RTEMS 6.3
Port status, port 0 (configuration port) (PSTSCFG)
This group contains register bit definitions. More...
#define GRSPWROUTER_PSTSCFG_EO   0x80000000U
#define GRSPWROUTER_PSTSCFG_EE   0x40000000U
#define GRSPWROUTER_PSTSCFG_PL   0x20000000U
#define GRSPWROUTER_PSTSCFG_TT   0x10000000U
#define GRSPWROUTER_PSTSCFG_PT   0x8000000U
#define GRSPWROUTER_PSTSCFG_HC   0x4000000U
#define GRSPWROUTER_PSTSCFG_PI   0x2000000U
#define GRSPWROUTER_PSTSCFG_CE   0x1000000U
#define GRSPWROUTER_PSTSCFG_EC_SHIFT   20
#define GRSPWROUTER_PSTSCFG_EC_MASK   0xf00000U
#define GRSPWROUTER_PSTSCFG_EC_GET(_reg)
#define GRSPWROUTER_PSTSCFG_EC_SET(_reg, _val)
#define GRSPWROUTER_PSTSCFG_EC(_val)
#define GRSPWROUTER_PSTSCFG_R   0x80000U
#define GRSPWROUTER_PSTSCFG_TS   0x40000U
#define GRSPWROUTER_PSTSCFG_ME   0x20000U
#define GRSPWROUTER_PSTSCFG_IP_SHIFT   7
#define GRSPWROUTER_PSTSCFG_IP_MASK   0xf80U
#define GRSPWROUTER_PSTSCFG_IP_GET(_reg)
#define GRSPWROUTER_PSTSCFG_IP_SET(_reg, _val)
#define GRSPWROUTER_PSTSCFG_IP(_val)
#define GRSPWROUTER_PSTSCFG_RES_SHIFT   5
#define GRSPWROUTER_PSTSCFG_RES_MASK   0x60U
#define GRSPWROUTER_PSTSCFG_RES_GET(_reg)
#define GRSPWROUTER_PSTSCFG_RES_SET(_reg, _val)
#define GRSPWROUTER_PSTSCFG_RES(_val)
#define GRSPWROUTER_PSTSCFG_CP   0x10U
#define GRSPWROUTER_PSTSCFG_PC_SHIFT   0
#define GRSPWROUTER_PSTSCFG_PC_MASK   0xfU
#define GRSPWROUTER_PSTSCFG_PC_GET(_reg)
#define GRSPWROUTER_PSTSCFG_PC_SET(_reg, _val)
#define GRSPWROUTER_PSTSCFG_PC(_val)
◆ GRSPWROUTER_PSTSCFG_EC
#define GRSPWROUTER_PSTSCFG_EC ( _val)
Value:
( ( ( _val ) << GRSPWROUTER_PSTSCFG_EC_SHIFT ) & \
GRSPWROUTER_PSTSCFG_EC_MASK )
◆ GRSPWROUTER_PSTSCFG_EC_GET
#define GRSPWROUTER_PSTSCFG_EC_GET ( _reg)
Value:
( ( ( _reg ) & GRSPWROUTER_PSTSCFG_EC_MASK ) >> \
◆ GRSPWROUTER_PSTSCFG_EC_SET
#define GRSPWROUTER_PSTSCFG_EC_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GRSPWROUTER_PSTSCFG_EC_MASK ) | \
GRSPWROUTER_PSTSCFG_EC_MASK ) )
◆ GRSPWROUTER_PSTSCFG_IP
#define GRSPWROUTER_PSTSCFG_IP ( _val)
Value:
( ( ( _val ) << GRSPWROUTER_PSTSCFG_IP_SHIFT ) & \
GRSPWROUTER_PSTSCFG_IP_MASK )
◆ GRSPWROUTER_PSTSCFG_IP_GET
#define GRSPWROUTER_PSTSCFG_IP_GET ( _reg)
Value:
( ( ( _reg ) & GRSPWROUTER_PSTSCFG_IP_MASK ) >> \
◆ GRSPWROUTER_PSTSCFG_IP_SET
#define GRSPWROUTER_PSTSCFG_IP_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GRSPWROUTER_PSTSCFG_IP_MASK ) | \
GRSPWROUTER_PSTSCFG_IP_MASK ) )
◆ GRSPWROUTER_PSTSCFG_PC
#define GRSPWROUTER_PSTSCFG_PC ( _val)
Value:
( ( ( _val ) << GRSPWROUTER_PSTSCFG_PC_SHIFT ) & \
GRSPWROUTER_PSTSCFG_PC_MASK )
◆ GRSPWROUTER_PSTSCFG_PC_GET
#define GRSPWROUTER_PSTSCFG_PC_GET ( _reg)
Value:
( ( ( _reg ) & GRSPWROUTER_PSTSCFG_PC_MASK ) >> \
◆ GRSPWROUTER_PSTSCFG_PC_SET
#define GRSPWROUTER_PSTSCFG_PC_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GRSPWROUTER_PSTSCFG_PC_MASK ) | \
GRSPWROUTER_PSTSCFG_PC_MASK ) )
◆ GRSPWROUTER_PSTSCFG_RES
#define GRSPWROUTER_PSTSCFG_RES ( _val)
Value:
( ( ( _val ) << GRSPWROUTER_PSTSCFG_RES_SHIFT ) & \
GRSPWROUTER_PSTSCFG_RES_MASK )
◆ GRSPWROUTER_PSTSCFG_RES_GET
#define GRSPWROUTER_PSTSCFG_RES_GET ( _reg)
Value:
( ( ( _reg ) & GRSPWROUTER_PSTSCFG_RES_MASK ) >> \
◆ GRSPWROUTER_PSTSCFG_RES_SET
#define GRSPWROUTER_PSTSCFG_RES_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GRSPWROUTER_PSTSCFG_RES_MASK ) | \
GRSPWROUTER_PSTSCFG_RES_MASK ) )
