RTEMS 6.3
#define RDC_MDA_COUNT   (12U)
#define RDC_PDAP_COUNT   (128U)
#define RDC_MRSA_COUNT   (59U)
#define RDC_MREA_COUNT   (59U)
#define RDC_MRC_COUNT   (59U)
#define RDC_MRVS_COUNT   (59U)
VIR - Version Information
#define RDC_VIR_NDID_MASK   (0xFU)
#define RDC_VIR_NDID_SHIFT   (0U)
#define RDC_VIR_NDID(x)
#define RDC_VIR_NMSTR_MASK   (0xFF0U)
#define RDC_VIR_NMSTR_SHIFT   (4U)
#define RDC_VIR_NMSTR(x)
#define RDC_VIR_NPER_MASK   (0xFF000U)
#define RDC_VIR_NPER_SHIFT   (12U)
#define RDC_VIR_NPER(x)
#define RDC_VIR_NRGN_MASK   (0xFF00000U)
#define RDC_VIR_NRGN_SHIFT   (20U)
#define RDC_VIR_NRGN(x)
STAT - Status
#define RDC_STAT_DID_MASK   (0xFU)
#define RDC_STAT_DID_SHIFT   (0U)
#define RDC_STAT_DID(x)
#define RDC_STAT_PDS_MASK   (0x100U)
#define RDC_STAT_PDS_SHIFT   (8U)
#define RDC_STAT_PDS(x)
INTCTRL - Interrupt and Control
#define RDC_INTCTRL_RCI_EN_MASK   (0x1U)
#define RDC_INTCTRL_RCI_EN_SHIFT   (0U)
#define RDC_INTCTRL_RCI_EN(x)
INTSTAT - Interrupt Status
#define RDC_INTSTAT_INT_MASK   (0x1U)
#define RDC_INTSTAT_INT_SHIFT   (0U)
#define RDC_INTSTAT_INT(x)
MDA - Master Domain Assignment
#define RDC_MDA_DID_MASK   (0x3U)
#define RDC_MDA_DID_SHIFT   (0U)
#define RDC_MDA_DID(x)
#define RDC_MDA_LCK_MASK   (0x80000000U)
#define RDC_MDA_LCK_SHIFT   (31U)
#define RDC_MDA_LCK(x)
PDAP - Peripheral Domain Access Permissions
#define RDC_PDAP_D0W_MASK   (0x1U)
#define RDC_PDAP_D0W_SHIFT   (0U)
#define RDC_PDAP_D0W(x)
#define RDC_PDAP_D0R_MASK   (0x2U)
#define RDC_PDAP_D0R_SHIFT   (1U)
#define RDC_PDAP_D0R(x)
#define RDC_PDAP_D1W_MASK   (0x4U)
#define RDC_PDAP_D1W_SHIFT   (2U)
#define RDC_PDAP_D1W(x)
#define RDC_PDAP_D1R_MASK   (0x8U)
#define RDC_PDAP_D1R_SHIFT   (3U)
#define RDC_PDAP_D1R(x)
#define RDC_PDAP_SREQ_MASK   (0x40000000U)
#define RDC_PDAP_SREQ_SHIFT   (30U)
#define RDC_PDAP_SREQ(x)
#define RDC_PDAP_LCK_MASK   (0x80000000U)
#define RDC_PDAP_LCK_SHIFT   (31U)
#define RDC_PDAP_LCK(x)
MRSA - Memory Region Start Address
#define RDC_MRSA_SADR_MASK   (0xFFFFFF80U)
#define RDC_MRSA_SADR_SHIFT   (7U)
#define RDC_MRSA_SADR(x)
MREA - Memory Region End Address
#define RDC_MREA_EADR_MASK   (0xFFFFFF80U)
#define RDC_MREA_EADR_SHIFT   (7U)
#define RDC_MREA_EADR(x)
MRC - Memory Region Control
#define RDC_MRC_D0W_MASK   (0x1U)
#define RDC_MRC_D0W_SHIFT   (0U)
#define RDC_MRC_D0W(x)
#define RDC_MRC_D0R_MASK   (0x2U)
#define RDC_MRC_D0R_SHIFT   (1U)
#define RDC_MRC_D0R(x)
#define RDC_MRC_D1W_MASK   (0x4U)
#define RDC_MRC_D1W_SHIFT   (2U)
#define RDC_MRC_D1W(x)
#define RDC_MRC_D1R_MASK   (0x8U)
#define RDC_MRC_D1R_SHIFT   (3U)
#define RDC_MRC_D1R(x)
#define RDC_MRC_ENA_MASK   (0x40000000U)
#define RDC_MRC_ENA_SHIFT   (30U)
#define RDC_MRC_ENA(x)
#define RDC_MRC_LCK_MASK   (0x80000000U)
#define RDC_MRC_LCK_SHIFT   (31U)
#define RDC_MRC_LCK(x)
MRVS - Memory Region Violation Status
#define RDC_MRVS_VDID_MASK   (0x3U)
#define RDC_MRVS_VDID_SHIFT   (0U)
#define RDC_MRVS_VDID(x)
#define RDC_MRVS_AD_MASK   (0x10U)
#define RDC_MRVS_AD_SHIFT   (4U)
#define RDC_MRVS_AD(x)
