RTEMS 6.3
Linker Sets
This group contains the linker sets API. More...
file  cpukit/include/rtems/linkersets.h
 This header file provides the linker sets API.
#define RTEMS_LINKER_SET_BEGIN(set)
#define RTEMS_LINKER_SET_END(set)
#define RTEMS_LINKER_SET_ALIGN(type)
#define RTEMS_LINKER_ROSET_DECLARE(set, type)
#define RTEMS_LINKER_ROSET(set, type)
#define RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE(set, type, item, order)
#define RTEMS_LINKER_ROSET_ITEM_DECLARE(set, type, item)
#define RTEMS_LINKER_ROSET_ITEM_REFERENCE(set, type, item)
#define RTEMS_LINKER_ROSET_ITEM_ORDERED(set, type, item, order)
#define RTEMS_LINKER_ROSET_ITEM(set, type, item)
#define RTEMS_LINKER_ROSET_CONTENT(set, decl)
#define RTEMS_LINKER_RWSET_DECLARE(set, type)
#define RTEMS_LINKER_RWSET(set, type)
#define RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE(set, type, item, order)
#define RTEMS_LINKER_RWSET_ITEM_DECLARE(set, type, item)
#define RTEMS_LINKER_RWSET_ITEM_REFERENCE(set, type, item)
#define RTEMS_LINKER_RWSET_ITEM_ORDERED(set, type, item, order)
#define RTEMS_LINKER_RWSET_ITEM(set, type, item)
#define RTEMS_LINKER_RWSET_CONTENT(set, decl)
#define RTEMS_LINKER_SET_SIZE(set)
#define RTEMS_LINKER_SET_ITEM_COUNT(set)
#define RTEMS_LINKER_SET_IS_EMPTY(set)
#define RTEMS_LINKER_SET_FOREACH(set, item)
◆ RTEMS_LINKER_ROSET
#define RTEMS_LINKER_ROSET ( set,
type )
Value:
RTEMS_LINKER_SET_ALIGN( type ) type const RTEMS_LINKER_SET_BEGIN( set )[ 0 ] \
RTEMS_SECTION( ".rtemsroset." #set ".begin" ) RTEMS_USED; \
RTEMS_LINKER_SET_ALIGN( type ) type const RTEMS_LINKER_SET_END( set )[ 0 ] \
RTEMS_SECTION( ".rtemsroset." #set ".end" ) RTEMS_USED
#define RTEMS_USED
Tells the compiler that the variable or function is used.
Definition basedefs.h:924
◆ RTEMS_LINKER_ROSET_CONTENT
#define RTEMS_LINKER_ROSET_CONTENT ( set,
decl )
Value:
decl \
RTEMS_SECTION( ".rtemsroset." #set ".content" )
◆ RTEMS_LINKER_ROSET_DECLARE
#define RTEMS_LINKER_ROSET_DECLARE ( set,
type )
Value:
extern RTEMS_LINKER_SET_ALIGN( type ) type \
const RTEMS_LINKER_SET_BEGIN( set )[]; \
const RTEMS_LINKER_SET_END( set )[]
◆ RTEMS_LINKER_ROSET_ITEM
#define RTEMS_LINKER_ROSET_ITEM ( set,
type,
item )
Value:
RTEMS_LINKER_SET_ALIGN( type ) type const _Linker_set_##set##_##item \
RTEMS_SECTION( ".rtemsroset." #set ".content.1" ) RTEMS_USED
◆ RTEMS_LINKER_ROSET_ITEM_DECLARE
#define RTEMS_LINKER_ROSET_ITEM_DECLARE ( set,
type,
item )
Value:
extern RTEMS_LINKER_SET_ALIGN( type ) type const _Linker_set_##set##_##item \
◆ RTEMS_LINKER_ROSET_ITEM_ORDERED
#define RTEMS_LINKER_ROSET_ITEM_ORDERED ( set,
type,
item,
order )
Value:
RTEMS_SECTION( ".rtemsroset." #set ".content.0." RTEMS_XSTRING( order ) ) \
#define RTEMS_XSTRING(...)
Stringifies the expansion of the arguments.
