RTEMS 6.3
Tests a fatal error caused by a too small idle thread stack size. More...
Files | |
| file | testsuites/validation/tr-fatal-idle-thread-stack-too-small.c |
| file | testsuites/validation/tr-fatal-idle-thread-stack-too-small.h |
| struct | ScoreThreadValFatalIdleThreadStackTooSmall_Context |
| Test context for spec:/score/thread/val/fatal-idle-thread-stack-too-small test case. More... | |
| void | ScoreThreadValFatalIdleThreadStackTooSmall_Run (rtems_fatal_source source, rtems_fatal_code code) |
| Runs the parameterized test case. | |
This test case performs the following actions:
| void ScoreThreadValFatalIdleThreadStackTooSmall_Run | ( | rtems_fatal_source | source, |
| rtems_fatal_code | code ) |
| source | is the fatal source. |
| code | is the fatal code. |
