RTEMS 6.3
DR - GPIO data register | |
| #define | GPIO_DR_DR_MASK (0xFFFFFFFFU) |
| #define | GPIO_DR_DR_SHIFT (0U) |
| #define | GPIO_DR_DR(x) |
GDIR - GPIO direction register | |
| #define | GPIO_GDIR_GDIR_MASK (0xFFFFFFFFU) |
| #define | GPIO_GDIR_GDIR_SHIFT (0U) |
| #define | GPIO_GDIR_GDIR(x) |
PSR - GPIO pad status register | |
| #define | GPIO_PSR_PSR_MASK (0xFFFFFFFFU) |
| #define | GPIO_PSR_PSR_SHIFT (0U) |
| #define | GPIO_PSR_PSR(x) |
ICR1 - GPIO interrupt configuration register1 | |
| #define | GPIO_ICR1_ICR0_MASK (0x3U) |
| #define | GPIO_ICR1_ICR0_SHIFT (0U) |
| #define | GPIO_ICR1_ICR0(x) |
| #define | GPIO_ICR1_ICR1_MASK (0xCU) |
| #define | GPIO_ICR1_ICR1_SHIFT (2U) |
| #define | GPIO_ICR1_ICR1(x) |
| #define | GPIO_ICR1_ICR2_MASK (0x30U) |
| #define | GPIO_ICR1_ICR2_SHIFT (4U) |
| #define | GPIO_ICR1_ICR2(x) |
| #define | GPIO_ICR1_ICR3_MASK (0xC0U) |
| #define | GPIO_ICR1_ICR3_SHIFT (6U) |
| #define | GPIO_ICR1_ICR3(x) |
| #define | GPIO_ICR1_ICR4_MASK (0x300U) |
| #define | GPIO_ICR1_ICR4_SHIFT (8U) |
| #define | GPIO_ICR1_ICR4(x) |
| #define | GPIO_ICR1_ICR5_MASK (0xC00U) |
| #define | GPIO_ICR1_ICR5_SHIFT (10U) |
| #define | GPIO_ICR1_ICR5(x) |
| #define | GPIO_ICR1_ICR6_MASK (0x3000U) |
| #define | GPIO_ICR1_ICR6_SHIFT (12U) |
| #define | GPIO_ICR1_ICR6(x) |
| #define | GPIO_ICR1_ICR7_MASK (0xC000U) |
| #define | GPIO_ICR1_ICR7_SHIFT (14U) |
| #define | GPIO_ICR1_ICR7(x) |
| #define | GPIO_ICR1_ICR8_MASK (0x30000U) |
| #define | GPIO_ICR1_ICR8_SHIFT (16U) |
| #define | GPIO_ICR1_ICR8(x) |
| #define | GPIO_ICR1_ICR9_MASK (0xC0000U) |
| #define | GPIO_ICR1_ICR9_SHIFT (18U) |
| #define | GPIO_ICR1_ICR9(x) |
| #define | GPIO_ICR1_ICR10_MASK (0x300000U) |
| #define | GPIO_ICR1_ICR10_SHIFT (20U) |
| #define | GPIO_ICR1_ICR10(x) |
| #define | GPIO_ICR1_ICR11_MASK (0xC00000U) |
| #define | GPIO_ICR1_ICR11_SHIFT (22U) |
| #define | GPIO_ICR1_ICR11(x) |
| #define | GPIO_ICR1_ICR12_MASK (0x3000000U) |
| #define | GPIO_ICR1_ICR12_SHIFT (24U) |
| #define | GPIO_ICR1_ICR12(x) |
| #define | GPIO_ICR1_ICR13_MASK (0xC000000U) |
| #define | GPIO_ICR1_ICR13_SHIFT (26U) |
| #define | GPIO_ICR1_ICR13(x) |
| #define | GPIO_ICR1_ICR14_MASK (0x30000000U) |
| #define | GPIO_ICR1_ICR14_SHIFT (28U) |
| #define | GPIO_ICR1_ICR14(x) |
| #define | GPIO_ICR1_ICR15_MASK (0xC0000000U) |
| #define | GPIO_ICR1_ICR15_SHIFT (30U) |
