RTEMS 6.3
NXP MPC8260ADS Board Support Package. More...
Files | |
| file | bsps/powerpc/mpc8260ads/include/bsp.h |
| Global BSP definitions. | |
| struct | bcsr |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME "eth1" |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_enet_driver_attach |
Typedefs | |
| typedef struct bcsr | BCSR |
| int | rtems_enet_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching) |
| void * | bsp_idle_thread (uintptr_t ignored) |
| Optimized idle task. | |
| void | cpu_init (void) |
| int | mbx8xx_console_get_configuration (void) |
| uint32_t | bsp_serial_per_sec |
| void * bsp_idle_thread | ( | uintptr_t | ignored | ) |
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
