RTEMS 6.3
| #define | __HAL_I2S_RESET_HANDLE_STATE(__HANDLE__) |
| Reset I2S handle state. | |
| #define | __HAL_I2S_ENABLE(__HANDLE__) |
| Enable the specified SPI peripheral (in I2S mode). | |
| #define | __HAL_I2S_DISABLE(__HANDLE__) |
| Disable the specified SPI peripheral (in I2S mode). | |
| #define | __HAL_I2S_ENABLE_IT(__HANDLE__, __INTERRUPT__) |
| Enable the specified I2S interrupts. | |
| #define | __HAL_I2S_DISABLE_IT(__HANDLE__, __INTERRUPT__) |
| Disable the specified I2S interrupts. | |
| #define | __HAL_I2S_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Check if the specified I2S interrupt source is enabled or disabled. | |
| #define | __HAL_I2S_GET_FLAG(__HANDLE__, __FLAG__) |
| Check whether the specified I2S flag is set or not. | |
| #define | __HAL_I2S_CLEAR_OVRFLAG(__HANDLE__) |
| Clear the I2S OVR pending flag. | |
| #define | __HAL_I2S_CLEAR_UDRFLAG(__HANDLE__) |
| Clear the I2S UDR pending flag. | |
| #define | __HAL_I2S_CLEAR_TIFREFLAG(__HANDLE__) |
| Clear the I2S FRE pending flag. | |
| #define __HAL_I2S_CLEAR_OVRFLAG | ( | __HANDLE__ | ) |
| __HANDLE__ | specifies the I2S Handle. |
| None |
| #define __HAL_I2S_CLEAR_TIFREFLAG | ( | __HANDLE__ | ) |
| None |
| #define __HAL_I2S_CLEAR_UDRFLAG | ( | __HANDLE__ | ) |
| None |
| #define __HAL_I2S_DISABLE | ( | __HANDLE__ | ) |
| None |
| #define __HAL_I2S_DISABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ ) |
| __HANDLE__ | specifies the I2S Handle. This parameter can be I2S where x: 1, 2 or 3 to select the I2S peripheral. |
| __INTERRUPT__ | specifies the interrupt source to enable or disable. This parameter can be one of the following values:
| None |
| #define __HAL_I2S_ENABLE | ( | __HANDLE__ | ) |
| None |
| #define __HAL_I2S_ENABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ ) |
| None |
| #define __HAL_I2S_GET_FLAG | ( | __HANDLE__, | |
| __FLAG__ ) |
| __FLAG__ | specifies the flag to check. This parameter can be one of the following values:
| The | new state of FLAG (TRUE or FALSE). |
| #define __HAL_I2S_GET_IT_SOURCE | ( | __HANDLE__, | |
| __INTERRUPT__ ) |
| __INTERRUPT__ | specifies the I2S interrupt source to check. This parameter can be one of the following values:
| The | new state of IT (TRUE or FALSE). |
| #define __HAL_I2S_RESET_HANDLE_STATE | ( | __HANDLE__ | ) |
| None |