| #define | GPIO_ICR1_ICR15(x) |
ICR2 - GPIO interrupt configuration register2 | |
| #define | GPIO_ICR2_ICR16_MASK (0x3U) |
| #define | GPIO_ICR2_ICR16_SHIFT (0U) |
| #define | GPIO_ICR2_ICR16(x) |
| #define | GPIO_ICR2_ICR17_MASK (0xCU) |
| #define | GPIO_ICR2_ICR17_SHIFT (2U) |
| #define | GPIO_ICR2_ICR17(x) |
| #define | GPIO_ICR2_ICR18_MASK (0x30U) |
| #define | GPIO_ICR2_ICR18_SHIFT (4U) |
| #define | GPIO_ICR2_ICR18(x) |
| #define | GPIO_ICR2_ICR19_MASK (0xC0U) |
| #define | GPIO_ICR2_ICR19_SHIFT (6U) |
| #define | GPIO_ICR2_ICR19(x) |
| #define | GPIO_ICR2_ICR20_MASK (0x300U) |
| #define | GPIO_ICR2_ICR20_SHIFT (8U) |
| #define | GPIO_ICR2_ICR20(x) |
| #define | GPIO_ICR2_ICR21_MASK (0xC00U) |
| #define | GPIO_ICR2_ICR21_SHIFT (10U) |
| #define | GPIO_ICR2_ICR21(x) |
| #define | GPIO_ICR2_ICR22_MASK (0x3000U) |
| #define | GPIO_ICR2_ICR22_SHIFT (12U) |
| #define | GPIO_ICR2_ICR22(x) |
| #define | GPIO_ICR2_ICR23_MASK (0xC000U) |
| #define | GPIO_ICR2_ICR23_SHIFT (14U) |
| #define | GPIO_ICR2_ICR23(x) |
| #define | GPIO_ICR2_ICR24_MASK (0x30000U) |
| #define | GPIO_ICR2_ICR24_SHIFT (16U) |
| #define | GPIO_ICR2_ICR24(x) |
| #define | GPIO_ICR2_ICR25_MASK (0xC0000U) |
| #define | GPIO_ICR2_ICR25_SHIFT (18U) |
| #define | GPIO_ICR2_ICR25(x) |
| #define | GPIO_ICR2_ICR26_MASK (0x300000U) |
| #define | GPIO_ICR2_ICR26_SHIFT (20U) |
| #define | GPIO_ICR2_ICR26(x) |
| #define | GPIO_ICR2_ICR27_MASK (0xC00000U) |
| #define | GPIO_ICR2_ICR27_SHIFT (22U) |
| #define | GPIO_ICR2_ICR27(x) |
| #define | GPIO_ICR2_ICR28_MASK (0x3000000U) |
| #define | GPIO_ICR2_ICR28_SHIFT (24U) |
| #define | GPIO_ICR2_ICR28(x) |
| #define | GPIO_ICR2_ICR29_MASK (0xC000000U) |
| #define | GPIO_ICR2_ICR29_SHIFT (26U) |
| #define | GPIO_ICR2_ICR29(x) |
| #define | GPIO_ICR2_ICR30_MASK (0x30000000U) |
| #define | GPIO_ICR2_ICR30_SHIFT (28U) |
| #define | GPIO_ICR2_ICR30(x) |
| #define | GPIO_ICR2_ICR31_MASK (0xC0000000U) |
| #define | GPIO_ICR2_ICR31_SHIFT (30U) |
| #define | GPIO_ICR2_ICR31(x) |
IMR - GPIO interrupt mask register | |
| #define | GPIO_IMR_IMR_MASK (0xFFFFFFFFU) |
| #define | GPIO_IMR_IMR_SHIFT (0U) |
| #define | GPIO_IMR_IMR(x) |
ISR - GPIO interrupt status register | |
| #define | GPIO_ISR_ISR_MASK (0xFFFFFFFFU) |
| #define | GPIO_ISR_ISR_SHIFT (0U) |
| #define | GPIO_ISR_ISR(x) |
EDGE_SEL - GPIO edge select register | |
