RTEMS 6.3
Test the rtems_timer_ident() directive. More...
file  testsuites/validation/tc-timer-ident.c
#define NAME_LOCAL_OBJECT   rtems_build_name( 'T', 'I', 'M', 'R' )
 T_TEST_CASE (RtemsTimerValIdent)
This test case performs the following actions:
  • Run the generic object identification tests for Classic API timer class objects defined by spec:/rtems/req/ident-local.
