RTEMS 6.3
This group contains the APBUART interfaces. More...
Topics
 UART FIFO debug register (FIFO)
 This group contains register bit definitions.
 UART control register (CTRL)
 UART data register (DATA)
 UART scaler reload register (SCALER)
 UART status register (STATUS)
file  bsps/include/grlib/apbuart-regs.h
 This header file defines the APBUART register block interface.
file  bsps/include/grlib/apbuart.h
 This header file defines the APBUART interface.
file  bsps/shared/grlib/uart/apbuart_polled.c
 This source file contains the implementation of apbuart_outbyte_wait(), apbuart_outbyte_polled(), and apbuart_inbyte_nonblocking().
struct  apbuart
 This structure defines the APBUART register block memory map. More...
typedef struct apbuart apbuart
int apbuart_inbyte_nonblocking (apbuart *regs)
 Clears all errors and tries to get one character from the receiver FIFO.
void apbuart_outbyte_polled (apbuart *regs, char ch)
 Waits until an empty transmitter FIFO was observed and then stores the character to the data register.
void apbuart_outbyte_wait (const apbuart *regs)
 Ensures that at least once an empty transmitter FIFO was observed.
◆ apbuart_inbyte_nonblocking()
int apbuart_inbyte_nonblocking ( apbuart * regs)
Parameters
regsis the pointer to the APBUART register block.
Return values
-1The receiver FIFO was empty.
Returns
Returns the first character of the receiver FIFO if it was non-empty.
◆ apbuart_outbyte_polled()
void apbuart_outbyte_polled ( apbuart * regs,
char ch )
Parameters
chis the character to output.
◆ apbuart_outbyte_wait()
void apbuart_outbyte_wait ( const apbuart * regs)
Parameters