| #define | GPIO_EDGE_SEL_GPIO_EDGE_SEL_MASK (0xFFFFFFFFU) |
| #define | GPIO_EDGE_SEL_GPIO_EDGE_SEL_SHIFT (0U) |
| #define | GPIO_EDGE_SEL_GPIO_EDGE_SEL(x) |
DR_SET - GPIO data register SET | |
| #define | GPIO_DR_SET_DR_SET_MASK (0xFFFFFFFFU) |
| #define | GPIO_DR_SET_DR_SET_SHIFT (0U) |
| #define | GPIO_DR_SET_DR_SET(x) |
DR_CLEAR - GPIO data register CLEAR | |
| #define | GPIO_DR_CLEAR_DR_CLEAR_MASK (0xFFFFFFFFU) |
| #define | GPIO_DR_CLEAR_DR_CLEAR_SHIFT (0U) |
| #define | GPIO_DR_CLEAR_DR_CLEAR(x) |
DR_TOGGLE - GPIO data register TOGGLE | |
| #define | GPIO_DR_TOGGLE_DR_TOGGLE_MASK (0xFFFFFFFFU) |
| #define | GPIO_DR_TOGGLE_DR_TOGGLE_SHIFT (0U) |
| #define | GPIO_DR_TOGGLE_DR_TOGGLE(x) |
| #define GPIO_DR_CLEAR_DR_CLEAR | ( | x | ) |
DR_CLEAR - DR_CLEAR
DR_CLEAR - Clear
DR_CLEAR - Clear
DR_CLEAR - Clear
| #define GPIO_DR_DR | ( | x | ) |
DR - DR
DR - DR data bits
DR - DR data bits
DR - DR data bits
| #define GPIO_DR_SET_DR_SET | ( | x | ) |
DR_SET - DR_SET
DR_SET - Set
DR_SET - Set
DR_SET - Set
| #define GPIO_DR_TOGGLE_DR_TOGGLE | ( | x | ) |
DR_TOGGLE - DR_TOGGLE
DR_TOGGLE - Toggle
DR_TOGGLE - Toggle
DR_TOGGLE - Toggle
| #define GPIO_EDGE_SEL_GPIO_EDGE_SEL | ( | x | ) |
GPIO_EDGE_SEL - GPIO_EDGE_SEL
GPIO_EDGE_SEL - Edge select
| #define GPIO_GDIR_GDIR | ( | x | ) |
GDIR - GDIR
GDIR - GPIO direction bits
| #define GPIO_ICR1_ICR0 | ( | x | ) |
ICR0 - ICR0 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR0 - Interrupt configuration field for GPIO interrupt 0 0b00..Interrupt 0 is low-level sensitive. 0b01..Interrupt 0 is high-level sensitive. 0b10..Interrupt 0 is rising-edge sensitive. 0b11..Interrupt 0 is falling-edge sensitive.
| #define GPIO_ICR1_ICR1 | ( | x | ) |
ICR1 - ICR1 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR1 - Interrupt configuration field for GPIO interrupt 1 0b00..Interrupt 1 is low-level sensitive. 0b01..Interrupt 1 is high-level sensitive. 0b10..Interrupt 1 is rising-edge sensitive. 0b11..Interrupt 1 is falling-edge sensitive.
| #define GPIO_ICR1_ICR10 | ( | x | ) |
ICR10 - ICR10 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR10 - Interrupt configuration field for GPIO interrupt 10 0b00..Interrupt 10 is low-level sensitive. 0b01..Interrupt 10 is high-level sensitive. 0b10..Interrupt 10 is rising-edge sensitive. 0b11..Interrupt 10 is falling-edge sensitive.
