RTEMS 6.3
#define SSARC_HP_SRAM0_COUNT   (1024U)
#define SSARC_HP_SRAM1_COUNT   (1024U)
#define SSARC_HP_SRAM2_COUNT   (1024U)
SRAM0 - Description Address Register
#define SSARC_HP_SRAM0_ADDR_MASK   (0xFFFFFFFFU)
#define SSARC_HP_SRAM0_ADDR_SHIFT   (0U)
#define SSARC_HP_SRAM0_ADDR(x)
SRAM1 - Description Data Register
#define SSARC_HP_SRAM1_DATA_MASK   (0xFFFFFFFFU)
#define SSARC_HP_SRAM1_DATA_SHIFT   (0U)
#define SSARC_HP_SRAM1_DATA(x)
SRAM2 - Description Control Register
#define SSARC_HP_SRAM2_TYPE_MASK   (0x7U)
#define SSARC_HP_SRAM2_TYPE_SHIFT   (0U)
#define SSARC_HP_SRAM2_TYPE(x)
#define SSARC_HP_SRAM2_SV_EN_MASK   (0x10U)
#define SSARC_HP_SRAM2_SV_EN_SHIFT   (4U)
#define SSARC_HP_SRAM2_SV_EN(x)
#define SSARC_HP_SRAM2_RT_EN_MASK   (0x20U)
#define SSARC_HP_SRAM2_RT_EN_SHIFT   (5U)
#define SSARC_HP_SRAM2_RT_EN(x)
#define SSARC_HP_SRAM2_SIZE_MASK   (0xC0U)
#define SSARC_HP_SRAM2_SIZE_SHIFT   (6U)
#define SSARC_HP_SRAM2_SIZE(x)
◆ SSARC_HP_SRAM0_ADDR [1/2]
#define SSARC_HP_SRAM0_ADDR ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM0_ADDR_SHIFT)) & SSARC_HP_SRAM0_ADDR_MASK)
ADDR - Address field
◆ SSARC_HP_SRAM0_ADDR [2/2]
Value:
◆ SSARC_HP_SRAM1_DATA [1/2]
#define SSARC_HP_SRAM1_DATA ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM1_DATA_SHIFT)) & SSARC_HP_SRAM1_DATA_MASK)
DATA - Data field
◆ SSARC_HP_SRAM1_DATA [2/2]
Value:
DATA - Data field
◆ SSARC_HP_SRAM2_RT_EN [1/2]
#define SSARC_HP_SRAM2_RT_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_RT_EN_SHIFT)) & SSARC_HP_SRAM2_RT_EN_MASK)
RT_EN - Restore Enable 0b0..Do not use this descriptor for the restore operation 0b1..Use this descriptor for the restore operation
◆ SSARC_HP_SRAM2_RT_EN [2/2]
Value:
◆ SSARC_HP_SRAM2_SIZE [1/2]
#define SSARC_HP_SRAM2_SIZE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_SIZE_SHIFT)) & SSARC_HP_SRAM2_SIZE_MASK)
SIZE - Size field 0b00..8-bit 0b01..16-bit 0b10..32-bit 0b11..Reserved
◆ SSARC_HP_SRAM2_SIZE [2/2]
Value:
◆ SSARC_HP_SRAM2_SV_EN [1/2]
#define SSARC_HP_SRAM2_SV_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_SV_EN_SHIFT)) & SSARC_HP_SRAM2_SV_EN_MASK)
SV_EN - Save Enable 0b0..Do not use this descriptor in the save operation 0b1..Use this descriptor in the save operation
◆ SSARC_HP_SRAM2_SV_EN [2/2]
Value:
◆ SSARC_HP_SRAM2_TYPE [1/2]
#define SSARC_HP_SRAM2_TYPE ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_TYPE_SHIFT)) & SSARC_HP_SRAM2_TYPE_MASK)
TYPE - Type field 0b000..SR 0b001..WO 0b010..RMW_OR 0b011..RMW_AND 0b100..DELAY 0b101..POLLING_0 0b110..POLLING_1 0b111..Reserved
◆ SSARC_HP_SRAM2_TYPE [2/2]
Value:
