RTEMS 6.3
Tests a signal constant of the Signal Manager using the signal set of the executing task. More...
Files | |
| file | testsuites/validation/tr-signal-constant.c |
| file | testsuites/validation/tr-signal-constant.h |
| struct | RtemsSignalValSignalConstant_Context |
| Test context for spec:/rtems/signal/val/signal-constant test case. More... | |
Typedefs | |
| typedef RtemsSignalValSignalConstant_Context | Context |
| void | RtemsSignalValSignalConstant_Run (rtems_signal_set signal, int number) |
| Runs the parameterized test case. | |
This test case performs the following actions:
| void RtemsSignalValSignalConstant_Run | ( | rtems_signal_set | signal, |
| int | number ) |
| signal | is the signal constant. |
| number | is the signal number. |