| #define GPIO_ICR1_ICR11 | ( | x | ) |
ICR11 - ICR11 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR11 - Interrupt configuration field for GPIO interrupt 11 0b00..Interrupt 11 is low-level sensitive. 0b01..Interrupt 11 is high-level sensitive. 0b10..Interrupt 11 is rising-edge sensitive. 0b11..Interrupt 11 is falling-edge sensitive.
| #define GPIO_ICR1_ICR12 | ( | x | ) |
ICR12 - ICR12 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR12 - Interrupt configuration field for GPIO interrupt 12 0b00..Interrupt 12 is low-level sensitive. 0b01..Interrupt 12 is high-level sensitive. 0b10..Interrupt 12 is rising-edge sensitive. 0b11..Interrupt 12 is falling-edge sensitive.
| #define GPIO_ICR1_ICR13 | ( | x | ) |
ICR13 - ICR13 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR13 - Interrupt configuration field for GPIO interrupt 13 0b00..Interrupt 13 is low-level sensitive. 0b01..Interrupt 13 is high-level sensitive. 0b10..Interrupt 13 is rising-edge sensitive. 0b11..Interrupt 13 is falling-edge sensitive.
| #define GPIO_ICR1_ICR14 | ( | x | ) |
ICR14 - ICR14 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR14 - Interrupt configuration field for GPIO interrupt 14 0b00..Interrupt 14 is low-level sensitive. 0b01..Interrupt 14 is high-level sensitive. 0b10..Interrupt 14 is rising-edge sensitive. 0b11..Interrupt 14 is falling-edge sensitive.
| #define GPIO_ICR1_ICR15 | ( | x | ) |
ICR15 - ICR15 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR15 - Interrupt configuration field for GPIO interrupt 15 0b00..Interrupt 15 is low-level sensitive. 0b01..Interrupt 15 is high-level sensitive. 0b10..Interrupt 15 is rising-edge sensitive. 0b11..Interrupt 15 is falling-edge sensitive.
| #define GPIO_ICR1_ICR2 | ( | x | ) |
ICR2 - ICR2 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR2 - Interrupt configuration field for GPIO interrupt 2 0b00..Interrupt 2 is low-level sensitive. 0b01..Interrupt 2 is high-level sensitive. 0b10..Interrupt 2 is rising-edge sensitive. 0b11..Interrupt 2 is falling-edge sensitive.
| #define GPIO_ICR1_ICR3 | ( | x | ) |
ICR3 - ICR3 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR3 - Interrupt configuration field for GPIO interrupt 3 0b00..Interrupt 3 is low-level sensitive. 0b01..Interrupt 3 is high-level sensitive. 0b10..Interrupt 3 is rising-edge sensitive. 0b11..Interrupt 3 is falling-edge sensitive.
| #define GPIO_ICR1_ICR4 | ( | x | ) |
ICR4 - ICR4 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR4 - Interrupt configuration field for GPIO interrupt 4 0b00..Interrupt 4 is low-level sensitive. 0b01..Interrupt 4 is high-level sensitive. 0b10..Interrupt 4 is rising-edge sensitive. 0b11..Interrupt 4 is falling-edge sensitive.
| #define GPIO_ICR1_ICR5 | ( | x | ) |
ICR5 - ICR5 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR5 - Interrupt configuration field for GPIO interrupt 5 0b00..Interrupt 5 is low-level sensitive. 0b01..Interrupt 5 is high-level sensitive. 0b10..Interrupt 5 is rising-edge sensitive. 0b11..Interrupt 5 is falling-edge sensitive.
| #define GPIO_ICR1_ICR6 | ( | x | ) |
ICR6 - ICR6 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR6 - Interrupt configuration field for GPIO interrupt 6 0b00..Interrupt 6 is low-level sensitive. 0b01..Interrupt 6 is high-level sensitive. 0b10..Interrupt 6 is rising-edge sensitive. 0b11..Interrupt 6 is falling-edge sensitive.
