPMON_TEMPSENSE2_PANIC_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE2_PANIC_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE2_PANIC_ALARM_VALUE_MASK)
◆ TEMPMON_TEMPSENSE2_SET_LOW_ALARM_VALUE
#define TEMPMON_TEMPSENSE2_SET_LOW_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE2_SET_LOW_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE2_SET_LOW_ALARM_VALUE_MASK)
◆ TEMPMON_TEMPSENSE2_SET_PANIC_ALARM_VALUE
#define TEMPMON_TEMPSENSE2_SET_PANIC_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE2_SET_PANIC_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE2_SET_PANIC_ALARM_VALUE_MASK)
◆ TEMPMON_TEMPSENSE2_TOG_LOW_ALARM_VALUE
#define TEMPMON_TEMPSENSE2_TOG_LOW_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE2_TOG_LOW_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE2_TOG_LOW_ALARM_VALUE_MASK)
◆ TEMPMON_TEMPSENSE2_TOG_PANIC_ALARM_VALUE
#define TEMPMON_TEMPSENSE2_TOG_PANIC_ALARM_VALUE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << TEMPMON_TEMPSENSE2_TOG_PANIC_ALARM_VALUE_SHIFT)) & TEMPMON_TEMPSENSE2_TOG_PANIC_ALARM_VALUE_MASK)
