RTEMS
6.3
Toggle main menu visibility
CPUEndian
Implementation
SuperCore
CPU Architecture Support
Example
CPUEndian.
More...
#define
CPU_swap_u16
(value)
CPUEndian.
CPU_swap_u16
#define CPU_swap_u16
value
Value:
(((value&0xff) << 8) | ((value >> 8)&0xff))
This routine swaps a 16 bir quantity.
Parameters
[in]
value
is the value to be swapped
Returns
the value after being endian swapped
