RTEMS 6.3
HAL FLASH Aliased Defines maintained for legacy purpose
#define TYPEPROGRAM_BYTE   FLASH_TYPEPROGRAM_BYTE
#define TYPEPROGRAM_HALFWORD   FLASH_TYPEPROGRAM_HALFWORD
#define TYPEPROGRAM_WORD   FLASH_TYPEPROGRAM_WORD
#define TYPEPROGRAM_DOUBLEWORD   FLASH_TYPEPROGRAM_DOUBLEWORD
#define TYPEERASE_SECTORS   FLASH_TYPEERASE_SECTORS
#define TYPEERASE_PAGES   FLASH_TYPEERASE_PAGES
#define TYPEERASE_PAGEERASE   FLASH_TYPEERASE_PAGES
#define TYPEERASE_MASSERASE   FLASH_TYPEERASE_MASSERASE
#define WRPSTATE_DISABLE   OB_WRPSTATE_DISABLE
#define WRPSTATE_ENABLE   OB_WRPSTATE_ENABLE
#define HAL_FLASH_TIMEOUT_VALUE   FLASH_TIMEOUT_VALUE
#define OBEX_PCROP   OPTIONBYTE_PCROP
#define OBEX_BOOTCONFIG   OPTIONBYTE_BOOTCONFIG
#define PCROPSTATE_DISABLE   OB_PCROP_STATE_DISABLE
#define PCROPSTATE_ENABLE   OB_PCROP_STATE_ENABLE
#define TYPEERASEDATA_BYTE   FLASH_TYPEERASEDATA_BYTE
#define TYPEERASEDATA_HALFWORD   FLASH_TYPEERASEDATA_HALFWORD
#define TYPEERASEDATA_WORD   FLASH_TYPEERASEDATA_WORD
#define TYPEPROGRAMDATA_BYTE   FLASH_TYPEPROGRAMDATA_BYTE
#define TYPEPROGRAMDATA_HALFWORD   FLASH_TYPEPROGRAMDATA_HALFWORD
#define TYPEPROGRAMDATA_WORD   FLASH_TYPEPROGRAMDATA_WORD
#define TYPEPROGRAMDATA_FASTBYTE   FLASH_TYPEPROGRAMDATA_FASTBYTE
#define TYPEPROGRAMDATA_FASTHALFWORD   FLASH_TYPEPROGRAMDATA_FASTHALFWORD
#define TYPEPROGRAMDATA_FASTWORD   FLASH_TYPEPROGRAMDATA_FASTWORD
#define PAGESIZE   FLASH_PAGE_SIZE
#define TYPEPROGRAM_FASTBYTE   FLASH_TYPEPROGRAM_BYTE
#define TYPEPROGRAM_FASTHALFWORD   FLASH_TYPEPROGRAM_HALFWORD
#define TYPEPROGRAM_FASTWORD   FLASH_TYPEPROGRAM_WORD
#define VOLTAGE_RANGE_1   FLASH_VOLTAGE_RANGE_1
#define VOLTAGE_RANGE_2   FLASH_VOLTAGE_RANGE_2
#define VOLTAGE_RANGE_3   FLASH_VOLTAGE_RANGE_3
#define VOLTAGE_RANGE_4   FLASH_VOLTAGE_RANGE_4
#define TYPEPROGRAM_FAST   FLASH_TYPEPROGRAM_FAST
#define TYPEPROGRAM_FAST_AND_LAST   FLASH_TYPEPROGRAM_FAST_AND_LAST
#define WRPAREA_BANK1_AREAA   OB_WRPAREA_BANK1_AREAA
#define WRPAREA_BANK1_AREAB   OB_WRPAREA_BANK1_AREAB
#define WRPAREA_BANK2_AREAA   OB_WRPAREA_BANK2_AREAA
#define WRPAREA_BANK2_AREAB   OB_WRPAREA_BANK2_AREAB
#define IWDG_STDBY_FREEZE   OB_IWDG_STDBY_FREEZE
#define IWDG_STDBY_ACTIVE   OB_IWDG_STDBY_RUN
#define IWDG_STOP_FREEZE   OB_IWDG_STOP_FREEZE
#define IWDG_STOP_ACTIVE   OB_IWDG_STOP_RUN
#define FLASH_ERROR_NONE   HAL_FLASH_ERROR_NONE
#define FLASH_ERROR_RD   HAL_FLASH_ERROR_RD
#define FLASH_ERROR_PG   HAL_FLASH_ERROR_PROG
#define FLASH_ERROR_PGP   HAL_FLASH_ERROR_PGS
#define FLASH_ERROR_WRP   HAL_FLASH_ERROR_WRP
#define FLASH_ERROR_OPTV   HAL_FLASH_ERROR_OPTV
#define FLASH_ERROR_OPTVUSR   HAL_FLASH_ERROR_OPTVUSR
#define FLASH_ERROR_PROG   HAL_FLASH_ERROR_PROG
#define FLASH_ERROR_OP   HAL_FLASH_ERROR_OPERATION
#define FLASH_ERROR_PGA   HAL_FLASH_ERROR_PGA
#define FLASH_ERROR_SIZE   HAL_FLASH_ERROR_SIZE
#define FLASH_ERROR_SIZ   HAL_FLASH_ERROR_SIZE
#define FLASH_ERROR_PGS   HAL_FLASH_ERROR_PGS
#define FLASH_ERROR_MIS   HAL_FLASH_ERROR_MIS
#define FLASH_ERROR_FAST   HAL_FLASH_ERROR_FAST
#define FLASH_ERROR_FWWERR   HAL_FLASH_ERROR_FWWERR
#define FLASH_ERROR_NOTZERO   HAL_FLASH_ERROR_NOTZERO
#define FLASH_ERROR_OPERATION   HAL_FLASH_ERROR_OPERATION
#define FLASH_ERROR_ERS   HAL_FLASH_ERROR_ERS
#define OB_WDG_SW   OB_IWDG_SW
#define OB_WDG_HW   OB_IWDG_HW
#define OB_SDADC12_VDD_MONITOR_SET   OB_SDACD_VDD_MONITOR_SET
#define OB_SDADC12_VDD_MONITOR_RESET   OB_SDACD_VDD_MONITOR_RESET
#define OB_RAM_PARITY_CHECK_SET   OB_SRAM_PARITY_SET
#define OB_RAM_PARITY_CHECK_RESET   OB_SRAM_PARITY_RESET
#define IS_OB_SDADC12_VDD_MONITOR   IS_OB_SDACD_VDD_MONITOR
#define OB_RDP_LEVEL0   OB_RDP_LEVEL_0
#define OB_RDP_LEVEL1   OB_RDP_LEVEL_1
#define OB_RDP_LEVEL2   OB_RDP_LEVEL_2
#define OB_BOOT_ENTRY_FORCED_NONE   OB_BOOT_LOCK_DISABLE
#define OB_BOOT_ENTRY_FORCED_FLASH   OB_BOOT_LOCK_ENABLE
