RTEMS 6.3
CR - Control Register | |
| #define | OTFAD_CR_FERR_MASK (0x2U) |
| #define | OTFAD_CR_FERR_SHIFT (1U) |
| #define | OTFAD_CR_FERR(x) |
| #define | OTFAD_CR_FLDM_MASK (0x8U) |
| #define | OTFAD_CR_FLDM_SHIFT (3U) |
| #define | OTFAD_CR_FLDM(x) |
| #define | OTFAD_CR_KBSE_MASK (0x10U) |
| #define | OTFAD_CR_KBSE_SHIFT (4U) |
| #define | OTFAD_CR_KBSE(x) |
| #define | OTFAD_CR_KBPE_MASK (0x20U) |
| #define | OTFAD_CR_KBPE_SHIFT (5U) |
| #define | OTFAD_CR_KBPE(x) |
| #define | OTFAD_CR_RRAE_MASK (0x80U) |
| #define | OTFAD_CR_RRAE_SHIFT (7U) |
| #define | OTFAD_CR_RRAE(x) |
| #define | OTFAD_CR_SKBP_MASK (0x40000000U) |
| #define | OTFAD_CR_SKBP_SHIFT (30U) |
| #define | OTFAD_CR_SKBP(x) |
| #define | OTFAD_CR_GE_MASK (0x80000000U) |
| #define | OTFAD_CR_GE_SHIFT (31U) |
| #define | OTFAD_CR_GE(x) |
SR - Status Register | |
| #define | OTFAD_SR_KBERR_MASK (0x1U) |
| #define | OTFAD_SR_KBERR_SHIFT (0U) |
| #define | OTFAD_SR_KBERR(x) |
| #define | OTFAD_SR_MDPCP_MASK (0x2U) |
| #define | OTFAD_SR_MDPCP_SHIFT (1U) |
| #define | OTFAD_SR_MDPCP(x) |
| #define | OTFAD_SR_MODE_MASK (0xCU) |
| #define | OTFAD_SR_MODE_SHIFT (2U) |
| #define | OTFAD_SR_MODE(x) |
| #define | OTFAD_SR_NCTX_MASK (0xF0U) |
| #define | OTFAD_SR_NCTX_SHIFT (4U) |
| #define | OTFAD_SR_NCTX(x) |
| #define | OTFAD_SR_CTXER0_MASK (0x100U) |
| #define | OTFAD_SR_CTXER0_SHIFT (8U) |
| #define | OTFAD_SR_CTXER0(x) |
| #define | OTFAD_SR_CTXER1_MASK (0x200U) |
| #define | OTFAD_SR_CTXER1_SHIFT (9U) |
| #define | OTFAD_SR_CTXER1(x) |
| #define | OTFAD_SR_CTXER2_MASK (0x400U) |
| #define | OTFAD_SR_CTXER2_SHIFT (10U) |
| #define | OTFAD_SR_CTXER2(x) |
| #define | OTFAD_SR_CTXER3_MASK (0x800U) |
| #define | OTFAD_SR_CTXER3_SHIFT (11U) |
| #define | OTFAD_SR_CTXER3(x) |
| #define | OTFAD_SR_CTXIE0_MASK (0x10000U) |
| #define | OTFAD_SR_CTXIE0_SHIFT (16U) |
| #define | OTFAD_SR_CTXIE0(x) |
| #define | OTFAD_SR_CTXIE1_MASK (0x20000U) |
| #define | OTFAD_SR_CTXIE1_SHIFT (17U) |
| #define | OTFAD_SR_CTXIE1(x) |
| #define | OTFAD_SR_CTXIE2_MASK (0x40000U) |
| #define | OTFAD_SR_CTXIE2_SHIFT (18U) |
| #define | OTFAD_SR_CTXIE2(x) |
| #define | OTFAD_SR_CTXIE3_MASK (0x80000U) |
| #define | OTFAD_SR_CTXIE3_SHIFT (19U) |
| #define | OTFAD_SR_CTXIE3(x) |
| #define | OTFAD_SR_HRL_MASK (0xF000000U) |
| #define | OTFAD_SR_HRL_SHIFT (24U) |
| #define | OTFAD_SR_HRL(x) |
| #define | OTFAD_SR_RRAM_MASK (0x10000000U) |
| #define | OTFAD_SR_RRAM_SHIFT (28U) |
| #define | OTFAD_SR_RRAM(x) |
| #define | OTFAD_SR_GEM_MASK (0x20000000U) |
| #define | OTFAD_SR_GEM_SHIFT (29U) |
| #define | OTFAD_SR_GEM(x) |
| #define | OTFAD_SR_KBPE_MASK (0x40000000U) |
| #define | OTFAD_SR_KBPE_SHIFT (30U) |
| #define | OTFAD_SR_KBPE(x) |
| #define | OTFAD_SR_KBD_MASK (0x80000000U) |
| #define | OTFAD_SR_KBD_SHIFT (31U) |
