RTEMS 6.3
MT25TL01G Exported Functions
int32_t MT25TL01G_GetFlashInfo (MT25TL01G_Info_t *pInfo)
 Return the configuration of the QSPI memory.
int32_t MT25TL01G_Enter4BytesAddressMode (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 This function set the QSPI memory in 4-byte address mode SPI/QPI; 1-0-1/4-0-4.
int32_t MT25TL01G_Exit4BytesAddressMode (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 Flash exit 4 Byte address mode. Effect 3/4 address byte commands only. SPI/QPI; 1-0-0/4-0-0.
int32_t MT25TL01G_AutoPollingMemReady (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 Polling WIP(Write In Progress) bit become to 0 SPI/QPI;4-0-4.
int32_t MT25TL01G_WriteEnable (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 This function send a Write Enable and wait it is effective.
int32_t MT25TL01G_WriteDisable (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 This function reset the (WEL) Write Enable Latch bit. SPI/QPI; 1-0-0/4-0-0.
int32_t MT25TL01G_PageProgram (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *pData, uint32_t WriteAddr, uint32_t Size)
 Writes an amount of data to the QSPI memory. SPI/QPI; 1-1-1/1-2-2/1-4-4/4-4-4.
int32_t MT25TL01G_ReadDTR (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *pData, uint32_t ReadAddr, uint32_t Size)
 Reads an amount of data from the QSPI memory on DTR mode. SPI/QPI; 1-1-1/1-1-2/1-4-4/4-4-4.
int32_t MT25TL01G_ReadSTR (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *pData, uint32_t ReadAddr, uint32_t Size)
 Reads an amount of data from the QSPI memory on STR mode. SPI/QPI; 1-1-1/1-2-2/1-4-4/4-4-4.
int32_t MT25TL01G_BlockErase (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint32_t BlockAddress, MT25TL01G_Erase_t BlockSize)
 Erases the specified block of the QSPI memory. MT25TL01G support 4K, 32K, 64K size block erase commands. SPI/QPI; 1-1-0/4-4-0.
int32_t MT25TL01G_ChipErase (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 Whole chip erase. SPI/QPI; 1-0-0/4-0-0.
int32_t MT25TL01G_ReadStatusRegister (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *Value)
 Read Flash Status register value SPI/QPI; 1-0-1/4-0-4.
int32_t MT25TL01G_EnterQPIMode (QSPI_HandleTypeDef *Ctx)
 This function put QSPI memory in QPI mode (Quad I/O) from SPI mode. SPI -> QPI; 1-x-x -> 4-4-4 SPI; 1-0-0.
int32_t MT25TL01G_ExitQPIMode (QSPI_HandleTypeDef *Ctx)
 This function put QSPI memory in SPI mode (Single I/O) from QPI mode. QPI -> SPI; 4-4-4 -> 1-x-x QPI; 4-0-0.
int32_t MT25TL01G_EnableMemoryMappedModeDTR (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
int32_t MT25TL01G_EnableMemoryMappedModeSTR (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
int32_t MT25TL01G_ResetEnable (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 Flash reset enable command SPI/QPI; 1-0-0, 4-0-0.
int32_t MT25TL01G_ResetMemory (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 Flash reset memory command SPI/QPI; 1-0-0, 4-0-0.
int32_t MT25TL01G_ReadID (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *ID)
 Read Flash 3 Byte IDs. Manufacturer ID, Memory type, Memory density SPI/QPI; 1-0-1/4-0-4.
int32_t MT25TL01G_ProgEraseSuspend (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 Program/Erases suspend. Interruption Program/Erase operations. After the device has entered Erase-Suspended mode, system can read any address except the block/sector being Program/Erased. SPI/QPI; 1-0-0/4-0-0.
int32_t MT25TL01G_ProgEraseResume (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 Program/Erases resume. SPI/QPI; 1-0-0/4-0-0.
int32_t MT25TL01G_EnterDeepPowerDown (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 Deep power down. The device is not active and all Write/Program/Erase instruction are ignored. SPI/QPI; 1-0-0/4-0-0.
int32_t MT25TL01G_ReleaseFromDeepPowerDown (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode)
 Release from deep power down. After CS# go high, system need wait tRES1 time for device ready. SPI/QPI; 1-0-0/4-0-0.
int32_t MT25TL01G_ReadSPBLockRegister (QSPI_HandleTypeDef *Ctx, MT25TL01G_Interface_t Mode, uint8_t *SPBRegister)
 Read SECTOR PROTECTION Block register value. SPI; 1-0-1.