| #define GPIO_ICR1_ICR7 | ( | x | ) |
ICR7 - ICR7 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR7 - Interrupt configuration field for GPIO interrupt 7 0b00..Interrupt 7 is low-level sensitive. 0b01..Interrupt 7 is high-level sensitive. 0b10..Interrupt 7 is rising-edge sensitive. 0b11..Interrupt 7 is falling-edge sensitive.
| #define GPIO_ICR1_ICR8 | ( | x | ) |
ICR8 - ICR8 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR8 - Interrupt configuration field for GPIO interrupt 8 0b00..Interrupt 8 is low-level sensitive. 0b01..Interrupt 8 is high-level sensitive. 0b10..Interrupt 8 is rising-edge sensitive. 0b11..Interrupt 8 is falling-edge sensitive.
| #define GPIO_ICR1_ICR9 | ( | x | ) |
ICR9 - ICR9 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR9 - Interrupt configuration field for GPIO interrupt 9 0b00..Interrupt 9 is low-level sensitive. 0b01..Interrupt 9 is high-level sensitive. 0b10..Interrupt 9 is rising-edge sensitive. 0b11..Interrupt 9 is falling-edge sensitive.
| #define GPIO_ICR2_ICR16 | ( | x | ) |
ICR16 - ICR16 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR16 - Interrupt configuration field for GPIO interrupt 16 0b00..Interrupt 16 is low-level sensitive. 0b01..Interrupt 16 is high-level sensitive. 0b10..Interrupt 16 is rising-edge sensitive. 0b11..Interrupt 16 is falling-edge sensitive.
| #define GPIO_ICR2_ICR17 | ( | x | ) |
ICR17 - ICR17 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR17 - Interrupt configuration field for GPIO interrupt 17 0b00..Interrupt 17 is low-level sensitive. 0b01..Interrupt 17 is high-level sensitive. 0b10..Interrupt 17 is rising-edge sensitive. 0b11..Interrupt 17 is falling-edge sensitive.
| #define GPIO_ICR2_ICR18 | ( | x | ) |
ICR18 - ICR18 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR18 - Interrupt configuration field for GPIO interrupt 18 0b00..Interrupt 18 is low-level sensitive. 0b01..Interrupt 18 is high-level sensitive. 0b10..Interrupt 18 is rising-edge sensitive. 0b11..Interrupt 18 is falling-edge sensitive.
| #define GPIO_ICR2_ICR19 | ( | x | ) |
ICR19 - ICR19 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR19 - Interrupt configuration field for GPIO interrupt 19 0b00..Interrupt 19 is low-level sensitive. 0b01..Interrupt 19 is high-level sensitive. 0b10..Interrupt 19 is rising-edge sensitive. 0b11..Interrupt 19 is falling-edge sensitive.
| #define GPIO_ICR2_ICR20 | ( | x | ) |
ICR20 - ICR20 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR20 - Interrupt configuration field for GPIO interrupt 20 0b00..Interrupt 20 is low-level sensitive. 0b01..Interrupt 20 is high-level sensitive. 0b10..Interrupt 20 is rising-edge sensitive. 0b11..Interrupt 20 is falling-edge sensitive.
| #define GPIO_ICR2_ICR21 | ( | x | ) |
ICR21 - ICR21 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR21 - Interrupt configuration field for GPIO interrupt 21 0b00..Interrupt 21 is low-level sensitive. 0b01..Interrupt 21 is high-level sensitive. 0b10..Interrupt 21 is rising-edge sensitive. 0b11..Interrupt 21 is falling-edge sensitive.
| #define GPIO_ICR2_ICR22 | ( | x | ) |
ICR22 - ICR22 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR22 - Interrupt configuration field for GPIO interrupt 22 0b00..Interrupt 22 is low-level sensitive. 0b01..Interrupt 22 is high-level sensitive. 0b10..Interrupt 22 is rising-edge sensitive. 0b11..Interrupt 22 is falling-edge sensitive.