#define RDC_MRVS_VADR_MASK   (0xFFFFFFE0U)
#define RDC_MRVS_VADR_SHIFT   (5U)
#define RDC_MRVS_VADR(x)
◆ RDC_INTCTRL_RCI_EN [1/2]
#define RDC_INTCTRL_RCI_EN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_INTCTRL_RCI_EN_SHIFT)) & RDC_INTCTRL_RCI_EN_MASK)
RCI_EN - Restoration Complete Interrupt 0b0..Interrupt Disabled 0b1..Interrupt Enabled
◆ RDC_INTCTRL_RCI_EN [2/2]
Value:
◆ RDC_INTSTAT_INT [1/2]
#define RDC_INTSTAT_INT ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_INTSTAT_INT_SHIFT)) & RDC_INTSTAT_INT_MASK)
INT - Interrupt Status 0b0..No Interrupt Pending 0b1..Interrupt Pending
◆ RDC_INTSTAT_INT [2/2]
Value:
◆ RDC_MDA_DID [1/2]
#define RDC_MDA_DID ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MDA_DID_SHIFT)) & RDC_MDA_DID_MASK)
DID - Domain ID 0b00..Master assigned to Processing Domain 0 0b01..Master assigned to Processing Domain 1 0b10..Reserved 0b11..Reserved
◆ RDC_MDA_DID [2/2]
Value:
◆ RDC_MDA_LCK [1/2]
#define RDC_MDA_LCK ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MDA_LCK_SHIFT)) & RDC_MDA_LCK_MASK)
LCK - Assignment Lock 0b0..Not Locked 0b1..Locked
◆ RDC_MDA_LCK [2/2]
Value:
◆ RDC_MRC_D0R [1/2]
#define RDC_MRC_D0R ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MRC_D0R_SHIFT)) & RDC_MRC_D0R_MASK)
D0R - Domain 0 Read Access to Region 0b0..Processing Domain 0 does not have Read access to the memory region 0b1..Processing Domain 0 has Read access to the memory region
◆ RDC_MRC_D0R [2/2]
Value:
◆ RDC_MRC_D0W [1/2]
#define RDC_MRC_D0W ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MRC_D0W_SHIFT)) & RDC_MRC_D0W_MASK)
D0W - Domain 0 Write Access to Region 0b0..Processing Domain 0 does not have Write access to the memory region 0b1..Processing Domain 0 has Write access to the memory region
◆ RDC_MRC_D0W [2/2]
Value:
◆ RDC_MRC_D1R [1/2]
#define RDC_MRC_D1R ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MRC_D1R_SHIFT)) & RDC_MRC_D1R_MASK)
D1R - Domain 1 Read Access to Region 0b0..Processing Domain 1 does not have Read access to the memory region 0b1..Processing Domain 1 has Read access to the memory region
◆ RDC_MRC_D1R [2/2]
Value:
◆ RDC_MRC_D1W [1/2]
#define RDC_MRC_D1W ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MRC_D1W_SHIFT)) & RDC_MRC_D1W_MASK)
D1W - Domain 1 Write Access to Region 0b0..Processing Domain 1 does not have Write access to the memory region 0b1..Processing Domain 1 has Write access to the memory region
◆ RDC_MRC_D1W [2/2]
Value:
◆ RDC_MRC_ENA [1/2]
#define RDC_MRC_ENA ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MRC_ENA_SHIFT)) & RDC_MRC_ENA_MASK)
ENA - Region Enable 0b0..Memory region is not defined or restricted. 0b1..Memory boundaries, domain permissions and controls are in effect.
◆ RDC_MRC_ENA [2/2]
Value:
◆ RDC_MRC_LCK [1/2]
#define RDC_MRC_LCK ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MRC_LCK_SHIFT)) & RDC_MRC_LCK_MASK)
LCK - Region Lock 0b0..No Lock. All fields in this register may be modified. 0b1..Locked. No fields in this register may be modified except ENA, which may be set but not cleared.
