RTEMS 6.3
GR1553B RT Mode code control register (RTMCC)
This group contains register bit definitions. More...
#define GR1553B_RTMCC_RRTB_SHIFT   28
#define GR1553B_RTMCC_RRTB_MASK   0x30000000U
#define GR1553B_RTMCC_RRTB_GET(_reg)
#define GR1553B_RTMCC_RRTB_SET(_reg, _val)
#define GR1553B_RTMCC_RRTB(_val)
#define GR1553B_RTMCC_RRT_SHIFT   26
#define GR1553B_RTMCC_RRT_MASK   0xc000000U
#define GR1553B_RTMCC_RRT_GET(_reg)
#define GR1553B_RTMCC_RRT_SET(_reg, _val)
#define GR1553B_RTMCC_RRT(_val)
#define GR1553B_RTMCC_ITFB_SHIFT   24
#define GR1553B_RTMCC_ITFB_MASK   0x3000000U
#define GR1553B_RTMCC_ITFB_GET(_reg)
#define GR1553B_RTMCC_ITFB_SET(_reg, _val)
#define GR1553B_RTMCC_ITFB(_val)
#define GR1553B_RTMCC_ITF_SHIFT   22
#define GR1553B_RTMCC_ITF_MASK   0xc00000U
#define GR1553B_RTMCC_ITF_GET(_reg)
#define GR1553B_RTMCC_ITF_SET(_reg, _val)
#define GR1553B_RTMCC_ITF(_val)
#define GR1553B_RTMCC_ISTB_SHIFT   20
#define GR1553B_RTMCC_ISTB_MASK   0x300000U
#define GR1553B_RTMCC_ISTB_GET(_reg)
#define GR1553B_RTMCC_ISTB_SET(_reg, _val)
#define GR1553B_RTMCC_ISTB(_val)
#define GR1553B_RTMCC_IST_SHIFT   18
#define GR1553B_RTMCC_IST_MASK   0xc0000U
#define GR1553B_RTMCC_IST_GET(_reg)
#define GR1553B_RTMCC_IST_SET(_reg, _val)
#define GR1553B_RTMCC_IST(_val)
#define GR1553B_RTMCC_DBC_SHIFT   16
#define GR1553B_RTMCC_DBC_MASK   0x30000U
#define GR1553B_RTMCC_DBC_GET(_reg)
#define GR1553B_RTMCC_DBC_SET(_reg, _val)
#define GR1553B_RTMCC_DBC(_val)
#define GR1553B_RTMCC_TBW_SHIFT   14
#define GR1553B_RTMCC_TBW_MASK   0xc000U
#define GR1553B_RTMCC_TBW_GET(_reg)
#define GR1553B_RTMCC_TBW_SET(_reg, _val)
#define GR1553B_RTMCC_TBW(_val)
#define GR1553B_RTMCC_TVW_SHIFT   12
#define GR1553B_RTMCC_TVW_MASK   0x3000U
#define GR1553B_RTMCC_TVW_GET(_reg)
#define GR1553B_RTMCC_TVW_SET(_reg, _val)
#define GR1553B_RTMCC_TVW(_val)
#define GR1553B_RTMCC_TSB_SHIFT   10
#define GR1553B_RTMCC_TSB_MASK   0xc00U
#define GR1553B_RTMCC_TSB_GET(_reg)
#define GR1553B_RTMCC_TSB_SET(_reg, _val)
#define GR1553B_RTMCC_TSB(_val)
#define GR1553B_RTMCC_TS_SHIFT   8
#define GR1553B_RTMCC_TS_MASK   0x300U
#define GR1553B_RTMCC_TS_GET(_reg)
#define GR1553B_RTMCC_TS_SET(_reg, _val)
#define GR1553B_RTMCC_TS(_val)
#define GR1553B_RTMCC_SDB_SHIFT   6
#define GR1553B_RTMCC_SDB_MASK   0xc0U
#define GR1553B_RTMCC_SDB_GET(_reg)
#define GR1553B_RTMCC_SDB_SET(_reg, _val)
#define GR1553B_RTMCC_SDB(_val)
#define GR1553B_RTMCC_SD_SHIFT   4
#define GR1553B_RTMCC_SD_MASK   0x30U
#define GR1553B_RTMCC_SD_GET(_reg)
#define GR1553B_RTMCC_SD_SET(_reg, _val)
#define GR1553B_RTMCC_SD(_val)
#define GR1553B_RTMCC_SB_SHIFT   2
#define GR1553B_RTMCC_SB_MASK   0xcU
#define GR1553B_RTMCC_SB_GET(_reg)
#define GR1553B_RTMCC_SB_SET(_reg, _val)
#define GR1553B_RTMCC_SB(_val)
#define GR1553B_RTMCC_S_SHIFT   0
#define GR1553B_RTMCC_S_MASK   0x3U
#define GR1553B_RTMCC_S_GET(_reg)
#define GR1553B_RTMCC_S_SET(_reg, _val)
#define GR1553B_RTMCC_S(_val)
◆ GR1553B_RTMCC_DBC
#define GR1553B_RTMCC_DBC ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_DBC_SHIFT ) & \
