RTEMS 6.3
Tests a fatal error. More...
Files | |
| file | testsuites/validation/tr-fatal-start-on-not-online-processor.c |
| file | testsuites/validation/tr-fatal-start-on-not-online-processor.h |
| struct | ScoreSmpValFatalStartOnNotOnlineProcessor_Context |
| Test context for spec:/score/smp/val/fatal-start-on-not-online-processor test case. More... | |
| bool | __real__CPU_SMP_Start_processor (uint32_t cpu_index) |
| bool | __wrap__CPU_SMP_Start_processor (uint32_t cpu_index) |
| void | ScoreSmpValFatalStartOnNotOnlineProcessor_Run (rtems_fatal_source source, rtems_fatal_code code) |
| Runs the parameterized test case. | |
This test case performs the following actions:
| void ScoreSmpValFatalStartOnNotOnlineProcessor_Run | ( | rtems_fatal_source | source, |
| rtems_fatal_code | code ) |
| source | is fatal source. |
| code | is fatal code. |
