RTEMS 6.3
Tests the .preinit_array constructor handling of the C runtime support. More...
file  testsuites/validation/tc-preinit-array.c
 T_TEST_CASE (ScoreThreadValPreinitArray)
This test case performs the following actions:
  • Validate the .preinit_array constructor invocation. Mark that the test case executed.
    • Check that the .preinit_array constructor was called exactly once.
    • Check that the .preeinit_array construction was done by the Classic API user initialization task.
    • Check that the .preinit_array constructor was called before the global constructor invocations.
