RTEMS 6.3
#define __HAL_RTC_RESET_HANDLE_STATE(__HANDLE__)
 Reset RTC handle state.
#define __HAL_RTC_WRITEPROTECTION_DISABLE(__HANDLE__)
 Disable the write protection for RTC registers.
#define __HAL_RTC_WRITEPROTECTION_ENABLE(__HANDLE__)
 Enable the write protection for RTC registers.
#define __HAL_RTC_IS_CALENDAR_INITIALIZED(__HANDLE__)
 Check whether the RTC Calendar is initialized.
#define __HAL_RTC_DAYLIGHT_SAVING_TIME_ADD1H(__HANDLE__, __BKP__)
 Add 1 hour (summer time change).
#define __HAL_RTC_DAYLIGHT_SAVING_TIME_SUB1H(__HANDLE__, __BKP__)
 Subtract 1 hour (winter time change).
#define __HAL_RTC_ALARMA_ENABLE(__HANDLE__)
 Enable the RTC ALARMA peripheral.
#define __HAL_RTC_ALARMA_DISABLE(__HANDLE__)
 Disable the RTC ALARMA peripheral.
#define __HAL_RTC_ALARMB_ENABLE(__HANDLE__)
 Enable the RTC ALARMB peripheral.
#define __HAL_RTC_ALARMB_DISABLE(__HANDLE__)
 Disable the RTC ALARMB peripheral.
#define __HAL_RTC_ALARM_ENABLE_IT(__HANDLE__, __INTERRUPT__)
 Enable the RTC Alarm interrupt.
#define __HAL_RTC_ALARM_DISABLE_IT(__HANDLE__, __INTERRUPT__)
 Disable the RTC Alarm interrupt.
#define __HAL_RTC_ALARM_GET_IT(__HANDLE__, __INTERRUPT__)
 Check whether the specified RTC Alarm interrupt has occurred or not.
#define __HAL_RTC_ALARM_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified RTC Alarm interrupt has been enabled or not.
#define __HAL_RTC_ALARM_GET_FLAG(__HANDLE__, __FLAG__)
 Get the selected RTC Alarm's flag status.
#define __HAL_RTC_ALARM_CLEAR_FLAG(__HANDLE__, __FLAG__)
 Clear the RTC Alarm's pending flags.
#define __HAL_RTC_ALARM_EXTI_ENABLE_IT()
 Enable interrupt on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_DISABLE_IT()
 Disable interrupt on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_ENABLE_EVENT()
 Enable event on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_DISABLE_EVENT()
 Disable event on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_ENABLE_FALLING_EDGE()
 Enable falling edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_DISABLE_FALLING_EDGE()
 Disable falling edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_ENABLE_RISING_EDGE()
 Enable rising edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_DISABLE_RISING_EDGE()
 Disable rising edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_ENABLE_RISING_FALLING_EDGE()
 Enable rising & falling edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_DISABLE_RISING_FALLING_EDGE()
 Disable rising & falling edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_GET_FLAG()
 Check whether the RTC Alarm associated Exti line interrupt flag is set or not.
#define __HAL_RTC_ALARM_EXTI_CLEAR_FLAG()
 Clear the RTC Alarm associated Exti line flag.
#define __HAL_RTC_ALARM_EXTI_GENERATE_SWIT()
 Generate a Software interrupt on RTC Alarm associated Exti line.
◆ __HAL_RTC_ALARM_CLEAR_FLAG
#define __HAL_RTC_ALARM_CLEAR_FLAG ( __HANDLE__,
__FLAG__ )
Value:
((__HANDLE__)->Instance->ISR = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT)))
Parameters
__HANDLE__specifies the RTC handle.
__FLAG__specifies the RTC Alarm Flag sources to clear. This parameter can be:
  • RTC_FLAG_ALRAF
  • RTC_FLAG_ALRBF
Return values
None
◆ __HAL_RTC_ALARM_DISABLE_IT
#define __HAL_RTC_ALARM_DISABLE_IT ( __HANDLE__,
__INTERRUPT__ )
Value:
((__HANDLE__)->Instance->CR &= ~(__INTERRUPT__))
Parameters
__INTERRUPT__specifies the RTC Alarm interrupt sources to be enabled or disabled. This parameter can be any combination of the following values:
Return values
None
◆ __HAL_RTC_ALARM_ENABLE_IT
#define __HAL_RTC_ALARM_ENABLE_IT ( __HANDLE__,
__INTERRUPT__ )
Value:
((__HANDLE__)->Instance->CR |= (__INTERRUPT__))
Parameters
Return values
None
◆ __HAL_RTC_ALARM_EXTI_CLEAR_FLAG
#define __HAL_RTC_ALARM_EXTI_CLEAR_FLAG ( )
Value:
#define RTC_EXTI_LINE_ALARM_EVENT
Definition stm32h7xx_hal_rtc.h:1039
Return values
None.
