RTEMS 6.3
MIF_AUTHEN_CTRL - MIF Authentication Control | |
| #define | PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_MASK (0x100000U) |
| #define | PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG_SHIFT (20U) |
| #define | PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG(x) |
MIF_MLPL_SLEEP - MIF MLPL control of SLEEP | |
| #define | PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_MASK (0xFFFFU) |
| #define | PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL_SHIFT (0U) |
| #define | PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL(x) |
MIF_MLPL_IG - MIF MLPL control of IG | |
| #define | PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_MASK (0xFFFFU) |
| #define | PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL_SHIFT (0U) |
| #define | PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL(x) |
MIF_MLPL_LS - MIF MLPL control of LS | |
| #define | PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_MASK (0xFFFFU) |
| #define | PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL_SHIFT (0U) |
| #define | PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL(x) |
MIF_MLPL_HS - MIF MLPL control of HS | |
| #define | PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_MASK (0xFFFFU) |
| #define | PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL_SHIFT (0U) |
| #define | PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL(x) |
MIF_MLPL_STDBY - MIF MLPL control of STDBY | |
| #define | PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_MASK (0xFFFFU) |
| #define | PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL_SHIFT (0U) |
| #define | PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL(x) |
MIF_MLPL_ARR_PDN - MIF MLPL control of array power down | |
| #define | PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_MASK (0xFFFFU) |
| #define | PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL_SHIFT (0U) |
| #define | PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL(x) |
MIF_MLPL_PER_PDN - MIF MLPL control of peripheral power down | |
| #define | PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_MASK (0xFFFFU) |
| #define | PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL_SHIFT (0U) |
| #define | PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL(x) |
MIF_MLPL_INITN - MIF MLPL control of INITN | |
| #define | PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_MASK (0xFFFFU) |
| #define | PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL_SHIFT (0U) |
| #define | PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL(x) |
| #define | PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_MASK (0x80000000U) |
| #define | PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK_SHIFT (31U) |
| #define | PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK(x) |
MIF_MLPL_ISO - MIF MLPL control of isolation enable | |
| #define | PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_MASK (0xFFFFU) |
| #define | PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL_SHIFT (0U) |
| #define | PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL(x) |
| #define PGMC_MIF_MIF_AUTHEN_CTRL_LOCK_CFG | ( | x | ) |
LOCK_CFG - Configuration lock
| #define PGMC_MIF_MIF_MLPL_ARR_PDN_MLPL_CTRL | ( | x | ) |
MLPL_CTRL - Signal behavior at each MLPL
| #define PGMC_MIF_MIF_MLPL_HS_MLPL_CTRL | ( | x | ) |
| #define PGMC_MIF_MIF_MLPL_IG_MLPL_CTRL | ( | x | ) |
| #define PGMC_MIF_MIF_MLPL_INITN_BYPASS_VDD_OK | ( | x | ) |
BYPASS_VDD_OK - Bypass vdd_ok. This field is locked by AUTHEN_CTRL[LOCK_CFG] field.
| #define PGMC_MIF_MIF_MLPL_INITN_MLPL_CTRL | ( | x | ) |
| #define PGMC_MIF_MIF_MLPL_ISO_MLPL_CTRL | ( | x | ) |
| #define PGMC_MIF_MIF_MLPL_LS_MLPL_CTRL | ( | x | ) |
| #define PGMC_MIF_MIF_MLPL_PER_PDN_MLPL_CTRL | ( | x | ) |
| #define PGMC_MIF_MIF_MLPL_SLEEP_MLPL_CTRL | ( | x | ) |
| #define PGMC_MIF_MIF_MLPL_STDBY_MLPL_CTRL | ( | x | ) |