GR1553B_RTMCC_DBC_MASK )
◆ GR1553B_RTMCC_DBC_GET
#define GR1553B_RTMCC_DBC_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_DBC_MASK ) >> \
◆ GR1553B_RTMCC_DBC_SET
#define GR1553B_RTMCC_DBC_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_DBC_MASK ) | \
GR1553B_RTMCC_DBC_MASK ) )
◆ GR1553B_RTMCC_IST
#define GR1553B_RTMCC_IST ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_IST_SHIFT ) & \
GR1553B_RTMCC_IST_MASK )
◆ GR1553B_RTMCC_IST_GET
#define GR1553B_RTMCC_IST_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_IST_MASK ) >> \
◆ GR1553B_RTMCC_IST_SET
#define GR1553B_RTMCC_IST_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_IST_MASK ) | \
GR1553B_RTMCC_IST_MASK ) )
◆ GR1553B_RTMCC_ISTB
#define GR1553B_RTMCC_ISTB ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_ISTB_SHIFT ) & \
GR1553B_RTMCC_ISTB_MASK )
◆ GR1553B_RTMCC_ISTB_GET
#define GR1553B_RTMCC_ISTB_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_ISTB_MASK ) >> \
◆ GR1553B_RTMCC_ISTB_SET
#define GR1553B_RTMCC_ISTB_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_ISTB_MASK ) | \
GR1553B_RTMCC_ISTB_MASK ) )
◆ GR1553B_RTMCC_ITF
#define GR1553B_RTMCC_ITF ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_ITF_SHIFT ) & \
GR1553B_RTMCC_ITF_MASK )
◆ GR1553B_RTMCC_ITF_GET
#define GR1553B_RTMCC_ITF_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_ITF_MASK ) >> \
◆ GR1553B_RTMCC_ITF_SET
#define GR1553B_RTMCC_ITF_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_ITF_MASK ) | \
GR1553B_RTMCC_ITF_MASK ) )
◆ GR1553B_RTMCC_ITFB
#define GR1553B_RTMCC_ITFB ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_ITFB_SHIFT ) & \
GR1553B_RTMCC_ITFB_MASK )
◆ GR1553B_RTMCC_ITFB_GET
#define GR1553B_RTMCC_ITFB_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_ITFB_MASK ) >> \
◆ GR1553B_RTMCC_ITFB_SET
#define GR1553B_RTMCC_ITFB_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_ITFB_MASK ) | \
GR1553B_RTMCC_ITFB_MASK ) )
◆ GR1553B_RTMCC_RRT
#define GR1553B_RTMCC_RRT ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_RRT_SHIFT ) & \
GR1553B_RTMCC_RRT_MASK )
◆ GR1553B_RTMCC_RRT_GET
#define GR1553B_RTMCC_RRT_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_RRT_MASK ) >> \
◆ GR1553B_RTMCC_RRT_SET
#define GR1553B_RTMCC_RRT_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_RRT_MASK ) | \
GR1553B_RTMCC_RRT_MASK ) )
◆ GR1553B_RTMCC_RRTB
#define GR1553B_RTMCC_RRTB ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_RRTB_SHIFT ) & \
GR1553B_RTMCC_RRTB_MASK )
◆ GR1553B_RTMCC_RRTB_GET
#define GR1553B_RTMCC_RRTB_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_RRTB_MASK ) >> \
◆ GR1553B_RTMCC_RRTB_SET
#define GR1553B_RTMCC_RRTB_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_RRTB_MASK ) | \
GR1553B_RTMCC_RRTB_MASK ) )
◆ GR1553B_RTMCC_S
#define GR1553B_RTMCC_S ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_S_SHIFT ) & \
GR1553B_RTMCC_S_MASK )
◆ GR1553B_RTMCC_S_GET
