RTEMS 6.3
LEON2 Board Support Package. More...
Files | |
| file | bsps/sparc/include/drvmgr/leon2_amba_bus.h |
| This header file provides interfaces of the LEON2 Hardcoded bus driver. | |
| file | bsps/sparc/leon2/btimer/btimer.c |
| Implement a benchmark timer using timer 2. | |
| file | bsps/sparc/leon2/clock/ckinit.c |
| Clock Tick Device Driver. | |
| file | bsps/sparc/leon2/console/console.c |
| TTY driver driver for the serial ports on the LEON console. | |
| file | bsps/sparc/leon2/console/debugputs.c |
| TTY driver for the serial ports on the LEON. | |
| file | bsps/sparc/leon2/gnatsupp/gnatsupp.c |
| Support for gnat/rtems iterrupts and exception handling. | |
| file | bsps/sparc/leon2/include/bsp.h |
| Global BSP definitions. | |
| file | bsps/sparc/leon2/include/bsp/irq.h |
| Interrupts definitions. | |
| file | bsps/sparc/leon2/include/bsp/irqimpl.h |
| This header file provides interfaces used by the interrupt support implementation. | |
| file | bsps/sparc/leon2/include/leon.h |
| file | bsps/sparc/leon2/include/tm27.h |
| Implementations for interrupt mechanisms for Time Test 27. | |
| file | bsps/sparc/leon2/start/bspdelay.c |
| LEON2 BSP Delay Method. | |
| file | bsps/sparc/leon2/start/bspidle.c |
| LEON2 Idle Thread. | |
| file | bsps/sparc/leon2/start/bspstart.c |
| LEON2 Cache Snooping Support. | |
| file | bsps/sparc/leon2/start/setvec.c |
| Installs an interrupt vector on the SPARC simulator. | |
| #define | LEON2 1 |
| #define | BSP_FEATURE_IRQ_EXTENSION |
| #define | BSP_IDLE_TASK_BODY bsp_idle_thread |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME "open_eth1" |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH rtems_leon_open_eth_driver_attach |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH_SMC91111 rtems_smc91111_driver_attach_leon2 |
| #define | HAS_SMC91111 |
| #define | GRETH_SUPPORTED |
| #define | GRETH_MEM_LOAD(addr) |
| #define | BSP_PCI_BIG_ENDIAN |
| #define | AMBAPPBUS_INFO_AVAIL |
| #define | GPTIMER_INFO_AVAIL |
| #define | GRETH_INFO_AVAIL |
Typedefs | |
| typedef void(*) | bsp_shared_isr(void *arg) |
| void * | bsp_idle_thread (uintptr_t ignored) |
| Optimized idle task. | |
| int | rtems_leon_open_eth_driver_attach (struct rtems_bsdnet_ifconfig *config) |
| int | rtems_smc91111_driver_attach_leon2 (struct rtems_bsdnet_ifconfig *config) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| void | BSP_fatal_exit (uint32_t error) |
| void | rtems_bsp_delay (int usecs) |
| int | cchip1_register (void) |
| void | console_outbyte_polled (int port, unsigned char ch) |
| int | console_inbyte_nonblocking (int port) |
| int | CPU_SPARC_HAS_SNOOPING |
| int | RAM_START |
| int | RAM_END |
| int | RAM_SIZE |
| int | PROM_START |
| int | PROM_END |
| int | PROM_SIZE |
| int | CLOCK_SPEED |
| int | end |
| #define GRETH_MEM_LOAD | ( | addr | ) |
| void * bsp_idle_thread | ( | uintptr_t | ignored | ) |
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
| int console_inbyte_nonblocking | ( | int | port | ) |
This method polls the specified port for an input character. console port.
| [in] | port | is the input port |
