RTEMS 6.3
MVME162 Board Support Package. More...
Files | |
| file | bsps/m68k/mvme162/include/bsp.h |
| Global BSP definitions. | |
| struct | mcchip_regs |
| struct | scc_regs |
| struct | memc040_regs_ |
| struct | cd2401_regs_ |
| union | cd2401_regs_::[union].u1 |
| struct | cd2401_regs_::[struct].u1.async |
| struct | cd2401_regs_::[struct].u1.sync |
| union | cd2401_regs_::[union].u2 |
| struct | cd2401_regs_::[struct].u2.w |
| struct | cd2401_regs_::[struct].u2.b |
| union | cd2401_regs_::[union].u3 |
| struct | cd2401_regs_::[struct].u3.async |
| struct | cd2401_regs_::[struct].u3.sync |
| union | cd2401_regs_::[union].u4 |
| struct | cd2401_regs_::[struct].u4.w |
| struct | cd2401_regs_::[struct].u4.b |
| union | cd2401_regs_::[union].u5 |
| struct | cd2401_regs_::[struct].u5.w |
| struct | cd2401_regs_::[struct].u5.b |
| #define | mcchip ((mcchip_regs * const) 0xFFF42000) |
| #define | TX_BUFFER_EMPTY 0x04 |
| #define | RX_DATA_AVAILABLE 0x01 |
| #define | SCC_VECTOR 0x40 |
| #define | scc ((scc_regs * const) 0xFFF45000) |
| #define | ZWRITE0(port, v) |
| #define | ZREAD0(port) |
| #define | ZREAD(port, n) |
| #define | ZREADD(port) |
| #define | ZWRITE(port, n, v) |
| #define | ZWRITED(port, v) |
| #define | EXTERN extern |
| #define | MOT_162BUG_VEC_ADDRESS 0x00000000 |
| #define | memc040_1 ((memc040_regs * const) 0xFFF43000) |
| #define | memc040_2 ((memc040_regs * const) 0xFFF43100) |
| #define | cd2401 ((cd2401_regs * const) 0xFFF45000) |
| #define | CD2401_CLK_RATE 20000000 |
Typedefs | |
| typedef volatile struct memc040_regs_ | memc040_regs |
| typedef volatile struct cd2401_regs_ | cd2401_regs |
Enumerations | |
| enum | { portB , portA } |
| bool | char_ready (int port, char *ch) |
| char | char_wait (int port) |
| void | char_put (int port, char ch) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| rtems_isr_entry | M68Kvec [] |
| void * | M68Kvec [] |
MVME167 Board Support Package.
| #define ZREAD | ( | port, | |
| n ) |
| #define ZREAD0 | ( | port | ) |
| #define ZREADD | ( | port | ) |
| #define ZWRITE | ( | port, | |
| n, | |||
| v ) |
| #define ZWRITE0 | ( | port, | |
| v ) |
| #define ZWRITED | ( | port, | |
| v ) |