◆ __HAL_RTC_ALARM_EXTI_DISABLE_EVENT
#define __HAL_RTC_ALARM_EXTI_DISABLE_EVENT ( )
Value:
(EXTI->EMR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT))
Return values
None.
◆ __HAL_RTC_ALARM_EXTI_DISABLE_FALLING_EDGE
#define __HAL_RTC_ALARM_EXTI_DISABLE_FALLING_EDGE ( )
Value:
(EXTI->FTSR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT))
Return values
None
◆ __HAL_RTC_ALARM_EXTI_DISABLE_IT
#define __HAL_RTC_ALARM_EXTI_DISABLE_IT ( )
Value:
(EXTI->IMR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT))
Return values
None
◆ __HAL_RTC_ALARM_EXTI_DISABLE_RISING_EDGE
#define __HAL_RTC_ALARM_EXTI_DISABLE_RISING_EDGE ( )
Value:
(EXTI->RTSR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT))
Return values
None
◆ __HAL_RTC_ALARM_EXTI_DISABLE_RISING_FALLING_EDGE
#define __HAL_RTC_ALARM_EXTI_DISABLE_RISING_FALLING_EDGE ( )
Value:
do { \
__HAL_RTC_ALARM_EXTI_DISABLE_RISING_EDGE(); \
__HAL_RTC_ALARM_EXTI_DISABLE_FALLING_EDGE(); \
} while(0u)
Return values
None
◆ __HAL_RTC_ALARM_EXTI_ENABLE_EVENT
#define __HAL_RTC_ALARM_EXTI_ENABLE_EVENT ( )
Value:
Return values
None.
◆ __HAL_RTC_ALARM_EXTI_ENABLE_FALLING_EDGE
#define __HAL_RTC_ALARM_EXTI_ENABLE_FALLING_EDGE ( )
Value:
(EXTI->FTSR1 |= RTC_EXTI_LINE_ALARM_EVENT)
Return values
None
◆ __HAL_RTC_ALARM_EXTI_ENABLE_IT
#define __HAL_RTC_ALARM_EXTI_ENABLE_IT ( )
Value:
Return values
None
◆ __HAL_RTC_ALARM_EXTI_ENABLE_RISING_EDGE
#define __HAL_RTC_ALARM_EXTI_ENABLE_RISING_EDGE ( )
Value:
(EXTI->RTSR1 |= RTC_EXTI_LINE_ALARM_EVENT)
Return values
None
◆ __HAL_RTC_ALARM_EXTI_ENABLE_RISING_FALLING_EDGE
#define __HAL_RTC_ALARM_EXTI_ENABLE_RISING_FALLING_EDGE ( )
Value:
do { \
__HAL_RTC_ALARM_EXTI_ENABLE_RISING_EDGE(); \
__HAL_RTC_ALARM_EXTI_ENABLE_FALLING_EDGE(); \
} while(0u)
Return values
None
◆ __HAL_RTC_ALARM_EXTI_GENERATE_SWIT
#define __HAL_RTC_ALARM_EXTI_GENERATE_SWIT ( )
Value:
(EXTI->SWIER1 |= RTC_EXTI_LINE_ALARM_EVENT)
Return values
None
◆ __HAL_RTC_ALARM_EXTI_GET_FLAG
#define __HAL_RTC_ALARM_EXTI_GET_FLAG ( )
Value:
Return values
LineStatus.
