RTEMS 6.3
Test the rtems_semaphore_ident() directive. More...
file  testsuites/validation/tc-sem-ident.c
#define NAME_LOCAL_OBJECT   rtems_build_name( 'S', 'E', 'M', 'A' )
 T_TEST_CASE (RtemsSemValIdent)
This test case performs the following actions:
  • Run the generic object identification tests for Classic API semaphore class objects defined by spec:/rtems/req/ident.
