RTEMS 6.3
Test the rtems_partition_ident() directive. More...
file  testsuites/validation/tc-part-ident.c
#define NAME_LOCAL_OBJECT   rtems_build_name( 'P', 'A', 'R', 'T' )
 T_TEST_CASE (RtemsPartValIdent)
This test case performs the following actions:
  • Run the generic object identification tests for Classic API partition class objects defined by spec:/rtems/req/ident.
