RTEMS 6.3
Gumstix Board Support Package. More...
file  bsps/arm/gumstix/include/bsp.h
 Global BSP definitions.
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_HAS_FRAME_BUFFER   1
#define BSP_MAIN_FREQ   3686400
 What is the input clock freq in hertz.
#define BSP_SLCK_FREQ   32768
#define BSP_MAX_INT   AT91RM9200_MAX_INT
 What is the last interrupt.
#define ST_PIMR_PIV   33
#define outport_byte(port, val)
#define inport_byte(port, val)
#define outport_word(port, val)
#define inport_word(port, val)
#define BSP_NE2000_NETWORK_DRIVER_NAME   "ne1"
#define BSP_NE2000_NETWORK_DRIVER_ATTACH   rtems_ne_driver_attach
#define RTEMS_BSP_NETWORK_DRIVER_NAME   BSP_NE2000_NETWORK_DRIVER_NAME
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   BSP_NE2000_NETWORK_DRIVER_ATTACH
typedef struct _console_tbl console_tbl
console_tbl * BSP_get_uart_from_minor (int minor)
int rtems_ne_driver_attach (struct rtems_bsdnet_ifconfig *, int)
◆ inport_byte
#define inport_byte ( port,
val )
Value:
(val) = *((unsigned char volatile*)(port))
◆ inport_word
#define inport_word ( port,
val )
Value:
(val) = *((unsigned short volatile*)(port))
◆ outport_byte
#define outport_byte ( port,
val )
Value:
*((unsigned char volatile*)(port)) = (val)
◆ outport_word
#define outport_word ( port,
val )
Value:
*((unsigned short volatile*)(port)) = (val)
