RTEMS 6.3
__STATIC_INLINE void LL_SWPMI_EnableDMAReq_RX (SWPMI_TypeDef *SWPMIx)
 Enable DMA mode for reception @rmtoll CR RXDMA LL_SWPMI_EnableDMAReq_RX.
__STATIC_INLINE void LL_SWPMI_DisableDMAReq_RX (SWPMI_TypeDef *SWPMIx)
 Disable DMA mode for reception @rmtoll CR RXDMA LL_SWPMI_DisableDMAReq_RX.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledDMAReq_RX (SWPMI_TypeDef *SWPMIx)
 Check if DMA mode for reception is enabled @rmtoll CR RXDMA LL_SWPMI_IsEnabledDMAReq_RX.
__STATIC_INLINE void LL_SWPMI_EnableDMAReq_TX (SWPMI_TypeDef *SWPMIx)
 Enable DMA mode for transmission @rmtoll CR TXDMA LL_SWPMI_EnableDMAReq_TX.
__STATIC_INLINE void LL_SWPMI_DisableDMAReq_TX (SWPMI_TypeDef *SWPMIx)
 Disable DMA mode for transmission @rmtoll CR TXDMA LL_SWPMI_DisableDMAReq_TX.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledDMAReq_TX (SWPMI_TypeDef *SWPMIx)
 Check if DMA mode for transmission is enabled @rmtoll CR TXDMA LL_SWPMI_IsEnabledDMAReq_TX.
__STATIC_INLINE uint32_t LL_SWPMI_DMA_GetRegAddr (SWPMI_TypeDef *SWPMIx, uint32_t Direction)
 Get the data register address used for DMA transfer @rmtoll TDR TD LL_SWPMI_DMA_GetRegAddr
RDR RD LL_SWPMI_DMA_GetRegAddr.
◆ LL_SWPMI_DisableDMAReq_RX()
__STATIC_INLINE void LL_SWPMI_DisableDMAReq_RX ( SWPMI_TypeDef * SWPMIx)
Parameters
SWPMIxSWPMI Instance
Return values
None
◆ LL_SWPMI_DisableDMAReq_TX()
__STATIC_INLINE void LL_SWPMI_DisableDMAReq_TX ( SWPMI_TypeDef * SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_DMA_GetRegAddr()
__STATIC_INLINE uint32_t LL_SWPMI_DMA_GetRegAddr ( SWPMI_TypeDef * SWPMIx,
uint32_t Direction )
Parameters
DirectionThis parameter can be one of the following values:
Return values
Addressof data register
◆ LL_SWPMI_EnableDMAReq_RX()
__STATIC_INLINE void LL_SWPMI_EnableDMAReq_RX ( SWPMI_TypeDef * SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_EnableDMAReq_TX()
__STATIC_INLINE void LL_SWPMI_EnableDMAReq_TX ( SWPMI_TypeDef * SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_IsEnabledDMAReq_RX()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledDMAReq_RX ( SWPMI_TypeDef * SWPMIx)
Parameters
Return values
Stateof bit (1 or 0).
◆ LL_SWPMI_IsEnabledDMAReq_TX()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledDMAReq_TX ( SWPMI_TypeDef * SWPMIx)
Parameters
Return values
