RTEMS 6.3
RISCV Architecture Support. More...
Topics
 RISC-V Assembler Support
 RISC-V Assembler Support.
union  RISCV_CLINT_timer_reg
struct  RISCV_CLINT_regs
struct  RISCV_PLIC_hart_regs
struct  RISCV_PLIC_regs
struct  CPU_Per_CPU_control
 The CPU specific per-CPU control. More...
#define CPU_THREAD_LOCAL_STORAGE_VARIANT   10
#define RISCV_CONTEXT_ISR_DISPATCH_DISABLE   4
#define RISCV_EXCEPTION_FRAME_MCAUSE   RISCV_EXCEPTION_FRAME_X( 0 )
#define RISCV_EXCEPTION_FRAME_SP   RISCV_EXCEPTION_FRAME_X( 1 )
#define RISCV_EXCEPTION_FRAME_GP   RISCV_EXCEPTION_FRAME_X( 2 )
#define RISCV_EXCEPTION_FRAME_TP   RISCV_EXCEPTION_FRAME_X( 3 )
#define RISCV_EXCEPTION_FRAME_S2   RISCV_EXCEPTION_FRAME_X( 4 )
#define RISCV_EXCEPTION_FRAME_S3   RISCV_EXCEPTION_FRAME_X( 5 )
#define RISCV_EXCEPTION_FRAME_S4   RISCV_EXCEPTION_FRAME_X( 6 )
#define RISCV_EXCEPTION_FRAME_S5   RISCV_EXCEPTION_FRAME_X( 7 )
#define RISCV_EXCEPTION_FRAME_S6   RISCV_EXCEPTION_FRAME_X( 8 )
#define RISCV_EXCEPTION_FRAME_S7   RISCV_EXCEPTION_FRAME_X( 9 )
#define RISCV_EXCEPTION_FRAME_S8   RISCV_EXCEPTION_FRAME_X( 10 )
#define RISCV_EXCEPTION_FRAME_S9   RISCV_EXCEPTION_FRAME_X( 11 )
#define RISCV_EXCEPTION_FRAME_S10   RISCV_EXCEPTION_FRAME_X( 12 )
#define RISCV_EXCEPTION_FRAME_S11   RISCV_EXCEPTION_FRAME_X( 13 )
#define RISCV_PLIC_MAX_INTERRUPTS   1024
void _RISCV_Interrupt_dispatch (uintptr_t mcause, struct Per_CPU_Control *cpu_self)
void _CPU_Context_volatile_clobber (uintptr_t pattern)
void _CPU_Context_validate (uintptr_t pattern)
volatile uint32_t * _RISCV_Counter_mutable
volatile uint32_t _RISCV_Counter_register