Definition basedefs.h:987
◆ RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE
#define RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE ( set,
type,
item,
order )
Value:
◆ RTEMS_LINKER_ROSET_ITEM_REFERENCE
#define RTEMS_LINKER_ROSET_ITEM_REFERENCE ( set,
type,
item )
Value:
static RTEMS_LINKER_SET_ALIGN( type ) type \
const * const _Set_reference_##set##_##item \
RTEMS_SECTION( ".rtemsroset.reference" ) RTEMS_USED = \
&_Linker_set_##set##_##item
◆ RTEMS_LINKER_RWSET
#define RTEMS_LINKER_RWSET ( set,
type )
Value:
RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_BEGIN( set )[ 0 ] \
RTEMS_SECTION( ".rtemsrwset." #set ".begin" ) RTEMS_USED; \
RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_END( set )[ 0 ] \
RTEMS_SECTION( ".rtemsrwset." #set ".end" ) RTEMS_USED
◆ RTEMS_LINKER_RWSET_CONTENT
#define RTEMS_LINKER_RWSET_CONTENT ( set,
decl )
Value:
decl \
RTEMS_SECTION( ".rtemsrwset." #set ".content" )
◆ RTEMS_LINKER_RWSET_DECLARE
#define RTEMS_LINKER_RWSET_DECLARE ( set,
type )
Value:
extern RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_BEGIN( set )[]; \
extern RTEMS_LINKER_SET_ALIGN( type ) type RTEMS_LINKER_SET_END( set )[]
◆ RTEMS_LINKER_RWSET_ITEM
#define RTEMS_LINKER_RWSET_ITEM ( set,
type,
item )
Value:
RTEMS_LINKER_SET_ALIGN( type ) type _Linker_set_##set##_##item \
RTEMS_SECTION( ".rtemsrwset." #set ".content.1" ) RTEMS_USED
◆ RTEMS_LINKER_RWSET_ITEM_DECLARE
#define RTEMS_LINKER_RWSET_ITEM_DECLARE ( set,
type,
item )
Value:
extern RTEMS_LINKER_SET_ALIGN( type ) type _Linker_set_##set##_##item \
◆ RTEMS_LINKER_RWSET_ITEM_ORDERED
#define RTEMS_LINKER_RWSET_ITEM_ORDERED ( set,
type,
item,
order )
Value:
RTEMS_SECTION( ".rtemsrwset." #set ".content.0." RTEMS_XSTRING( order ) ) \
◆ RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE
#define RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE ( set,
type,
item,
order )
Value:
◆ RTEMS_LINKER_RWSET_ITEM_REFERENCE
#define RTEMS_LINKER_RWSET_ITEM_REFERENCE ( set,
type,
item )
Value:
◆ RTEMS_LINKER_SET_ALIGN
#define RTEMS_LINKER_SET_ALIGN ( type)
Value:
#define RTEMS_ALIGNED(_alignment)
Instructs the compiler in a declaration or definition to enforce the alignment.
Definition basedefs.h:157
#define RTEMS_ALIGNOF(_type_name)
Gets the alignment requirement of the type.
Definition basedefs.h:176
◆ RTEMS_LINKER_SET_BEGIN
#define RTEMS_LINKER_SET_BEGIN ( set)
Value:
_Linker_set_##set##_begin
◆ RTEMS_LINKER_SET_END
#define RTEMS_LINKER_SET_END ( set)
Value:
_Linker_set_##set##_end
◆ RTEMS_LINKER_SET_FOREACH
#define RTEMS_LINKER_SET_FOREACH ( set,
item )
Value:
for ( \
item = (void *) _Linker_set_Obfuscate( RTEMS_LINKER_SET_BEGIN( set ) ) ; \
item != RTEMS_LINKER_SET_END( set ) ; \
++item \
◆ RTEMS_LINKER_SET_IS_EMPTY
#define RTEMS_LINKER_SET_IS_EMPTY ( set)
Value:
( RTEMS_LINKER_SET_SIZE( set ) == 0 )
◆ RTEMS_LINKER_SET_ITEM_COUNT
#define RTEMS_LINKER_SET_ITEM_COUNT ( set)
Value:
( RTEMS_LINKER_SET_SIZE( set ) \
/ sizeof( RTEMS_LINKER_SET_BEGIN( set )[ 0 ] ) )
◆ RTEMS_LINKER_SET_SIZE
#define RTEMS_LINKER_SET_SIZE ( set)
Value:
( _Linker_set_Obfuscate( RTEMS_LINKER_SET_END( set ) ) \
- _Linker_set_Obfuscate( RTEMS_LINKER_SET_BEGIN( set ) ) )
