RTEMS 6.3
Armv7-AR/AArch64 Generic Timer Clock Driver
This group contains the Armv7-AR/AArch64 Generic Timer Clock Driver implementation. More...
file  bsps/shared/dev/clock/arm-generic-timer.c
 This source file contains a Clock Driver implementation using Armv7-AR/AArch64 Generic Timer.
struct  arm_gt_clock_context
#define Clock_driver_support_at_tick(arg)
#define Clock_driver_support_initialize_hardware()
#define Clock_driver_support_install_isr(isr)
uint32_t _CPU_Counter_frequency (void)
CPU_Counter_ticks _CPU_Counter_read (void)
 RTEMS_SYSINIT_ITEM (arm_gt_clock_early_init, RTEMS_SYSINIT_CPU_COUNTER, RTEMS_SYSINIT_ORDER_FIRST)
The BSP must provide the following function:
void arm_generic_timer_get_config(uint32_t *frequency, uint32_t *irq);
The BSP may optionally define ARM_GENERIC_TIMER_USE_VIRTUAL in <bsp.h> to use the virtual timer instead of the physical timer.
◆ Clock_driver_support_at_tick
#define Clock_driver_support_at_tick ( arg)
Value:
arm_gt_clock_at_tick(arg)
◆ Clock_driver_support_initialize_hardware
#define Clock_driver_support_initialize_hardware ( void)
Value:
arm_gt_clock_initialize()
◆ Clock_driver_support_install_isr
#define Clock_driver_support_install_isr ( isr)
Value:
arm_gt_clock_handler_install(isr)