◆ MT25TL01G_AutoPollingMemReady()
int32_t MT25TL01G_AutoPollingMemReady ( QSPI_HandleTypeDef * Ctx,
MT25TL01G_Interface_t Mode )
Parameters
CtxComponent object pointer
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_BlockErase()
int32_t MT25TL01G_BlockErase ( QSPI_HandleTypeDef * Ctx,
MT25TL01G_Erase_t BlockSize )
Parameters
ModeInterface mode
BlockAddressBlock address to erase
Return values
QSPImemory status
◆ MT25TL01G_ChipErase()
int32_t MT25TL01G_ChipErase ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_EnableMemoryMappedModeDTR()
int32_t MT25TL01G_EnableMemoryMappedModeDTR ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_EnableMemoryMappedModeSTR()
int32_t MT25TL01G_EnableMemoryMappedModeSTR ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_Enter4BytesAddressMode()
int32_t MT25TL01G_Enter4BytesAddressMode ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_EnterDeepPowerDown()
int32_t MT25TL01G_EnterDeepPowerDown ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_EnterQPIMode()
int32_t MT25TL01G_EnterQPIMode ( QSPI_HandleTypeDef * Ctx)
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_Exit4BytesAddressMode()
int32_t MT25TL01G_Exit4BytesAddressMode ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_ExitQPIMode()
int32_t MT25TL01G_ExitQPIMode ( QSPI_HandleTypeDef * Ctx)
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_GetFlashInfo()
int32_t MT25TL01G_GetFlashInfo ( MT25TL01G_Info_t * pInfo)
Parameters
pInfopointer on the configuration structure
Return values
QSPImemory status
◆ MT25TL01G_PageProgram()
int32_t MT25TL01G_PageProgram ( QSPI_HandleTypeDef * Ctx,
uint8_t * pData,
uint32_t WriteAddr,
uint32_t Size )
Parameters
ModeInterface mode
pDataPointer to data to be written
WriteAddrWrite start address
SizeSize of data to write. Range 1 ~ 256
Return values
QSPImemory status
◆ MT25TL01G_ProgEraseResume()
int32_t MT25TL01G_ProgEraseResume ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_ProgEraseSuspend()
int32_t MT25TL01G_ProgEraseSuspend ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_ReadDTR()
int32_t MT25TL01G_ReadDTR ( QSPI_HandleTypeDef * Ctx,
uint8_t * pData,
uint32_t ReadAddr,
uint32_t Size )
Parameters
ModeInterface mode
pDataPointer to data to be read
ReadAddrRead start address
SizeSize of data to read
Return values
QSPImemory status
◆ MT25TL01G_ReadID()
int32_t MT25TL01G_ReadID ( QSPI_HandleTypeDef * Ctx,
uint8_t * ID )
Parameters
ModeInterface mode
IDpointer to flash id value
Return values
QSPImemory status
◆ MT25TL01G_ReadSPBLockRegister()
int32_t MT25TL01G_ReadSPBLockRegister ( QSPI_HandleTypeDef * Ctx,
uint8_t * SPBRegister )
Parameters
ModeInterface mode
SPBRegisterpointer to SPBRegister value
Return values
QSPImemory status
◆ MT25TL01G_ReadStatusRegister()
int32_t MT25TL01G_ReadStatusRegister ( QSPI_HandleTypeDef * Ctx,
uint8_t * Value )
Parameters
ModeInterface mode
Valuepointer to status register value
Return values
QSPImemory status
◆ MT25TL01G_ReadSTR()
int32_t MT25TL01G_ReadSTR ( QSPI_HandleTypeDef * Ctx,
uint8_t * pData,
uint32_t ReadAddr,
uint32_t Size )
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_ReleaseFromDeepPowerDown()
int32_t MT25TL01G_ReleaseFromDeepPowerDown ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_ResetEnable()
int32_t MT25TL01G_ResetEnable ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_ResetMemory()
int32_t MT25TL01G_ResetMemory ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_WriteDisable()
int32_t MT25TL01G_WriteDisable ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
◆ MT25TL01G_WriteEnable()
int32_t MT25TL01G_WriteEnable ( QSPI_HandleTypeDef * Ctx,
Parameters
ModeInterface mode
Return values
QSPImemory status
