RTEMS 6.3
NXP MPC5200 Board Support Package. More...
Topics
 BestComm Support
 BestComm support.
 MSCAN
file  bsps/powerpc/gen5200/include/bsp.h
 Global BSP definitions.
#define NEED_LOW_LEVEL_INIT
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "eth1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_mpc5200_fec_driver_attach_detach
#define RTEMS_BSP_HAS_IDE_DRIVER
#define ATA_USE_INT
#define IPB_CLOCK   33000000
#define XLB_CLOCK   66000000
#define G2_CLOCK   231000000
#define GEN5200_CONSOLE_BAUD   115200
#define BSP_Convert_decrementer(_value)
#define USE_SLICETIMER_0   TRUE
#define USE_SLICETIMER_1   FALSE
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
 LINKER_SYMBOL (bsp_ram_start)
 LINKER_SYMBOL (bsp_ram_end)
 LINKER_SYMBOL (bsp_ram_size)
 LINKER_SYMBOL (bsp_rom_start)
 LINKER_SYMBOL (bsp_rom_end)
 LINKER_SYMBOL (bsp_rom_size)
 LINKER_SYMBOL (bsp_dpram_start)
 LINKER_SYMBOL (bsp_dpram_end)
 LINKER_SYMBOL (bsp_dpram_size)
 LINKER_SYMBOL (bsp_section_text_start)
 LINKER_SYMBOL (bsp_section_text_end)
 LINKER_SYMBOL (bsp_section_text_size)
 LINKER_SYMBOL (bsp_section_data_start)
 LINKER_SYMBOL (bsp_section_data_end)
 LINKER_SYMBOL (bsp_section_data_size)
 LINKER_SYMBOL (bsp_section_bss_start)
 LINKER_SYMBOL (bsp_section_bss_end)
 LINKER_SYMBOL (bsp_section_bss_size)
 LINKER_SYMBOL (bsp_work_area_start)
 LINKER_SYMBOL (MBAR)
int rtems_mpc5200_fec_driver_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task.
void BSP_IRQ_Benchmarking_Reset (void)
void BSP_IRQ_Benchmarking_Report (void)
void cpu_init (void)
int mpc5200_eth_mii_read (int phyAddr, void *arg, unsigned regAddr, uint32_t *retVal)
◆ BSP_Convert_decrementer
#define BSP_Convert_decrementer ( _value)
Value:
(int) (((_value) * 4000) / (XLB_CLOCK/10000))
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t ignored)
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
