RTEMS 6.3
file  testsuites/validation/tc-timer-reset.c
struct  RtemsTimerReqReset_Entry
struct  RtemsTimerReqReset_Context
 Test context for spec:/rtems/timer/req/reset test case. More...
struct  RtemsTimerReqReset_Context::[struct].Map
enum  RtemsTimerReqReset_Pre_Id { RtemsTimerReqReset_Pre_Id_Valid , RtemsTimerReqReset_Pre_Id_Invalid , RtemsTimerReqReset_Pre_Id_NA }
enum  RtemsTimerReqReset_Pre_Context { RtemsTimerReqReset_Pre_Context_None , RtemsTimerReqReset_Pre_Context_Interrupt , RtemsTimerReqReset_Pre_Context_Server , RtemsTimerReqReset_Pre_Context_NA }
enum  RtemsTimerReqReset_Pre_Clock { RtemsTimerReqReset_Pre_Clock_None , RtemsTimerReqReset_Pre_Clock_Ticks , RtemsTimerReqReset_Pre_Clock_Realtime , RtemsTimerReqReset_Pre_Clock_NA }
enum  RtemsTimerReqReset_Pre_State { RtemsTimerReqReset_Pre_State_Inactive , RtemsTimerReqReset_Pre_State_Scheduled , RtemsTimerReqReset_Pre_State_Pending , RtemsTimerReqReset_Pre_State_NA }
enum  RtemsTimerReqReset_Post_Status { RtemsTimerReqReset_Post_Status_Ok , RtemsTimerReqReset_Post_Status_InvId , RtemsTimerReqReset_Post_Status_NotDef , RtemsTimerReqReset_Post_Status_NA }
enum  RtemsTimerReqReset_Post_Context {
  RtemsTimerReqReset_Post_Context_None , RtemsTimerReqReset_Post_Context_Interrupt , RtemsTimerReqReset_Post_Context_Server , RtemsTimerReqReset_Post_Context_Nop ,
  RtemsTimerReqReset_Post_Context_NA
enum  RtemsTimerReqReset_Post_Clock {
  RtemsTimerReqReset_Post_Clock_None , RtemsTimerReqReset_Post_Clock_Ticks , RtemsTimerReqReset_Post_Clock_Realtime , RtemsTimerReqReset_Post_Clock_Nop ,
  RtemsTimerReqReset_Post_Clock_NA
enum  RtemsTimerReqReset_Post_State { RtemsTimerReqReset_Post_State_Scheduled , RtemsTimerReqReset_Post_State_Nop , RtemsTimerReqReset_Post_State_NA }
enum  RtemsTimerReqReset_Post_Interval { RtemsTimerReqReset_Post_Interval_Last , RtemsTimerReqReset_Post_Interval_Nop , RtemsTimerReqReset_Post_Interval_NA }
enum  RtemsTimerReqReset_Post_Routine { RtemsTimerReqReset_Post_Routine_Last , RtemsTimerReqReset_Post_Routine_Nop , RtemsTimerReqReset_Post_Routine_NA }
enum  RtemsTimerReqReset_Post_UserData { RtemsTimerReqReset_Post_UserData_Last , RtemsTimerReqReset_Post_UserData_Nop , RtemsTimerReqReset_Post_UserData_NA }
enum  PreConditionContext { PRE_NONE = 0 , PRE_INTERRUPT = 1 , PRE_SERVER = 2 }
enum  Scheduling_Ticks { SCHEDULE_NONE = 0 , SCHEDULE_SOON = 1 , SCHEDULE_LATER = 2 , SCHEDULE_MAX = 5 }
 T_TEST_CASE_FIXTURE (RtemsTimerReqReset, &RtemsTimerReqReset_Fixture)
