RTEMS 6.3
Tests some Object Services directives. More...
file  testsuites/validation/tc-object.c
 T_TEST_CASE (RtemsObjectValObject)
This test case performs the following actions:
  • Validate the results of rtems_build_name() (function) and rtems_build_name() (macro) for a sample set of parameters.
    • Check that the accumulated name has the expected value.
  • Validate the result of rtems_object_get_local_node().
    • Check that the returned value is one.