◆ __HAL_RTC_ALARM_GET_FLAG
#define __HAL_RTC_ALARM_GET_FLAG ( __HANDLE__,
__FLAG__ )
Value:
(((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U)
Parameters
__FLAG__specifies the RTC Alarm Flag sources to check. This parameter can be:
  • RTC_FLAG_ALRAF
  • RTC_FLAG_ALRBF
  • RTC_FLAG_ALRAWF
  • RTC_FLAG_ALRBWF
Return values
None
◆ __HAL_RTC_ALARM_GET_IT
#define __HAL_RTC_ALARM_GET_IT ( __HANDLE__,
__INTERRUPT__ )
Value:
(((((__HANDLE__)->Instance->ISR)& (__INTERRUPT__ >> 4)) != 0U)? 1U : 0U)
Parameters
__INTERRUPT__specifies the RTC Alarm interrupt sources to check. This parameter can be:
Return values
None
◆ __HAL_RTC_ALARM_GET_IT_SOURCE
#define __HAL_RTC_ALARM_GET_IT_SOURCE ( __HANDLE__,
__INTERRUPT__ )
Value:
(((((__HANDLE__)->Instance->CR) & (__INTERRUPT__)) != 0U) ? 1U : 0U)
Parameters
Return values
None
◆ __HAL_RTC_ALARMA_DISABLE
#define __HAL_RTC_ALARMA_DISABLE ( __HANDLE__)
Value:
((__HANDLE__)->Instance->CR &= ~(RTC_CR_ALRAE))
Parameters
Return values
None
◆ __HAL_RTC_ALARMA_ENABLE
#define __HAL_RTC_ALARMA_ENABLE ( __HANDLE__)
Value:
((__HANDLE__)->Instance->CR |= (RTC_CR_ALRAE))
Parameters
Return values
None
◆ __HAL_RTC_ALARMB_DISABLE
#define __HAL_RTC_ALARMB_DISABLE ( __HANDLE__)
Value:
((__HANDLE__)->Instance->CR &= ~(RTC_CR_ALRBE))
Parameters
Return values
None
◆ __HAL_RTC_ALARMB_ENABLE
#define __HAL_RTC_ALARMB_ENABLE ( __HANDLE__)
Value:
((__HANDLE__)->Instance->CR |= (RTC_CR_ALRBE))
Parameters
Return values
None
◆ __HAL_RTC_DAYLIGHT_SAVING_TIME_ADD1H
#define __HAL_RTC_DAYLIGHT_SAVING_TIME_ADD1H ( __HANDLE__,
__BKP__ )
Value:
do { \
__HAL_RTC_WRITEPROTECTION_DISABLE(__HANDLE__); \
SET_BIT((__HANDLE__)->Instance->CR, RTC_CR_ADD1H); \
MODIFY_REG((__HANDLE__)->Instance->CR, RTC_CR_BKP , (__BKP__)); \
__HAL_RTC_WRITEPROTECTION_ENABLE(__HANDLE__); \
} while(0u);
Parameters
__BKP__Backup This parameter can be:
  • RTC_STOREOPERATION_RESET
  • RTC_STOREOPERATION_SET
Return values
None
◆ __HAL_RTC_DAYLIGHT_SAVING_TIME_SUB1H
#define __HAL_RTC_DAYLIGHT_SAVING_TIME_SUB1H ( __HANDLE__,
__BKP__ )
Value:
do { \
SET_BIT((__HANDLE__)->Instance->CR, RTC_CR_SUB1H); \
} while(0u);
Parameters
Return values
None
◆ __HAL_RTC_IS_CALENDAR_INITIALIZED
#define __HAL_RTC_IS_CALENDAR_INITIALIZED ( __HANDLE__)
Value:
(((((__HANDLE__)->Instance->ISR) & (RTC_FLAG_INITS)) == RTC_FLAG_INITS) ? 1U : 0U)
Parameters
Return values
None
◆ __HAL_RTC_RESET_HANDLE_STATE
#define __HAL_RTC_RESET_HANDLE_STATE ( __HANDLE__)
Value:
((__HANDLE__)->State = HAL_RTC_STATE_RESET)
@ HAL_RTC_STATE_RESET
Definition stm32h7xx_hal_rtc.h:50
Parameters
__HANDLE__RTC handle.
Return values
None
◆ __HAL_RTC_WRITEPROTECTION_DISABLE
#define __HAL_RTC_WRITEPROTECTION_DISABLE ( __HANDLE__)
Value:
do{ \
(__HANDLE__)->Instance->WPR = 0xCAU; \
(__HANDLE__)->Instance->WPR = 0x53U; \
} while(0u)
Parameters
Return values
None
◆ __HAL_RTC_WRITEPROTECTION_ENABLE
#define __HAL_RTC_WRITEPROTECTION_ENABLE ( __HANDLE__)
Value:
do{ \
(__HANDLE__)->Instance->WPR = 0xFFU; \
} while(0u)
Parameters
Return values
None
