RTEMS 6.3
Pipe support for different types of descriptors. More...
typedef int(*) rtems_pipe_handler_t(int filsdes[2])
 Pipe handler.
typedef int(*) rtems_pipe2_handler_t(int filsdes[2], int flags)
 Pipe2 handler.
void rtems_filesystem_register_pipe (rtems_pipe_handler_t pipe_handler)
 Register a file system pipe call handler.
void rtems_filesystem_register_pipe2 (rtems_pipe2_handler_t pipe2_handler)
 Register a file system pipe2 call handler.
◆ rtems_filesystem_register_pipe()
void rtems_filesystem_register_pipe ( rtems_pipe_handler_t pipe_handler)
Parameters
[in]pipe_handlerHandler to called when pipe() is called.
◆ rtems_filesystem_register_pipe2()
void rtems_filesystem_register_pipe2 ( rtems_pipe2_handler_t pipe2_handler)
Parameters
[in]pipe2_handlerHandler to called when pipe2() is called.