| #define GPIO_ICR2_ICR23 | ( | x | ) |
ICR23 - ICR23 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR23 - Interrupt configuration field for GPIO interrupt 23 0b00..Interrupt 23 is low-level sensitive. 0b01..Interrupt 23 is high-level sensitive. 0b10..Interrupt 23 is rising-edge sensitive. 0b11..Interrupt 23 is falling-edge sensitive.
| #define GPIO_ICR2_ICR24 | ( | x | ) |
ICR24 - ICR24 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR24 - Interrupt configuration field for GPIO interrupt 24 0b00..Interrupt 24 is low-level sensitive. 0b01..Interrupt 24 is high-level sensitive. 0b10..Interrupt 24 is rising-edge sensitive. 0b11..Interrupt 24 is falling-edge sensitive.
| #define GPIO_ICR2_ICR25 | ( | x | ) |
ICR25 - ICR25 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR25 - Interrupt configuration field for GPIO interrupt 25 0b00..Interrupt 25 is low-level sensitive. 0b01..Interrupt 25 is high-level sensitive. 0b10..Interrupt 25 is rising-edge sensitive. 0b11..Interrupt 25 is falling-edge sensitive.
| #define GPIO_ICR2_ICR26 | ( | x | ) |
ICR26 - ICR26 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR26 - Interrupt configuration field for GPIO interrupt 26 0b00..Interrupt 26 is low-level sensitive. 0b01..Interrupt 26 is high-level sensitive. 0b10..Interrupt 26 is rising-edge sensitive. 0b11..Interrupt 26 is falling-edge sensitive.
| #define GPIO_ICR2_ICR27 | ( | x | ) |
ICR27 - ICR27 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR27 - Interrupt configuration field for GPIO interrupt 27 0b00..Interrupt 27 is low-level sensitive. 0b01..Interrupt 27 is high-level sensitive. 0b10..Interrupt 27 is rising-edge sensitive. 0b11..Interrupt 27 is falling-edge sensitive.
| #define GPIO_ICR2_ICR28 | ( | x | ) |
ICR28 - ICR28 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR28 - Interrupt configuration field for GPIO interrupt 28 0b00..Interrupt 28 is low-level sensitive. 0b01..Interrupt 28 is high-level sensitive. 0b10..Interrupt 28 is rising-edge sensitive. 0b11..Interrupt 28 is falling-edge sensitive.
| #define GPIO_ICR2_ICR29 | ( | x | ) |
ICR29 - ICR29 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR29 - Interrupt configuration field for GPIO interrupt 29 0b00..Interrupt 29 is low-level sensitive. 0b01..Interrupt 29 is high-level sensitive. 0b10..Interrupt 29 is rising-edge sensitive. 0b11..Interrupt 29 is falling-edge sensitive.
| #define GPIO_ICR2_ICR30 | ( | x | ) |
ICR30 - ICR30 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR30 - Interrupt configuration field for GPIO interrupt 30 0b00..Interrupt 30 is low-level sensitive. 0b01..Interrupt 30 is high-level sensitive. 0b10..Interrupt 30 is rising-edge sensitive. 0b11..Interrupt 30 is falling-edge sensitive.
| #define GPIO_ICR2_ICR31 | ( | x | ) |
ICR31 - ICR31 0b00..Interrupt n is low-level sensitive. 0b01..Interrupt n is high-level sensitive. 0b10..Interrupt n is rising-edge sensitive. 0b11..Interrupt n is falling-edge sensitive.
ICR31 - Interrupt configuration field for GPIO interrupt 31 0b00..Interrupt 31 is low-level sensitive. 0b01..Interrupt 31 is high-level sensitive. 0b10..Interrupt 31 is rising-edge sensitive. 0b11..Interrupt 31 is falling-edge sensitive.
| #define GPIO_IMR_IMR | ( | x | ) |
IMR - IMR
IMR - Interrupt Mask bits
| #define GPIO_ISR_ISR | ( | x | ) |
ISR - ISR
ISR - Interrupt status bits
| #define GPIO_PSR_PSR | ( | x | ) |
PSR - PSR
PSR - GPIO pad status bits
