RTEMS 6.3
spec:/rtems/scheduler/req/ident-by-processor-set
file  testsuites/validation/tc-scheduler-ident-by-processor-set.c
struct  RtemsSchedulerReqIdentByProcessorSet_Entry
struct  RtemsSchedulerReqIdentByProcessorSet_Context
 Test context for spec:/rtems/scheduler/req/ident-by-processor-set test case. More...
struct  RtemsSchedulerReqIdentByProcessorSet_Context::[struct].Map
enum  RtemsSchedulerReqIdentByProcessorSet_Pre_CPUOwnedByScheduler { RtemsSchedulerReqIdentByProcessorSet_Pre_CPUOwnedByScheduler_Yes , RtemsSchedulerReqIdentByProcessorSet_Pre_CPUOwnedByScheduler_No , RtemsSchedulerReqIdentByProcessorSet_Pre_CPUOwnedByScheduler_NA }
enum  RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSetObj { RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSetObj_Invalid , RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSetObj_Valid , RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSetObj_NA }
enum  RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSetSize { RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSetSize_Valid , RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSetSize_Invalid , RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSetSize_NA }
enum  RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSet { RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSet_Valid , RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSet_Null , RtemsSchedulerReqIdentByProcessorSet_Pre_CPUSet_NA }
enum  RtemsSchedulerReqIdentByProcessorSet_Pre_Id { RtemsSchedulerReqIdentByProcessorSet_Pre_Id_Valid , RtemsSchedulerReqIdentByProcessorSet_Pre_Id_Null , RtemsSchedulerReqIdentByProcessorSet_Pre_Id_NA }
enum  RtemsSchedulerReqIdentByProcessorSet_Post_Status {
  RtemsSchedulerReqIdentByProcessorSet_Post_Status_Ok , RtemsSchedulerReqIdentByProcessorSet_Post_Status_InvAddr , RtemsSchedulerReqIdentByProcessorSet_Post_Status_InvSize , RtemsSchedulerReqIdentByProcessorSet_Post_Status_InvName ,
  RtemsSchedulerReqIdentByProcessorSet_Post_Status_IncStat , RtemsSchedulerReqIdentByProcessorSet_Post_Status_NA
enum  RtemsSchedulerReqIdentByProcessorSet_Post_IdVar { RtemsSchedulerReqIdentByProcessorSet_Post_IdVar_Set , RtemsSchedulerReqIdentByProcessorSet_Post_IdVar_Nop , RtemsSchedulerReqIdentByProcessorSet_Post_IdVar_NA }
 T_TEST_CASE_FIXTURE (RtemsSchedulerReqIdentByProcessorSet, &RtemsSchedulerReqIdentByProcessorSet_Fixture)
