RTEMS 6.3
Tests uniprocessor-specific semaphore behaviour. More...
file  testsuites/validation/tc-sem-uni.c
struct  RtemsSemValUni_Context
 Test context for spec:/rtems/sem/val/uni test case. More...
typedef RtemsSemValUni_Context Context
 T_TEST_CASE_FIXTURE (RtemsSemValUni, &RtemsSemValUni_Fixture)
This test case performs the following actions:
  • Create a worker thread and two MrsP mutexes. Obtain the Mrsp mutexes and check that a task yield works (owner is not sticky). We need two mutexes since the uniprocessor schedulers do not increment the stick level in the scheduler unblock operation.
    • Yield and let the worker obtain the MrsP mutexes.
    • Yield and let the worker release the MrsP mutexes.
    • Clean up all used resources.
