RTEMS 6.3
PowerPC Paravirtualization Support
PowerPC Paravirtualization Support.
This handler encapulates the functionality (primarily conditional feature defines) related to paravirtualization on the PowerPC.
Paravirtualization on the PowerPC makes the following assumptions:
  • RTEMS executes in user space
  • In user space there is no access to the MSR.
  • Interrupt enable/disable support using the MSR must be disabled and replaced with BSP provided methods which are adapted to the hosting environment.
