RTEMS 6.3
Tests properties of thread-local objects. More...
file  testsuites/validation/tc-score-thread-tls.c
 T_TEST_CASE (ScoreThreadValTls)
This test case performs the following actions:
  • The test action is carried out by the thread-local objects definition.
    • Check that the initial value of the zero initialized thread-local object has the expected value.
    • Check that the alignment of the zero initialized thread-local object has the expected value.
    • Check that the initial value of the non-zero initialized thread-local object has the expected value.
    • Check that the alignment of the non-zero initialized thread-local object has the expected value.
