Tests the Event Manager API.
This test case performs the following actions:
- Run the event constant and number test for all 32 event constants.
- Check that RTEMS_PENDING_EVENTS is a constant expression which evaluates to a value of zero.
- Calculate the value of a bitwise or of all 32 event constants.
- Check that the value is equal to RTEMS_ALL_EVENTS.
- Validate the Event Manager directive options.
- Check that RTEMS_EVENT_ALL is equal to zero.
- Check that RTEMS_EVENT_ANY is a power of two.