| #define | OTFAD_SR_KBD(x) |
| #define | XRDC2_SR_DIN_MASK (0xFU) |
| #define | XRDC2_SR_DIN_SHIFT (0U) |
| #define | XRDC2_SR_DIN(x) |
| #define | XRDC2_SR_HRL_MASK (0xF0U) |
| #define | XRDC2_SR_HRL_SHIFT (4U) |
| #define | XRDC2_SR_HRL(x) |
| #define | XRDC2_SR_GCLO_MASK (0xF00U) |
| #define | XRDC2_SR_GCLO_SHIFT (8U) |
| #define | XRDC2_SR_GCLO(x) |
KEY - AES Key Word | |
| #define | OTFAD_KEY_KEY_MASK (0xFFFFFFFFU) |
| #define | OTFAD_KEY_KEY_SHIFT (0U) |
| #define | OTFAD_KEY_KEY(x) |
CTR - AES Counter Word | |
| #define | OTFAD_CTR_CTR_MASK (0xFFFFFFFFU) |
| #define | OTFAD_CTR_CTR_SHIFT (0U) |
| #define | OTFAD_CTR_CTR(x) |
RGD_W0 - AES Region Descriptor Word0 | |
| #define | OTFAD_RGD_W0_SRTADDR_MASK (0xFFFFFC00U) |
| #define | OTFAD_RGD_W0_SRTADDR_SHIFT (10U) |
| #define | OTFAD_RGD_W0_SRTADDR(x) |
RGD_W1 - AES Region Descriptor Word1 | |
| #define | OTFAD_RGD_W1_VLD_MASK (0x1U) |
| #define | OTFAD_RGD_W1_VLD_SHIFT (0U) |
| #define | OTFAD_RGD_W1_VLD(x) |
| #define | OTFAD_RGD_W1_ADE_MASK (0x2U) |
| #define | OTFAD_RGD_W1_ADE_SHIFT (1U) |
| #define | OTFAD_RGD_W1_ADE(x) |
| #define | OTFAD_RGD_W1_RO_MASK (0x4U) |
| #define | OTFAD_RGD_W1_RO_SHIFT (2U) |
| #define | OTFAD_RGD_W1_RO(x) |
| #define | OTFAD_RGD_W1_ENDADDR_MASK (0xFFFFFC00U) |
| #define | OTFAD_RGD_W1_ENDADDR_SHIFT (10U) |
| #define | OTFAD_RGD_W1_ENDADDR(x) |
| #define OTFAD_CR_FERR | ( | x | ) |
FERR - Force Error 0b0..No effect on the SR[KBERE] indicator. 0b1..SR[KBERR] is immediately set after a write with this data bit set.
| #define OTFAD_CR_FLDM | ( | x | ) |
FLDM - Force Logically Disabled Mode 0b0..No effect on the operating mode. 0b1..Force entry into LDM after a write with this data bit set. SR[MODE] signals the operating mode.
| #define OTFAD_CR_GE | ( | x | ) |
GE - Global OTFAD Enable 0b0..OTFAD has decryption disabled. All data fetched by the FlexSPI bypasses OTFAD processing. 0b1..OTFAD has decryption enabled, and processes data fetched by the FlexSPI as defined by the hardware configuration.
| #define OTFAD_CR_KBPE | ( | x | ) |
KBPE - Key Blob Processing Enable 0b0..Key blob processing is disabled. 0b1..Key blob processing is enabled.
| #define OTFAD_CR_KBSE | ( | x | ) |
KBSE - Key Blob Scramble Enable 0b0..Key blob KEK scrambling is disabled. 0b1..Key blob KEK scrambling is enabled.
| #define OTFAD_CR_RRAE | ( | x | ) |
RRAE - Restricted Register Access Enable 0b0..Register access is fully enabled. The OTFAD programming model registers can be accessed "normally". 0b1..Register access is restricted and only the CR, SR and optional MDPC registers can be accessed; others are treated as RAZ/WI.
| #define OTFAD_CR_SKBP | ( | x | ) |
SKBP - Start key blob processing 0b0..Key blob processing is not initiated. 0b1..Properly-enabled key blob processing is initiated.
