RTEMS 6.3
Tests an event constant and number of the Event Manager using the Classic and system event sets of the executing task. More...
file  testsuites/validation/tr-event-constant.c
file  testsuites/validation/tr-event-constant.h
struct  RtemsEventValEventConstant_Context
 Test context for spec:/rtems/event/val/event-constant test case. More...
void RtemsEventValEventConstant_Run (rtems_event_set event, int number)
 Runs the parameterized test case.
This test case performs the following actions:
  • Validate the event constant.
    • Check that the event constant is equal to the event number bit in the event set.
    • Check that the event number bit of the event constant is not set in RTEMS_PENDING_EVENTS.
  • Get all pending events of the Classic event set of the executing task.
    • Check that the directive call was successful.
    • Check that there were no pending events.
  • Get all pending events of the system event set of the executing task.
  • Receive all pending events of the Classic event set of the executing task.
    • Check that the directive call was unsatisfied.
    • Check that there were no events received.
  • Receive all pending events of the system event set of the executing task.
  • Send the event to the Classic event set of the executing task.
    • Check that the pending event is equal to the event sent by a previous action.
  • Receive any event of the Classic event set of the executing task.
    • Check that the received event is equal to the event sent by a previous action.
  • Receive any event of the system event set of the executing task.
    • Check that the no events were received.
◆ RtemsEventValEventConstant_Run()
void RtemsEventValEventConstant_Run ( rtems_event_set event,
int number )
Parameters
eventis the event constant.
numberis the event number.
