RTEMS 6.3
CTRL0 - Control Register 0 | |
| #define | OSC_RC_400M_CTRL0_REF_CLK_DIV_MASK (0x3F000000U) |
| #define | OSC_RC_400M_CTRL0_REF_CLK_DIV_SHIFT (24U) |
| #define | OSC_RC_400M_CTRL0_REF_CLK_DIV(x) |
CTRL1 - Control Register 1 | |
| #define | OSC_RC_400M_CTRL1_HYST_MINUS_MASK (0xFU) |
| #define | OSC_RC_400M_CTRL1_HYST_MINUS_SHIFT (0U) |
| #define | OSC_RC_400M_CTRL1_HYST_MINUS(x) |
| #define | OSC_RC_400M_CTRL1_HYST_PLUS_MASK (0xF00U) |
| #define | OSC_RC_400M_CTRL1_HYST_PLUS_SHIFT (8U) |
| #define | OSC_RC_400M_CTRL1_HYST_PLUS(x) |
| #define | OSC_RC_400M_CTRL1_TARGET_COUNT_MASK (0xFFFF0000U) |
| #define | OSC_RC_400M_CTRL1_TARGET_COUNT_SHIFT (16U) |
| #define | OSC_RC_400M_CTRL1_TARGET_COUNT(x) |
CTRL2 - Control Register 2 | |
| #define | OSC_RC_400M_CTRL2_TUNE_BYP_MASK (0x400U) |
| #define | OSC_RC_400M_CTRL2_TUNE_BYP_SHIFT (10U) |
| #define | OSC_RC_400M_CTRL2_TUNE_BYP(x) |
| #define | OSC_RC_400M_CTRL2_TUNE_EN_MASK (0x1000U) |
| #define | OSC_RC_400M_CTRL2_TUNE_EN_SHIFT (12U) |
| #define | OSC_RC_400M_CTRL2_TUNE_EN(x) |
| #define | OSC_RC_400M_CTRL2_TUNE_START_MASK (0x4000U) |
| #define | OSC_RC_400M_CTRL2_TUNE_START_SHIFT (14U) |
| #define | OSC_RC_400M_CTRL2_TUNE_START(x) |
| #define | OSC_RC_400M_CTRL2_OSC_TUNE_VAL_MASK (0xFF000000U) |
| #define | OSC_RC_400M_CTRL2_OSC_TUNE_VAL_SHIFT (24U) |
| #define | OSC_RC_400M_CTRL2_OSC_TUNE_VAL(x) |
CTRL3 - Control Register 3 | |
| #define | OSC_RC_400M_CTRL3_CLR_ERR_MASK (0x1U) |
| #define | OSC_RC_400M_CTRL3_CLR_ERR_SHIFT (0U) |
| #define | OSC_RC_400M_CTRL3_CLR_ERR(x) |
| #define | OSC_RC_400M_CTRL3_EN_1M_CLK_MASK (0x100U) |
| #define | OSC_RC_400M_CTRL3_EN_1M_CLK_SHIFT (8U) |
| #define | OSC_RC_400M_CTRL3_EN_1M_CLK(x) |
| #define | OSC_RC_400M_CTRL3_MUX_1M_CLK_MASK (0x400U) |
| #define | OSC_RC_400M_CTRL3_MUX_1M_CLK_SHIFT (10U) |
| #define | OSC_RC_400M_CTRL3_MUX_1M_CLK(x) |
| #define | OSC_RC_400M_CTRL3_COUNT_1M_CLK_MASK (0xFFFF0000U) |
| #define | OSC_RC_400M_CTRL3_COUNT_1M_CLK_SHIFT (16U) |
| #define | OSC_RC_400M_CTRL3_COUNT_1M_CLK(x) |
STAT0 - Status Register 0 | |
| #define | OSC_RC_400M_STAT0_CLK1M_ERR_MASK (0x1U) |
| #define | OSC_RC_400M_STAT0_CLK1M_ERR_SHIFT (0U) |
| #define | OSC_RC_400M_STAT0_CLK1M_ERR(x) |
STAT1 - Status Register 1 | |
| #define | OSC_RC_400M_STAT1_CURR_COUNT_VAL_MASK (0xFFFF0000U) |
| #define | OSC_RC_400M_STAT1_CURR_COUNT_VAL_SHIFT (16U) |
| #define | OSC_RC_400M_STAT1_CURR_COUNT_VAL(x) |
STAT2 - Status Register 2 | |
