RTEMS 6.3
#define __HAL_MDMA_ENABLE(__HANDLE__)
 Enable the specified MDMA Channel.
#define __HAL_MDMA_DISABLE(__HANDLE__)
 Disable the specified MDMA Channel.
#define __HAL_MDMA_GET_FLAG(__HANDLE__, __FLAG__)
 Get the MDMA Channel pending flags.
#define __HAL_MDMA_CLEAR_FLAG(__HANDLE__, __FLAG__)
 Clear the MDMA Stream pending flags.
#define __HAL_MDMA_ENABLE_IT(__HANDLE__, __INTERRUPT__)
 Enables the specified MDMA Channel interrupts.
#define __HAL_MDMA_DISABLE_IT(__HANDLE__, __INTERRUPT__)
 Disables the specified MDMA Channel interrupts.
#define __HAL_MDMA_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Checks whether the specified MDMA Channel interrupt is enabled or not.
#define __HAL_MDMA_SET_COUNTER(__HANDLE__, __COUNTER__)
 Writes the number of data in bytes to be transferred on the MDMA Channelx.
#define __HAL_MDMA_GET_COUNTER(__HANDLE__)
 Returns the number of remaining data in bytes in the current MDMA Channelx transfer.
◆ __HAL_MDMA_CLEAR_FLAG
#define __HAL_MDMA_CLEAR_FLAG ( __HANDLE__,
__FLAG__ )
Value:
((__HANDLE__)->Instance->CIFCR = (__FLAG__))
Parameters
__HANDLE__MDMA handle
__FLAG__specifies the flag to clear. This parameter can be any combination of the following values:
  • MDMA_FLAG_TE : Transfer Error flag.
  • MDMA_FLAG_CTC : Channel Transfer Complete flag.
  • MDMA_FLAG_BRT : Block Repeat Transfer flag.
  • MDMA_FLAG_BT : Block Transfer complete flag.
  • MDMA_FLAG_BFTC : BuFfer Transfer Complete flag.
Return values
None
◆ __HAL_MDMA_DISABLE
#define __HAL_MDMA_DISABLE ( __HANDLE__)
Value:
((__HANDLE__)->Instance->CCR &= ~MDMA_CCR_EN)
#define MDMA_CCR_EN
Definition stm32h723xx.h:13661
Parameters
Return values
None
◆ __HAL_MDMA_DISABLE_IT
#define __HAL_MDMA_DISABLE_IT ( __HANDLE__,
__INTERRUPT__ )
Value:
((__HANDLE__)->Instance->CCR &= ~(__INTERRUPT__))
Parameters
__INTERRUPT__specifies the MDMA interrupt sources to be enabled or disabled. This parameter can be any combination of the following values:
  • MDMA_IT_TE : Transfer Error interrupt mask
  • MDMA_IT_CTC : Channel Transfer Complete interrupt mask
  • MDMA_IT_BRT : Block Repeat Transfer interrupt mask
  • MDMA_IT_BT : Block Transfer interrupt mask
  • MDMA_IT_BFTC : BuFfer Transfer Complete interrupt mask
Return values
None
◆ __HAL_MDMA_ENABLE
#define __HAL_MDMA_ENABLE ( __HANDLE__)
Value:
((__HANDLE__)->Instance->CCR |= MDMA_CCR_EN)
Parameters
Return values
None
◆ __HAL_MDMA_ENABLE_IT
#define __HAL_MDMA_ENABLE_IT ( __HANDLE__,
__INTERRUPT__ )
Value:
((__HANDLE__)->Instance->CCR |= (__INTERRUPT__))
Parameters
__INTERRUPT__specifies the DMA interrupt sources to be enabled or disabled. This parameter can be any combination of the following values:
Return values
None
◆ __HAL_MDMA_GET_COUNTER
#define __HAL_MDMA_GET_COUNTER ( __HANDLE__)
Value:
((__HANDLE__)->Instance->CBNDTR & MDMA_CBNDTR_BNDT)
#define MDMA_CBNDTR_BNDT
Definition stm32h723xx.h:13764
Parameters
__HANDLE__: MDMA handle
Return values
Thenumber of remaining data in bytes in the current MDMA Channelx transfer.
◆ __HAL_MDMA_GET_FLAG
#define __HAL_MDMA_GET_FLAG ( __HANDLE__,
__FLAG__ )
Value:
((__HANDLE__)->Instance->CISR & (__FLAG__))
Parameters
__FLAG__Get the specified flag. This parameter can be any combination of the following values:
  • MDMA_FLAG_CRQA : Channel request Active flag.
Return values
Thestate of FLAG (SET or RESET).
◆ __HAL_MDMA_GET_IT_SOURCE
#define __HAL_MDMA_GET_IT_SOURCE ( __HANDLE__,
__INTERRUPT__ )
Value:
(((__HANDLE__)->Instance->CCR & (__INTERRUPT__)))
Parameters
__INTERRUPT__specifies the MDMA interrupt source to check.
Return values
Thestate of MDMA_IT (SET or RESET).
◆ __HAL_MDMA_SET_COUNTER
#define __HAL_MDMA_SET_COUNTER ( __HANDLE__,
__COUNTER__ )
Value:
((__HANDLE__)->Instance->CBNDTR |= ((__COUNTER__) & MDMA_CBNDTR_BNDT))
Parameters
__COUNTER__Number of data in bytes to be transferred.
Return values
None