◆ RDC_MRC_LCK [2/2]
Value:
◆ RDC_MREA_EADR [1/2]
#define RDC_MREA_EADR ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MREA_EADR_SHIFT)) & RDC_MREA_EADR_MASK)
EADR - Upper bound for memory region
◆ RDC_MREA_EADR [2/2]
Value:
◆ RDC_MRSA_SADR [1/2]
#define RDC_MRSA_SADR ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MRSA_SADR_SHIFT)) & RDC_MRSA_SADR_MASK)
SADR - Start address for memory region
◆ RDC_MRSA_SADR [2/2]
Value:
◆ RDC_MRVS_AD [1/2]
#define RDC_MRVS_AD ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MRVS_AD_SHIFT)) & RDC_MRVS_AD_MASK)
AD - Access Denied
◆ RDC_MRVS_AD [2/2]
Value:
AD - Access Denied
◆ RDC_MRVS_VADR [1/2]
#define RDC_MRVS_VADR ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MRVS_VADR_SHIFT)) & RDC_MRVS_VADR_MASK)
VADR - Violating Address
◆ RDC_MRVS_VADR [2/2]
Value:
◆ RDC_MRVS_VDID [1/2]
#define RDC_MRVS_VDID ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_MRVS_VDID_SHIFT)) & RDC_MRVS_VDID_MASK)
VDID - Violating Domain ID 0b00..Processing Domain 0 0b01..Processing Domain 1 0b10..Reserved 0b11..Reserved
◆ RDC_MRVS_VDID [2/2]
Value:
◆ RDC_PDAP_D0R [1/2]
#define RDC_PDAP_D0R ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_PDAP_D0R_SHIFT)) & RDC_PDAP_D0R_MASK)
D0R - Domain 0 Read Access 0b0..No Read Access 0b1..Read Access Allowed
◆ RDC_PDAP_D0R [2/2]
Value:
◆ RDC_PDAP_D0W [1/2]
#define RDC_PDAP_D0W ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_PDAP_D0W_SHIFT)) & RDC_PDAP_D0W_MASK)
D0W - Domain 0 Write Access 0b0..No Write Access 0b1..Write Access Allowed
◆ RDC_PDAP_D0W [2/2]
Value:
◆ RDC_PDAP_D1R [1/2]
#define RDC_PDAP_D1R ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_PDAP_D1R_SHIFT)) & RDC_PDAP_D1R_MASK)
D1R - Domain 1 Read Access 0b0..No Read Access 0b1..Read Access Allowed
◆ RDC_PDAP_D1R [2/2]
Value:
◆ RDC_PDAP_D1W [1/2]
#define RDC_PDAP_D1W ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_PDAP_D1W_SHIFT)) & RDC_PDAP_D1W_MASK)
D1W - Domain 1 Write Access 0b0..No Write Access 0b1..Write Access Allowed
◆ RDC_PDAP_D1W [2/2]
Value:
◆ RDC_PDAP_LCK [1/2]
#define RDC_PDAP_LCK ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_PDAP_LCK_SHIFT)) & RDC_PDAP_LCK_MASK)
LCK - Peripheral Permissions Lock 0b0..Not Locked 0b1..Locked
◆ RDC_PDAP_LCK [2/2]
Value:
◆ RDC_PDAP_SREQ [1/2]
#define RDC_PDAP_SREQ ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_PDAP_SREQ_SHIFT)) & RDC_PDAP_SREQ_MASK)
SREQ - Semaphore Required 0b0..Semaphores have no effect 0b1..Semaphores are enforced
◆ RDC_PDAP_SREQ [2/2]
Value:
◆ RDC_STAT_DID [1/2]
#define RDC_STAT_DID ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_STAT_DID_SHIFT)) & RDC_STAT_DID_MASK)
DID - Domain ID
◆ RDC_STAT_DID [2/2]
Value:
DID - Domain ID
◆ RDC_STAT_PDS [1/2]
#define RDC_STAT_PDS ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_STAT_PDS_SHIFT)) & RDC_STAT_PDS_MASK)
PDS - Power Domain Status 0b0..Power Down Domain is OFF 0b1..Power Down Domain is ON
◆ RDC_STAT_PDS [2/2]
Value:
◆ RDC_VIR_NDID [1/2]
#define RDC_VIR_NDID ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_VIR_NDID_SHIFT)) & RDC_VIR_NDID_MASK)
NDID - Number of Domains
◆ RDC_VIR_NDID [2/2]
Value:
◆ RDC_VIR_NMSTR [1/2]
#define RDC_VIR_NMSTR ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_VIR_NMSTR_SHIFT)) & RDC_VIR_NMSTR_MASK)
NMSTR - Number of Masters
◆ RDC_VIR_NMSTR [2/2]
Value:
◆ RDC_VIR_NPER [1/2]
#define RDC_VIR_NPER ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_VIR_NPER_SHIFT)) & RDC_VIR_NPER_MASK)
NPER - Number of Peripherals
◆ RDC_VIR_NPER [2/2]
Value:
◆ RDC_VIR_NRGN [1/2]
#define RDC_VIR_NRGN ( x)
Value:
(((uint32_t)(((uint32_t)(x)) << RDC_VIR_NRGN_SHIFT)) & RDC_VIR_NRGN_MASK)
NRGN - Number of Memory Regions
◆ RDC_VIR_NRGN [2/2]
Value:
