RTEMS 6.3
Journalling Flash File System Version 2 (JFFS2) Support
Mount options for the Journalling Flash File System, Version 2 (JFFS2). More...
struct  rtems_jffs2_flash_control
 JFFS2 flash device control. More...
struct  rtems_jffs2_compressor_control
 JFFS2 compressor control. More...
struct  rtems_jffs2_compressor_zlib_control
 ZLIB compressor control structure. More...
struct  rtems_jffs2_mount_data
 JFFS2 mount options. More...
struct  rtems_jffs2_info
 JFFS2 filesystem instance information. More...
struct  rtems_jffs2_config
#define RTEMS_JFFS2_GET_INFO   _IOR('F', 1, rtems_jffs2_info)
 IO control to get the JFFS2 filesystem instance information.
#define RTEMS_JFFS2_ON_DEMAND_GARBAGE_COLLECTION   _IO('F', 2)
 IO control to perform an on demand garbage collection in a JFFS2 filesystem instance.
#define RTEMS_JFFS2_FORCE_GARBAGE_COLLECTION   _IO('F', 3)
 IO control to force a garbage collection in a JFFS2 filesystem instance.
#define RTEMS_JFFS2_DELAYED_WRITE_TASK_PRIORITY_DEFAULT   15
typedef int(*) rtems_jffs2_flash_read(rtems_jffs2_flash_control *self, uint32_t offset, unsigned char *buffer, size_t size_of_buffer)
 Read from flash operation.
typedef int(*) rtems_jffs2_flash_write(rtems_jffs2_flash_control *self, uint32_t offset, const unsigned char *buffer, size_t size_of_buffer)
 Write to flash operation.
typedef int(*) rtems_jffs2_flash_erase(rtems_jffs2_flash_control *self, uint32_t offset)
 Flash erase operation.
typedef int(*) rtems_jffs2_flash_block_is_bad(rtems_jffs2_flash_control *self, uint32_t offset, bool *bad)
 Flash bad block check operation.
typedef int(*) rtems_jffs2_flash_block_mark_bad(rtems_jffs2_flash_control *self, uint32_t offset)
 Flash bad block mark operation.
typedef int(*) rtems_jffs2_flash_oob_write(rtems_jffs2_flash_control *self, uint32_t offset, uint8_t *oobbuf, uint32_t obblen)
 Flash oob write.
typedef int(*) rtems_jffs2_flash_oob_read(rtems_jffs2_flash_control *self, uint32_t offset, uint8_t *oobbuf, uint32_t obblen)
 Flash oob read.
typedef uint32_t(*) rtems_jffs2_flash_get_oob_size(rtems_jffs2_flash_control *self)
 Flash get oob size.
typedef void(*) rtems_jffs2_flash_destroy(rtems_jffs2_flash_control *self)
 Flash destroy operation.
typedef void(*) rtems_jffs2_trigger_garbage_collection(rtems_jffs2_flash_control *self)
 Trigger garbage collection operation.
typedef struct rtems_jffs2_compressor_control rtems_jffs2_compressor_control
typedef uint16_t(*) rtems_jffs2_compressor_compress(rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen)
 Compress operation.
typedef int(*) rtems_jffs2_compressor_decompress(rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen)
 Decompress operation.
typedef void(*) rtems_jffs2_compressor_destroy(rtems_jffs2_compressor_control *self)
 Compressor destroy operation.
typedef struct rtems_jffs2_config rtems_jffs2_config
uint16_t rtems_jffs2_compressor_rtime_compress (rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen)
 RTIME compressor compress operation.
int rtems_jffs2_compressor_rtime_decompress (rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen)
 RTIME compressor decompress operation.
uint16_t rtems_jffs2_compressor_zlib_compress (rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen)
 ZLIB compressor compress operation.
int rtems_jffs2_compressor_zlib_decompress (rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen)
 ZLIB compressor decompress operation.
int rtems_jffs2_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
 Initialization handler of the JFFS2 file system.
const rtems_jffs2_config jffs2_config
The application must provide flash device geometry information and flash device operations in the flash control structure rtems_jffs2_flash_control.
The application can optionally provide a compressor control structure to enable data compression using the selected compression algorithm.
The application must enable JFFS2 support with rtems_filesystem_register() or CONFIGURE_FILESYSTEM_JFFS2 via <rtems/confdefs.h>.
An example mount with a simple memory based flash device simulation follows. The zlib is used for as the compressor.
#include <rtems/jffs2.h>
#include <rtems/libio.h>
#define BLOCK_SIZE (32UL * 1024UL)
#define FLASH_SIZE (32UL * BLOCK_SIZE)
typedef struct {
unsigned char area[FLASH_SIZE];
static flash_control *get_flash_control(rtems_jffs2_flash_control *super)
return (flash_control *) super;
static int flash_read(
uint32_t offset,
flash_control *self = get_flash_control(super);
unsigned char *chunk = &self->area[offset];
memcpy(buffer, chunk, size_of_buffer);
return 0;
static int flash_write(
uint32_t offset,
size_t i;
for (i = 0; i < size_of_buffer; ++i) {
chunk[i] &= buffer[i];
return 0;
static int flash_erase(
uint32_t offset
memset(chunk, 0xff, BLOCK_SIZE);
return 0;
static flash_control flash_instance = {
.super = {
.block_size = BLOCK_SIZE,
.flash_size = FLASH_SIZE,
.read = flash_read,
.write = flash_write,
.erase = flash_erase,
.device_identifier = 0xc01dc0fe
static rtems_jffs2_compressor_zlib_control compressor_instance = {
.super = {
static const rtems_jffs2_mount_data mount_data = {
.flash_control = &flash_instance.super,
.compressor_control = &compressor_instance.super
static void erase_all(void)
memset(&flash_instance.area[0], 0xff, FLASH_SIZE);
void example_jffs2_mount(const char *mount_dir)
int rv;
erase_all();
NULL,
mount_dir,
RTEMS_FILESYSTEM_TYPE_JFFS2,
RTEMS_FILESYSTEM_READ_WRITE,
&mount_data
assert(rv == 0);
int mount_and_make_target_path(const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
Mounts a file system and makes the target path.
Definition mount-mktgt.c:44
uint16_t rtems_jffs2_compressor_zlib_compress(rtems_jffs2_compressor_control *self, unsigned char *data_in, unsigned char *cdata_out, uint32_t *datalen, uint32_t *cdatalen)
Definition compr_zlib.c:46
int rtems_jffs2_compressor_zlib_decompress(rtems_jffs2_compressor_control *self, uint16_t comprtype, unsigned char *cdata_in, unsigned char *data_out, uint32_t cdatalen, uint32_t datalen)
Definition compr_zlib.c:121
Basic IO API.
Definition jffs2_xnandpsu.c:52
Definition jffs2.h:556
Definition jffs2.h:355
Definition jffs2.h:589
◆ RTEMS_JFFS2_DELAYED_WRITE_TASK_PRIORITY_DEFAULT
Default delayed-write servicing task priority.
◆ RTEMS_JFFS2_FORCE_GARBAGE_COLLECTION
Use this operation with care since it may wear out your flash.
◆ RTEMS_JFFS2_GET_INFO
See also
rtems_jffs2_info.
◆ RTEMS_JFFS2_ON_DEMAND_GARBAGE_COLLECTION
This operation is intended to be used by an optional garbage collection thread. See rtems_jffs2_flash_control::trigger_garbage_collection.
Typedef Documentation
◆ rtems_jffs2_compressor_compress
Compress operation.
Parameters
[in,out]selfThe compressor control.
[in]data_inThe uncompressed data.
[out]cdata_outPointer to buffer with the compressed data.
[in,out]datalenOn entry, the size in bytes of the uncompressed data. On exit, the size in bytes of uncompressed data which was actually compressed.
[in,out]cdatalenOn entry, the size in bytes available for compressed data. On exit, the size in bytes of the actually compressed data.
Returns
The compressor type.
◆ rtems_jffs2_compressor_decompress
Parameters
[in]comprtypeThe compressor type.
[in]cdata_inThe compressed data.
[out]data_outThe uncompressed data.
[in]cdatalenThe size in bytes of the compressed data.
[in]datalenThe size in bytes of the uncompressed data.
Return values
0Successful operation.
-EIOAn error occurred. Please note that the value is negative.
otherAll other values are reserved and must not be used.
◆ rtems_jffs2_compressor_destroy
The compressor destroy operation is called during unmount of the file system instance. It can be used to free the resources associated with the now unused compressor operations.
Parameters
◆ rtems_jffs2_config
JFFS2 configuration definition. See confdefs.h for support on using this structure.
◆ rtems_jffs2_flash_block_is_bad
This operation checks whether a block is bad.
Parameters
[in,out]selfThe flash control.
[in]offsetThe offset in bytes of the block to check.
[out]Theresult of the bad block check.
Return values
◆ rtems_jffs2_flash_block_mark_bad
This operation marks a block bad.
Parameters
[in]offsetThe offset in bytes of the block to mark bad.
Return values
◆ rtems_jffs2_flash_destroy
The flash destroy operation is called during unmount of the file system instance. It can be used to free the resources associated with the now unused flash control
Parameters
◆ rtems_jffs2_flash_erase
This operation must erase one block specified by the offset.
Parameters
[in]offsetThe offset to erase from the flash begin in bytes.
Return values
◆ rtems_jffs2_flash_get_oob_size
Flash get oob size.
This operation gets the size of the out-of-band/spare bytes for each page.
Parameters
Return values
Thesize of the OOB/spare area available to each page
◆ rtems_jffs2_flash_oob_read
Flash oob read.
This operation reads the out-of-band/spare bytes for the block matching the given offset in bytes.
Parameters
[out]pointerto the buffer which will have the oob/spare bytes data written to it.
[in]lengthof the buffer which will hold the oob/spare bytes.
Return values
◆ rtems_jffs2_flash_oob_write
Flash oob write.
This operation writes the out-of-band/spare bytes for the block matching the given offset in bytes.
Parameters
[in]pointerto the buffer which will be written to the oob/spare bytes.
[in]lengthof the buffer which will be written to the oob/spare bytes.
Return values
◆ rtems_jffs2_flash_read
Parameters
[in]offsetThe offset to read from the flash begin in bytes.
[out]bufferThe buffer receiving the data.
[in]size_of_bufferThe size of the buffer in bytes.
Return values
◆ rtems_jffs2_flash_write
Parameters
[in]offsetThe offset to write from the flash begin in bytes.
[in]bufferThe buffer containing the data to write.
Return values
◆ rtems_jffs2_trigger_garbage_collection
An optional garbage collection thread may perform now a garbage collection using the RTEMS_JFFS2_ON_DEMAND_GARBAGE_COLLECTION IO control.
The garbage collection must not run in the executing context.
Parameters
[in]selfThe flash control.
◆ rtems_jffs2_initialize()
int rtems_jffs2_initialize ( rtems_filesystem_mount_table_entry_t * mt_entry,
const void * data )
Parameters
[in,out]mt_entryThe mount table entry.
[in]dataThe mount options are mandatory for JFFS2 and data must point to a valid rtems_jffs2_mount_data structure used for this file system instance.
Return values
-1An error occurred. The errno indicates the error.
See also
mount().
Variable Documentation
◆ jffs2_config
extern
External reference to the configuration.
The configuration is provided by the application.
