RTEMS 6.3
Datation Preamble Field (DPF)
This group contains register bit definitions. More...
#define SPWTDP_DPF_DPF_SHIFT   0
#define SPWTDP_DPF_DPF_MASK   0xffffU
#define SPWTDP_DPF_DPF_GET(_reg)
#define SPWTDP_DPF_DPF_SET(_reg, _val)
#define SPWTDP_DPF_DPF(_val)
◆ SPWTDP_DPF_DPF
#define SPWTDP_DPF_DPF ( _val)
Value:
( ( ( _val ) << SPWTDP_DPF_DPF_SHIFT ) & \
SPWTDP_DPF_DPF_MASK )
◆ SPWTDP_DPF_DPF_GET
#define SPWTDP_DPF_DPF_GET ( _reg)
Value:
( ( ( _reg ) & SPWTDP_DPF_DPF_MASK ) >> \
◆ SPWTDP_DPF_DPF_SET
#define SPWTDP_DPF_DPF_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~SPWTDP_DPF_DPF_MASK ) | \
SPWTDP_DPF_DPF_MASK ) )