| #define | OSC_RC_400M_STAT2_CURR_OSC_TUNE_VAL_MASK (0xFF000000U) |
| #define | OSC_RC_400M_STAT2_CURR_OSC_TUNE_VAL_SHIFT (24U) |
| #define | OSC_RC_400M_STAT2_CURR_OSC_TUNE_VAL(x) |
| #define OSC_RC_400M_CTRL0_REF_CLK_DIV | ( | x | ) |
REF_CLK_DIV - Divide value for ref_clk to generate slow_clk (used inside this IP)
| #define OSC_RC_400M_CTRL1_HYST_MINUS | ( | x | ) |
HYST_MINUS - Negative hysteresis value for the tuned clock
| #define OSC_RC_400M_CTRL1_HYST_PLUS | ( | x | ) |
HYST_PLUS - Positive hysteresis value for the tuned clock
| #define OSC_RC_400M_CTRL1_TARGET_COUNT | ( | x | ) |
TARGET_COUNT - Target count for the fast clock
| #define OSC_RC_400M_CTRL2_OSC_TUNE_VAL | ( | x | ) |
OSC_TUNE_VAL - Program the oscillator frequency
| #define OSC_RC_400M_CTRL2_TUNE_BYP | ( | x | ) |
TUNE_BYP - Bypass the tuning logic 0b0..Use the output of tuning logic to run the oscillator 0b1..Bypass the tuning logic and use the programmed OSC_TUNE_VAL to run the oscillator
| #define OSC_RC_400M_CTRL2_TUNE_EN | ( | x | ) |
TUNE_EN - Freeze/Unfreeze the tuning value 0b0..Freezes the tuning at the current tuned value. Oscillator runs at the frozen tuning value 0b1..Unfreezes and continues the tuning operation
| #define OSC_RC_400M_CTRL2_TUNE_START | ( | x | ) |
TUNE_START - Start/Stop tuning 0b0..Stop tuning and reset the tuning logic. Oscillator runs using programmed OSC_TUNE_VAL 0b1..Start tuning
| #define OSC_RC_400M_CTRL3_CLR_ERR | ( | x | ) |
CLR_ERR - Clear the error flag CLK1M_ERR 0b0..No effect 0b1..Clears the error flag CLK1M_ERR in status register STAT0
| #define OSC_RC_400M_CTRL3_COUNT_1M_CLK | ( | x | ) |
COUNT_1M_CLK - Count for the locked clk_1m_out
| #define OSC_RC_400M_CTRL3_EN_1M_CLK | ( | x | ) |
EN_1M_CLK - Enable 1MHz output Clock 0b0..Enable the output (clk_1m_out) 0b1..Disable the output (clk_1m_out)
| #define OSC_RC_400M_CTRL3_MUX_1M_CLK | ( | x | ) |
MUX_1M_CLK - Select free/locked 1MHz output 0b0..Select free-running 1MHz to be put out on clk_1m_out 0b1..Select locked 1MHz to be put out on clk_1m_out
| #define OSC_RC_400M_STAT0_CLK1M_ERR | ( | x | ) |
CLK1M_ERR - Error flag for clk_1m_locked 0b0..No effect 0b1..The count value has been reached within one divided ref_clk period
| #define OSC_RC_400M_STAT1_CURR_COUNT_VAL | ( | x | ) |
CURR_COUNT_VAL - Current count for the fast clock
| #define OSC_RC_400M_STAT2_CURR_OSC_TUNE_VAL | ( | x | ) |
CURR_OSC_TUNE_VAL - Current tuning value used by oscillator