| #define OTFAD_CTR_CTR | ( | x | ) |
CTR - AES Counter
CTR - AES Counter
| #define OTFAD_KEY_KEY | ( | x | ) |
KEY - AES Key
KEY - AES Key
| #define OTFAD_RGD_W0_SRTADDR | ( | x | ) |
SRTADDR - Start Address
| #define OTFAD_RGD_W1_ADE | ( | x | ) |
ADE - AES Decryption Enable. 0b0..Bypass the fetched data. 0b1..Perform the CTR-AES128 mode decryption on the fetched data.
| #define OTFAD_RGD_W1_ENDADDR | ( | x | ) |
ENDADDR - End Address
| #define OTFAD_RGD_W1_RO | ( | x | ) |
RO - Read-Only 0b0..The context registers can be accessed normally (as defined by SR[RRAM]). 0b1..The context registers are read-only and accesses may be further restricted based on SR[RRAM].
| #define OTFAD_RGD_W1_VLD | ( | x | ) |
VLD - Valid 0b0..Context is invalid. 0b1..Context is valid.
| #define OTFAD_SR_CTXER0 | ( | x | ) |
CTXER0 - Context Error 0b0..No key blob error was detected for context "n". 0b1..A key blob integrity error might have been detected in context "n".
| #define OTFAD_SR_CTXER1 | ( | x | ) |
CTXER1 - Context Error 0b0..No key blob error was detected for context "n". 0b1..A key blob integrity error might have been detected in context "n".
| #define OTFAD_SR_CTXER2 | ( | x | ) |
CTXER2 - Context Error 0b0..No key blob error was detected for context "n". 0b1..A key blob integrity error might have been detected in context "n".
| #define OTFAD_SR_CTXER3 | ( | x | ) |
CTXER3 - Context Error 0b0..No key blob error was detected for context "n". 0b1..A key blob integrity error might have been detected in context "n".
| #define OTFAD_SR_CTXIE0 | ( | x | ) |
CTXIE0 - Context Integrity Error 0b0..No key blob integrity error was detected for context "n". 0b1..A key blob integrity error was detected in context "n".
| #define OTFAD_SR_CTXIE1 | ( | x | ) |
CTXIE1 - Context Integrity Error 0b0..No key blob integrity error was detected for context "n". 0b1..A key blob integrity error was detected in context "n".
| #define OTFAD_SR_CTXIE2 | ( | x | ) |
CTXIE2 - Context Integrity Error 0b0..No key blob integrity error was detected for context "n". 0b1..A key blob integrity error was detected in context "n".
| #define OTFAD_SR_CTXIE3 | ( | x | ) |
CTXIE3 - Context Integrity Error 0b0..No key blob integrity error was detected for context "n". 0b1..A key blob integrity error was detected in context "n".
| #define OTFAD_SR_GEM | ( | x | ) |
GEM - Global Enable Mode 0b0..OTFAD is disabled. All data fetched by the FlexSPI bypasses OTFAD processing. 0b1..OTFAD is enabled, and processes data fetched by the FlexSPI as defined by the hardware configuration.
| #define OTFAD_SR_HRL | ( | x | ) |
HRL - Hardware Revision Level
| #define OTFAD_SR_KBD | ( | x | ) |
KBD - Key Blob Processing Done 0b0..Key blob processing was not enabled, or is not complete. 0b1..Key blob processing was enabled and is complete.
| #define OTFAD_SR_KBERR | ( | x | ) |
KBERR - Key Blob Error 0b0..No key blob error detected. 0b1..One or more key blob errors has been detected.
| #define OTFAD_SR_KBPE | ( | x | ) |
KBPE - Key Blob Processing Enable 0b0..Key blob processing is not enabled. 0b1..Key blob processing is enabled.
| #define OTFAD_SR_MDPCP | ( | x | ) |
MDPCP - MDPC Present
| #define OTFAD_SR_MODE | ( | x | ) |
MODE - Operating Mode 0b00..Operating in Normal mode (NRM) 0b01..Unused (reserved) 0b10..Unused (reserved) 0b11..Operating in Logically Disabled Mode (LDM)
| #define OTFAD_SR_NCTX | ( | x | ) |
NCTX - Number of Contexts
| #define OTFAD_SR_RRAM | ( | x | ) |
RRAM - Restricted Register Access Mode 0b0..Register access is fully enabled. The OTFAD programming model registers can be accessed "normally". 0b1..Register access is restricted and only the CR, SR and optional MDPC registers can be accessed; others are treated as RAZ/WI.
| #define XRDC2_SR_DIN | ( | x | ) |
DIN - Domain Identifier Number
| #define XRDC2_SR_GCLO | ( | x | ) |
GCLO - Global Configuration Lock Owner
| #define XRDC2_SR_HRL | ( | x | ) |