#define GR1553B_RTMCC_S_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_S_MASK ) >> \
◆ GR1553B_RTMCC_S_SET
#define GR1553B_RTMCC_S_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_S_MASK ) | \
GR1553B_RTMCC_S_MASK ) )
◆ GR1553B_RTMCC_SB
#define GR1553B_RTMCC_SB ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_SB_SHIFT ) & \
GR1553B_RTMCC_SB_MASK )
◆ GR1553B_RTMCC_SB_GET
#define GR1553B_RTMCC_SB_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_SB_MASK ) >> \
◆ GR1553B_RTMCC_SB_SET
#define GR1553B_RTMCC_SB_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_SB_MASK ) | \
GR1553B_RTMCC_SB_MASK ) )
◆ GR1553B_RTMCC_SD
#define GR1553B_RTMCC_SD ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_SD_SHIFT ) & \
GR1553B_RTMCC_SD_MASK )
◆ GR1553B_RTMCC_SD_GET
#define GR1553B_RTMCC_SD_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_SD_MASK ) >> \
◆ GR1553B_RTMCC_SD_SET
#define GR1553B_RTMCC_SD_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_SD_MASK ) | \
GR1553B_RTMCC_SD_MASK ) )
◆ GR1553B_RTMCC_SDB
#define GR1553B_RTMCC_SDB ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_SDB_SHIFT ) & \
GR1553B_RTMCC_SDB_MASK )
◆ GR1553B_RTMCC_SDB_GET
#define GR1553B_RTMCC_SDB_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_SDB_MASK ) >> \
◆ GR1553B_RTMCC_SDB_SET
#define GR1553B_RTMCC_SDB_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_SDB_MASK ) | \
GR1553B_RTMCC_SDB_MASK ) )
◆ GR1553B_RTMCC_TBW
#define GR1553B_RTMCC_TBW ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_TBW_SHIFT ) & \
GR1553B_RTMCC_TBW_MASK )
◆ GR1553B_RTMCC_TBW_GET
#define GR1553B_RTMCC_TBW_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_TBW_MASK ) >> \
◆ GR1553B_RTMCC_TBW_SET
#define GR1553B_RTMCC_TBW_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_TBW_MASK ) | \
GR1553B_RTMCC_TBW_MASK ) )
◆ GR1553B_RTMCC_TS
#define GR1553B_RTMCC_TS ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_TS_SHIFT ) & \
GR1553B_RTMCC_TS_MASK )
◆ GR1553B_RTMCC_TS_GET
#define GR1553B_RTMCC_TS_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_TS_MASK ) >> \
◆ GR1553B_RTMCC_TS_SET
#define GR1553B_RTMCC_TS_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_TS_MASK ) | \
GR1553B_RTMCC_TS_MASK ) )
◆ GR1553B_RTMCC_TSB
#define GR1553B_RTMCC_TSB ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_TSB_SHIFT ) & \
GR1553B_RTMCC_TSB_MASK )
◆ GR1553B_RTMCC_TSB_GET
#define GR1553B_RTMCC_TSB_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_TSB_MASK ) >> \
◆ GR1553B_RTMCC_TSB_SET
#define GR1553B_RTMCC_TSB_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_TSB_MASK ) | \
GR1553B_RTMCC_TSB_MASK ) )
◆ GR1553B_RTMCC_TVW
#define GR1553B_RTMCC_TVW ( _val)
Value:
( ( ( _val ) << GR1553B_RTMCC_TVW_SHIFT ) & \
GR1553B_RTMCC_TVW_MASK )
◆ GR1553B_RTMCC_TVW_GET
#define GR1553B_RTMCC_TVW_GET ( _reg)
Value:
( ( ( _reg ) & GR1553B_RTMCC_TVW_MASK ) >> \
◆ GR1553B_RTMCC_TVW_SET
#define GR1553B_RTMCC_TVW_SET ( _reg,
_val )
Value:
( ( ( _reg ) & ~GR1553B_RTMCC_TVW_MASK ) | \
GR1553B_RTMCC_TVW_MASK ) )
